Rosso red Rs turbo build and progress.
Rsmat (23-03-2019)
#1327
Well i've started to collect the bits for a future escort project, I just miss my 90 spec xr3i rs turbo rep. With the prices the way they are and the fact I need a LHD importing a bonus or the like and putting everything on it seems the best way to go.
While you have the engine out if its not too much trouble could you measure in the engine bay between both chassis legs as I'm looking into engine swaps and want to see what space I have to work with, i've seen vag 1.8t 20v's fitted before.
Keep up the good work, its your car thats one of the reasons I want another (even if unfortunately it will be a rep and not a genuine rst)
Rsmat (23-03-2019)
#1328
Chassis legs 650mm
Bay is 900mm
visa_broke (23-03-2019)
#1331
well had a change of heart Saturday morning .. put the order in with buzz weld for x4 stage 1 W.A.R Shultz in RAL3002 (red) and an FX11 Gun ..I then ordered a new fuel tank and some rear ARB shackles and a set of adjustable tie rod ends and some camber bolts for the rear ..then I decided to strip all the underside ready for it all landing.. today I dropped gear off at the powder coaters. this week ill prep all the underside ready to under seal , I also cleaned my steering rack up .
Rsmat (26-03-2019)
#1334
I just fitted a new tank to mine. Got it from car parts express. All good but the hose clip that is in between the sender hole and the fill hole as seen in your picture has no fixing on the non ford tank. I attached mine with adhesive and it’s fine.
Rsmat (26-03-2019)
Rsmat (26-03-2019)
#1341
Evening, was a good read that. Should have some good stopping power now to keep those horsies in check.
what do you think of the Mipa paint? Finnish looks superb. Your like a human dynamo mate.
#1343
today the new tank arrived which will be 2K painted and lacquered in OE silver . I've also got the paint for the new brake lines. the steering rack dust guard broke so that's going up to Raj @ Autoflock to have one made as you cant get them at al.l also all the brake line clips arrived and the clips and bolts for the arch liners ,I've also bought a turbo blanket to try and tomorrow im going to start restoring the nuts , bolts and washers for all the underside .
Also bought a new water matrix bulkhead seal.
#1348
today the delivery of the buzz weld W.A.R arrived , so I made a trip up to chirk auto paints and bought the strato silver for the new fuel tank and a roll of masking paper then I started stripping the last bits off the underside and removed the 30 year old fuel / brake line clips.. I managed a good 30mins on the wire wheel but forgot to take pics ,,hoping to get it all cleaned and prepped for under sealing Saturday.
#1351
Wow Matt you really don't hang around. I got mine back from paint December and haven't made as much progress in 3 months as you have in the past 3 weeks!
I have however managed to get hold of the Mipa paint for mine today and ordered all new headlights, full bearings, bottom arms, track rod ends and tie bar links for the underside rebuild so motivation is back on. I have tried to find the clips and screws for the wheel arch liners but god knows where they are in the pile of "spares" i have. Where you get yours from and do you have any pictures of the plastic clips they go into within the inner arch. If you could send a picture of the screws and fixings where you can for the washer bottle aswell please it might help me identify them in the pile i have here.
Thanks pal and keep up the good work...
#1352
PM me your number and I'll what's app the pics over quicker mate
#1353
Rsmat (31-03-2019)
Rsmat (31-03-2019)
