S1 Full *CUSTOM* build from shell! *****NOW FINISHED******
Old 23-06-2005, 10:28 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Default S1 Full *CUSTOM* build from shell! *****NOW FINISHED******
Soon to be finished so thought i would share a few shots
This is how it has been sitting for the past year untill now
Group N T3 Hybrid 4x4 Turbo with a De - restriced 34mm. .48 Exhousing. Group N oil feed.
Polished and rounded fuel rail and Cosworth fuel regulator, Yellow injectors, Festo connections to vacum for fuel reg to manifold.
Mk5/6 fuel filter with Festo non rubber connections.
Stainless steel braided fuel lines.
Bailey swirl pot with Samco pipes and Mikalor clamps.
Stainless steel Goodridge water lines and connectors.
STD 1.4 CVH EFi Mk5/6 Black rocker cover, with rubber gasket.
Alloy cam cover washers with stailess counter sunk cap heads bolts.
Another shot of the Group N Turbo
Inlet manifold been smoothed and finished in satin black to match the rocker cover. Fitted with the Water temp convertor, ACT convertor. Stainless lock nuts and stainless water pipes to and from the heater matrix.
THE COIL PACK! 8)
Smoothed inlet manifold. Festo connections. Fuel feed to the rail has a valve making it easy to check fuel pressure.
Brand new Throttle body. Festo connection in the inlet manifold with high pressure lines.
Old 23-06-2005, 01:26 PM
CliffRS4
CliffRS4's Avatar
Looking very nice.
Good to see another one being kept alive
Old 23-06-2005, 03:18 PM
adamS2RST
adamS2RST's Avatar
Excellent stuff, looks mad
Old 23-06-2005, 03:26 PM
The Sludge
garibaldi
The Sludge's Avatar
Old 23-06-2005, 06:58 PM
Versus_Creations
Ask me a question!
I checked the engine management today with the ECU from my XR.
Took out the plugs and placed them on the rocker cover while still attached to the leads. So when turning over engine i should see a spark.
Took the plugs off the injectors and using a MK5 escort side light holders in place of the injectors, i can now check that the injectors get a pulse when turning over the engine.
I am yet to run a wire for the fuel pump so instead i connected up a mulitmeter and made sure that the wire was getting 12v with ignition on.
So with no fuel (Cos the injectors are unpluged) and no spark (cos the plugs are on the rocker cover) i turned over the engine and could see the firing order and also the injectors plugs flashing
So the outcome is, that if i have these two parts of the management working and i assume i have compression.......she should start..
I need to take the loom back out and do the final touches to make it fit nice and look nice. Then a little wiring for fuel pumps and triggers etc..
Hope to have her on the road real soon.
Old 23-06-2005, 07:14 PM
pau1rs
pau1rs's Avatar
seen this in the flesh and is mint and a proper spot on build!!!
top work by jano again!!!!!
ps.. still got ya iscv mate!!!!
Old 23-06-2005, 07:34 PM
essexrsturbo
essexrsturbo's Avatar
seen this build all the way through and the attention to detail is bordering on stupidly detailed, things like every clip being individually polished.. should be awsome.
want anymore pics geez? as ive got loads ive been taking along the way
but sod that get on with building my loom mutha fuka!!
Old 23-06-2005, 07:39 PM
Versus_Creations
Ask me a question!
REALLY i will make your loom cook you breakfast if you like
if you can email the pics to me ill post sum up
Old 23-06-2005, 07:43 PM
Versus_Creations
Ask me a question!
Its a MINOR mate glad you getting use out of it
Old 23-06-2005, 07:45 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
get more pics up
Old 26-06-2005, 11:12 PM
Versus_Creations
Ask me a question!
Originally Posted by Freddy_mercury_magic
get more pics up
Ok here we have the Original ford side stickers to be fitted
A little notice to help people move around the workshop
Old 27-06-2005, 12:16 AM
luke89
Team HOTHOT!
luke89's Avatar
looks quality mate well done
Old 27-06-2005, 05:17 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
@ the note
looks minted janno, didnt know them graphics were still avail from ford
Old 27-06-2005, 06:48 PM
LIAMRSTS1
LIAMRSTS1's Avatar
Looking good dude
Old 27-06-2005, 10:14 PM
chiz
chiz's Avatar
its mad and i like it!!
Old 28-06-2005, 10:48 AM
Rossco
Rossco's Avatar
@ the note
When i asked a few months ago they wernt.
Looking good though Jano , but FFS sort a decent camera out
Old 28-06-2005, 12:42 PM
tenpotturbo
tenpotturbo's Avatar
nice work mate
Old 28-06-2005, 09:07 PM
kingpin09
kingpin09's Avatar
Ez jano its the kaz man!!! pow pow. the s1'z lookin sick, pictures dont do it justice.
Look forward to seeing it next time i pop around. Peace, keep up the good work guvnor
Old 28-06-2005, 09:36 PM
Dangerous Malcolm..
Dangerous Malcolm..'s Avatar
One to watch.
Old 30-06-2005, 08:24 AM
Versus_Creations
Ask me a question!
Originally Posted by Rossco
@ the note
The graphics have been unavailable for the last 5 years. I have had them hanging around just in case i bought a S1
Old 01-07-2005, 06:07 PM
1900cvh
1900cvh's Avatar
Very nice mate !!!
Thanks for the pulley washer !!!!
Old 01-07-2005, 09:28 PM
Adam Ash
Adam Ash's Avatar
Any piccies of the actual car ?
Old 03-07-2005, 11:55 AM
Versus_Creations
Ask me a question!
Yes mate
Old 05-07-2005, 08:17 PM
Gadget
Spanner monkey
Gadget's Avatar
I've seen this car in the flesh when i was down getting some bits from Jano and it's superb, all the work and neatness of it all is outstanding
Old 07-07-2005, 03:30 PM
Old 07-07-2005, 08:28 PM
RS220Turbo
RS220Turbo's Avatar
Lovely looking mota there brv hopefully you’ll have another one to work on soon. i'l need new stickers brv about 3 of em.
Old 07-07-2005, 10:29 PM
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
That looks shit hot Jano, i was chatting to one of my mates about you last week. His names Liam, got a S1 - you supplied him all the bits to go cozzie management, hes over the moon
Spoke very highly of you, but then he never told me nothing i didn't already know
Old 08-07-2005, 05:52 AM
Rossco
Rossco's Avatar
Thats better, cracking pics
Old 08-07-2005, 09:04 PM
Versus_Creations
Ask me a question!
Thanks to everyone for their kind words
I started her up today with no errors on the management system and will hopefully start to put her back together real soon...
ESSEX RS Reigional day here we come maybe not on the road due to TAX and MOT etc... will trailor it down
Where you been dude aint seen ya for ages!! Get things together and come over
Yes mate he also has a very nice S1 pic below
Old 09-07-2005, 11:45 AM
rs shawn
S1 Database Editor
rs shawn's Avatar
Any bigger pics of the actual car to go with the parts-pics ?
Old 09-07-2005, 08:28 PM
Versus_Creations
Ask me a question!
I will take some decent pics of the inside as i am putting it back together and also the rest of the motor.. It still needs to be flat and polished then polished by hand so will take the final shots of the outside after
Old 24-07-2005, 12:54 AM
Versus_Creations
Ask me a question!
If anyones about tomorrow at the essex rs show come and have a lookski....almost finished
Old 24-07-2005, 08:52 AM
Red16
Red16's Avatar
plenty of bling bits, very nice
Old 24-07-2005, 09:58 AM
RS2000_Daz
RS2000_Daz's Avatar
shit hot matey
Old 24-07-2005, 05:45 PM
rich p xr2t
rich p xr2t's Avatar
Jano_OddKidd, i c it at the essex show mate, very nice
Old 26-07-2005, 08:16 AM
Versus_Creations
Ask me a question!
Thanks for the kind words. The car is 90% done now. Still trying to find silly clips and parts like the washer jets and rubber to go around the wiper in the the spoiler etc..
Going back down the breakers today.
Will update with decent pics real soon
Old 26-07-2005, 01:17 PM
Sticky.
Sticky.'s Avatar
Old 26-07-2005, 03:07 PM
Brian
Brian's Avatar
Look's very nice mate
Brian
Old 27-07-2005, 08:09 AM
Versus_Creations
Ask me a question!
A few i took at the essex show.
I know its not a S1 but its a mk3 which is almost good enough
Old 27-07-2005, 11:24 AM
Linsay
Linsay's Avatar
Got one of these to keep cats away from my car?
Quick Reply: S1 Full *CUSTOM* build from shell! *****NOW FINISHED******
