My mate's N/A 2.1 Zetec Mk2 Orion, Now Breaking
Old 05-11-2006, 05:58 PM
  #41
Ex-Finesse
Ex-Finesse's Avatar
That's AWESOME
Would the engine builder reveal all the spec?
I'm currently having built a zetec with a very similiar spec. I'd love to know the spec of his, especially cam duration.
Like the angled inlet manifold too.
Old 06-11-2006, 06:59 PM
  #42
Johnny Knoxville
Johnny Knoxville's Avatar
Originally Posted by Ex-Finesse
That's AWESOME
He's not letting on at all much, Cams i know are wild and run 32mm oversize tappets, 48mm T/B's, and all the normal stuff?
Inlet is a custom job
Old 07-11-2006, 07:30 PM
  #43
Ex-Finesse
Ex-Finesse's Avatar
That's AWESOME
Oversize tappets - having to use the same here. Expensive stuff bearing in mind the head has to be modded to accept them too.
A few things I'd really like to know, and I would really appreciate it if he could reveal:
Is he using standard 2-piece valves?
What CR is he running?
In his opinion, what is the safe maximum rpm for a standard crank, with forged rods and pistons in a fully balanced engine. Standard crank grind (ie. no regrind needed) if it makes a difference
We're using the standard one on mine, thinking it'd be ok for up to 8500rpm. We plan to use 1-piece S/S valves, and our CR is planned at 11.75:1.
Sorry for all the questions, but any answers would be great.
Ralph.
Old 08-11-2006, 12:22 PM
  #44
Johnny Knoxville
I know it has S/S oversize valves
13:1 compression
He's also got a standard crank that has just been balanced and he said it will be save for 9k rpm's.
Its the std exhaust manifold that is the problem with the zetec's, even the aftermarket ones are crap, he has a custom jobby.
Old 08-11-2006, 01:07 PM
  #45
orion_crazy_carl
orion=mini saff
orion_crazy_carl's Avatar
his user name is freak power,says it all really
Old 08-11-2006, 02:36 PM
  #46
rs nutta
rs nutta's Avatar
wow looks minted
Old 08-11-2006, 06:02 PM
  #47
Ex-Finesse
Ex-Finesse's Avatar
Thanks v. much for the info mate.
Could you ask him how much his exhaust manifold cost? And whether he'd be interested on getting another sourced / made?
The only one looking viable for my engine is the Dunnell one, which looks a similiar design, but is very expensive... well over Ł500!
Muchos gracias mate
Old 08-11-2006, 07:58 PM
  #48
Johnny Knoxville
I Know Dunnels has gone up in price
His was more than 700!!
Old 08-11-2006, 09:24 PM
  #49
Johnny Knoxville
If anyone wants more details on this car please e-mail the owner for info, parts for sale i.e conversion parts and tuning a N/A Zetec
freakpower300@yahoo.co.uk
Old 08-11-2006, 09:42 PM
  #50
zippyobrien
zippyobrien's Avatar
that inlet is ridiculouse,
how can it possibly need 8 injectors,
must have an interesting flow pattern by the time the fuel is in the head, surely the fuel could spill???
Old 08-11-2006, 09:52 PM
  #51
Johnny Knoxville
Usually, the second injectors (the ones far away from the valve) will only open at WOT and at high rpm. When this two conditions are met, airflow is really high and the sprayed fuel outside the trumpet will be sucked in with no problem.
Injecting fuel far away from the valve will cold down ACT's better and the air mixture will be more homogeneous which will help since problems can arise (fuel droping out of suspension) when loads of fuel is injected.
All F1 engines have injectors like this, and the "cloud" made by the spray on them is massive! No fuel spills out the trumpet.
Actually there is also other reason:
- When the injector near the inlet valve is too big, it will hurt low airflow mix (fuel will drop out of suspension and the injector injects too much fuel at low ms openings). Use smaller injectors and get another set far away to only help high rpm fueling.
It all dependes were the extra set of 4 injectors are placed on the inlet. You can have 2 injectors spraying at the same time right at the back of the inlet valve(s), but this would only be aceptable if the injectores were really small and top-end will hurt on the mix due to the two injectors not flowing enough.
Only if you go above 500cc or so that you'll start having problems with low airflow speed and small injector cycles.
Ok, this is just a rule from where to start because there's alot more involved than just saying "500cc is the max for any kind of inlet manifold design".
This aplies to any engine, NA or turbo charged/supercharged.
Old 08-11-2006, 09:54 PM
  #52
zippyobrien
wow, really is hight tech stuff going on the fords these days,
excelelt explination, many thanks
Old 11-11-2006, 10:26 AM
  #53
Johnny Knoxville
Old 28-01-2007, 02:03 PM
  #54
Johnny Knoxville
Andrew asked me to thank Austin for the coil on plugs and holder
He's having a custom loom made for the conversion
The S60 pro has loads of trick stuff on it
Old 28-01-2007, 03:38 PM
  #55
ADT168
ADT168's Avatar
love this car and the engine thats in it
Old 28-01-2007, 03:44 PM
  #56
Fastas
Fastas's Avatar
VERY NICE
Old 28-01-2007, 04:26 PM
  #57
Munch
Mr. Sparkle!
Munch's Avatar
Old 28-01-2007, 04:28 PM
  #58
Very nice
Old 14-03-2007, 09:05 PM
  #59
Johnny Knoxville
Been told by Andrew the engine will be coming out for some small mods.
I don't know what his plans are but he did say issues with oil pump and sump
Old 06-06-2007, 08:27 PM
  #60
Johnny Knoxville
He will be fitting a dry sump
Old 07-06-2007, 09:00 PM
  #61
rigwrecker
rigwrecker's Avatar
Old 07-06-2007, 09:35 PM
  #62
Johnny Knoxville
He's also just fitted a electric water pump as well
Old 07-06-2007, 09:39 PM
  #63
18"chris
18"chris's Avatar
bloody hell,thats 1 well spec'd engine! good work fella
Old 08-06-2007, 06:59 PM
  #64
Johnny Knoxville
I'll pass it onto him
He also said that he has a ST170 engine in his work shop been stripped but this engine will in the car in a few years time as he wants to see what this one does
Old 09-06-2007, 02:35 PM
  #65
Johnny Knoxville
The Old
The New
Old 04-07-2007, 08:21 PM
  #66
Johnny Knoxville
As almost everything in the engine has been modified andrew didn't want to take any risks with the standard oil pump and sump set up so he's going to make this lot fit
He redid the clock as he wasn't happy with the las setup
Old 04-07-2007, 08:38 PM
  #67
749steve
749steve's Avatar
top work
when will it be done and running?
Old 04-07-2007, 08:40 PM
  #68
Johnny Knoxville
He said some time this year
Old 05-07-2007, 02:16 PM
  #69
markc
markc's Avatar
awsome car credit to the builder
Old 05-07-2007, 04:24 PM
  #70
MrCapriScort
Old Fords Never Die
MrCapriScort's Avatar
Engine bay looks a work of art, by the sounds of the engine spec should shift aswell. Them clocks look well trick
Old 05-07-2007, 09:16 PM
  #71
Johnny Knoxville
Old 05-07-2007, 09:56 PM
  #72
NEEDFORSPEED
NEEDFORSPEED's Avatar
keep us updated!! mint!!
Old 10-08-2007, 05:19 PM
  #73
Johnny Knoxville
Just been told he's sorted everything out and the dry sump will fit without any cutting of the inner wing.
He wants me to say thank you to Ryan @ UK car looms for the help with the loom he wanted
Old 07-10-2007, 01:08 PM
  #74
Johnny Knoxville
A little update the sump, Andrew words not mine, i just did a copy paste job
The kits from pace and titan were never made for FWD cars but i thought to myself i need one and have to make it fit
The sump fits but a modification to the old oil pump is needed, almost all the internals have been taken out as is will no longer provide the pressure. as you can see the new pump is meant to bolt the back of the sump but the drive shaft will hit it so it has to be moved to the front.
The problem with it been at the front is you need a Escort alternator and bracket but its still to high to clear the fitting of the pump so i've made a bracket to move it up 50mm and out 25mm, doing this i've had to modify the water pump as you can see, this was done in preparation for the sump when i fitted the electrical water pump as the stage 3 kit you get a water pump pulley kit that will not fit a FWD engine bay
I've just got to make and weld a bracket to the sump to lower the pump and make it adjustable for the belt and give a bit more clearance for the feed pipes and get a longer bit to drive the pump, pipe work and fitting kit for that, a few modifications to the the engine bay to give a little more clearance for the pump pulley
The set up
The new bracket that i welded to the sump
The new pulley thats been shortened for clearance
Never feels good to cut up a Titan sump, needs must as my manifold hit it before and now it doesn't
Just got to weld up the hole and make sure the flow of oil runs to the pick up pipes
Next thing i have to sort out is pipe work and oil cooling
Old 13-10-2007, 10:19 AM
  #75
Johnny Knoxville
Andrew ask me to post this for him
I was trying to find someone to make me one at at a good price. Was going to get this made at Simtek but they wanted Ł1800!!. But i ended up getting it at uk car looms for just Ł550 and well worth it
Nice coil on plug and N/A 8 injector set up
Top job Ryan and thanks again
Old 21-11-2007, 09:15 PM
  #76
Johnny Knoxville
Just a little update from Andrew
I made some time and welded up my sump
Fitted the oil tank in the engine bay in front of the gearbox and the catcher tank to the strut brace witch i'll post piscs later.
Its all going to fit and he said he would send me the pics of the sump set up after the weekend
Old 21-11-2007, 10:53 PM
  #77
RAT8OY
RAT8OY's Avatar
FUCK ME!!
Thats a VERY tidy car!
Old 22-11-2007, 06:07 AM
  #78
Old 22-11-2007, 04:54 PM
  #79
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
amazing! love it
Old 22-11-2007, 06:44 PM
  #80
Ade
Fast Ford snapper
Ade's Avatar
Love the wheels, what size/width/tyre and offset are they?
Thinking of those for my MK3....... you get any rubbing issues with them?
Quick Reply: My mate's N/A 2.1 Zetec Mk2 Orion, Now Breaking
