Rosso red Rs turbo build and progress.
#1163
Basically got to where the car was Saturday ..only to be informed of hidden bill for Ł420 .. so a grand total of Ł2,830 for the pleasure of a car with hardly any water in it , old wiring loom still hung down the passenger side and one of my bonnet vents broke ..the whole ordeal has took the piss ..car looks a right mess plus the engine is fucked ..bearing and possible crank Damage ..I've started stripping it today to get the engine back to ALD for inspecting and rebuild ..the car has only done 26 miles in total on the rollers and that's included 12 runs at 1 bar or so I'm told ..anyhow ordeal over its now time to crack on and get it sorted .
I drained what was left in the engine from the bung coming out ..0.7L of oil .
sump off ..and damage apparent .
Rsmat (27-01-2019)
Rsmat (27-01-2019)
Rsmat (27-01-2019)
#1172
That is shocking. Some people take no pride in their work, clearly the car is beautifully presented and anyone working on it should match it.
sorry to hear the engine is damaged from the bung.
Rsmat (27-01-2019)
#1174
What a shame mate after all the graft you put in. This is why I'd be scared to ever let anyone touch my car as they never seem to take care of it like it's your own. I'm sure you'll get it
Sorted mate good luck
Rsmat (28-01-2019)
#1177
I am at a loss for words.
I can understand a cylinder head plug coming loose. However, to pump out 4 liters of oil? Hell that thing must have almost caught on fire.
It must have been running a very long time for that much oil to come out of the distributor hole opening.
I have always been at dyno test sessions for my personal cars/engines. I guess I don't trust too many people with my hard earned $$.
I know you will get this sorted out soon enough.
Just one of those shit things that happens from time to time.
Keep up your good work. It will be a stunner when finally completed!!
Rsmat (28-01-2019)
#1178
as per our convo on faceache, such shoddy neglegent workmanship its like your car was treated with as little respect as possible for some reason.
how the fuck do you break a vent as far as im aware your never anywhere near them to cause any damage?
that wiring loom is a complete joke, im by no means any good with electrics but my god im sure i could have a go at making a tidier job than that.
to only run the car for 20 or so miles before whacking the boost up is a piss take also as i know you wanted at least 200 miles of running/bedding in first, maybe if he had done this the problem of the bung would of been easier/quicker to spot in the first place.
Im just glad it hasnt disheartened you and that your going sort it with the help of ALD. Then get it up to MSD so some proper tuners can sort it
Rsmat (28-01-2019)
#1183
That is shit news mate and bad workmanship leaving a wiring job like that when you've paid to have the job done properly
But with the oil leak if the car gave no signs the oil was leaking they may not have noticed anything til oil pressure dropped and the dreaded knocking started
#1185
that's exactly what happened the pressure dropped instant he shut off and it was to late.
#1186
Hi Matt, sorry to hear about the loss of oil pressure. I too know the feeling of an engine dying... I'm on engine number 5 .. Just remember to never give up; you've come so far with the whole project. The car is still looking stunning even if it doesn't run (its still a shonky ford but we love our shonky fords )... It WILL be worth it in the end! As for the loom, did you want to retain all of the MFI wiring? Its really not that hard to remove the MFI wiring, should that be what you want to do. All you need to do is unwrap the loom that is no longer needed and just cut as far back as you can, then retape it. Also maybe something to think about.. Add a knock sensor to your ecu.. Why did you have it on the rollers if the engine wasn't bedded in? It just doesn't make any sense.. After all the hard work you have done I would recommend before you get it on the rollers again to get some mileage down off boost. Sounds like the tuners didn't know what they were doing if they did 12 runs at 1 bar boost without running the engine in first, sounds like a recipe for disaster IMO. We live and we learn hey. You weren't to know that the the bung would have popped out, I don't think anyone could have anticipated that. At least this is an extremely valuable lesson to be learned. Rather have an issue on a rollers than blowing up an engine and getting into an accident on the roads. Keep your head up, back to the drawing board, with the necessary adjustments you'll come back bigger and better. As for the broken vent, if you go on eBay there's a few for sale. Good luck and keep the updates coming!
Rsmat (28-01-2019)
#1187
Hi Matt,
Absolutely gutting mate. Mate well impressed with your attitude and drive to get it sorted. I would probably shut it in a garage and leave it for 6 months and sulk for a bit.
As someone said above worth the trip to MSD for finishing work. I am happy with the work Stu and the team did on my cossie. That was running in and mapping a fresh built engine to with sorting the usual teething issues out along the way. You get good tea to.
keep up the good work.
#1188
Hi Matt,
Yea I've used MSD for nearly 16 years ..I'll get the car sorted and take it up for final run in and map .
#1189
I really thought it was going to be okay but the metal particles have unfortunately proved me wrong. I’m glad you are still motivated.
The untidy wiring and damage to your vent is unacceptable and the reason I would never leave the boost monster in someone else’s care and a factor in why I’ve still not fitted EFI to mine yet.
#1191
with regards to the running in of the engine, mat had instructed and agreed with the tuner to have it ran in on the rollers before giving it any boost etc, this was obviously not done which again is piss poor and neglegent imo
#1192
It's just unreal that I've seen it said recently thiers no needs for big miles on running in when did this change? What is the reason for lower miles these days? When Ahmed built my 1900 yes a long time ago he put it on a basic map hardly any boost and told me to come back in a thousand miles time I drove it from the south coast to the north coast and back plenty of stretching the engine not holding at a set speed then went back for boost just seems odd
#1193
I'm not sure myself ..was told that a well built engine with the right running in oil will bed the rings in a matter of a few miles / heat cycles by a few good people ..I think this time I'd like to run it in myself for a few 100 miles at least with a run in map.
#1194
Yeah deffo mate for your own peace of mind I know Ahmed was always safety in mind when I asked him about the yb build for the focus he wasn't keen to go over 600 for reliability reasons I guess they all had have thier own methods aye.
#1196
I didn't do that many miles iirc with my R32 on new tr racing engine I'm sure it was under 1000 miles, it only needs bedding in doesn't take long
Rsmat (29-01-2019)
#1197
I've been reliably informed 600 hp is the limit for reliability under sustained abuse, above that needs some operator sympathy
Rsmat (29-01-2019)
Rsmat (29-01-2019)
#1199
exactly that mate. All of mine and friends race engines are run in like that. Sorry to hear of the issues, on home builds your going to be experience some teething issues. I think also 200 miles to be run on a rolling road is unrealistic.
Rsmat (29-01-2019)
