Rosso red Rs turbo build and progress.
adduk (13-09-2018)
#882
Bit of a weird one with that belt matt but least you spotted it, keep up the good work
#883
Looks awesome mate, under the bonnet looks cracking.
What cc are you? 1600?
What kinda power are you at?
Cheers Paul
Cheers Paul
#884
300+
thanks mate ..Yea it's a forged blueprinted CVH 1600 ..it's not mapped yet but I'd like to say I could pull 380 of the block would hold up ..but it's a road car so I'm capping it at 300 .
Rsmat (12-08-2018)
#887
300+
A bit of an update although not much has happened as I've been in North Africa ..I've decided on a few add ons to the spec .like Tractive drive and launch control so we can use the power to tarmac better and I'm waiting on a few parts coming back that have had to be altered so hopefully by the end of the month I should be in a position to book for mapping.
also I'm half tempted to have anti lag .
#889
300+
I've got all the bits for DBW but not fitting yet ..that's what the wheel sensor is for and the box sensor are for ..for now .
VW TB and mk7 fiesta peddle in stock for future mod .
#892
Quality install mate. Looks like itll be out in spring now?
Rsmat (18-09-2018)
Rsmat (19-09-2018)
#897
300+
#898
Ah ok! I didnt even notice the side button TBH! Looks well where it is, I have always been a fan of rear mounting and flush mounting if the item can, but in your case. clearly not able to
Rsmat (21-09-2018)
Rsmat (24-09-2018)
bluntys1rsturbo (26-09-2018)
Rsmat (28-09-2018)
#904
Blimey been a while since I've seen any of Brom's kit.
You need to grab a blanking plate for the old stereo joystick (by the steering wheel) - looks lost and is obviously pointless functionality wise. Hopefully you can grab one for peanuts, afternall they were fitted across the range so shouldn't suffer RS tax
Looks great otherwise
Rsmat (28-09-2018)
#905
300+
Can you get blanks for them mate as it isn't needed as you say ..so I'll look into that once it's up and running .
Well I've booked it in for mapping and Steve himself is coming to mine to take a look at what we need and says he will fit and map in only a few days ... so just waiting for Steve to turn up at my house .
Rsmat (28-09-2018)
#907
I remember those joy sticks being the height of cutting edge gadgets..a bit like the open door pic on a Sierra. I would keep it just for that retro connection.
Rsmat (28-09-2018)
#908
I had a similar MEF front ARB kit on a mk3 escort. Great bits of kit, really transformed the handling. I think the bits of hardware that bolt through the tca's can be bought direct from rally design
#909
300+
yea they was cutting edge mate when out I quite like it ..could use it for my Anti lag and traction control or boost .
I'll have to find one incase I don't use the toggle mate.
#911
300+
Well had a few hours on the car today ..Got round to fitting the Rally design quick shift kit I've had on the shelf for 2 years ..reason I've gone for this is because I've had one before and was great plus I don't have to drill or cut anything on the car ...anyhow got it all done and it feels great ..nice smooth and short shift .
Rsmat (03-10-2018)
Rsmat (03-10-2018)
#917
300+
Had a mock up with an old cone filter tonight ..and measured up for a new one and a nice 45° hose (on order) ..then I cleaned up the hose clips for the boost pipes and fitted then the next day my bespoke made leads arrived and my new Zeitronix loom landed..and tonight I've sourced some M10 x 1.5 Aero lock nuts and stainless bolts for the T3 flange .
#918
300+
Managed to get the mock up with the RamAir cone filter and measure up I've ordered a 76mm- 89mm 45° black hose ..I also got the breather all plumbed in and the cam trigger sensor set up ..few random pics. I've decided once it's all mapped and running I'll strip the bits and tanks etc and pic a colour scheme so it all looks nice and neat.
