Focus RS MK1 with WRC influence
#201
I hope the welds hold up...MK is really only just learning, I am going to teach him how to use a mig on my Clarke 135 and then astound him with my Myford super 7 lathe skills.
#202
That sounds like a serious bit of competition. I bet mark is shitting his pants !!
#203
That's more than adequate for an old Peugeot with a rattly old pinto in it.
#205
I’m glad no-one is spamming my thread
#209
Sorry mate
#210
Don’t be pal I’m only messing. Keeps my thread on the 1st page
jonfoc (19-10-2017)
#213
Thanks Tim. You've kind of read my mind. For the initial build it will stay FWD. Then once the engine and bits are proven, I'll sell off all the suspension bits and gearbox, then go AWD. EVO is the way I'm leaning. This won't be for a while though.
#214
This VID shows how it handles in the wet, your FOCUS would be sooo cool doing this:
#216
Well it’s in paint. A nice shade of dark matt grey. It should keep the reflection down.
#217
Looks ACE. I really like it. What will you do in the foot wells where your feet would rub it away? Something like Rhino liner or have trays made up? I would also put something like 3m clear tape on the door bars as your feet will scratch them really quickly. I have the 3m carbon fibre tape and I just replace it yearly as it scuffs up.
#218
#219
Nah sold it on ,Mk took a life time to complete the work that was supposed to take 3/4 months so got pissed off and broke it ,twins congrats now your even more skint
#223
Mate that’s a shame. What are you on with now?
Yeah twins are great.
#225
I started work on the underside today. I was concerned about the amount of surface rust forming so I set about it with a wire wheel and scotch brite. Once it was shiny again and all the old rusty bits were free of loose bits, I lathered way too much bilt hamber electrox on it all. Should keep it protected for a while. Once it’s dry it’ll be having a 2 pack epoxy mastic coat then gravitex where needed. It’ll possibly have a light grey top coat too.
#227
Propper job
#228
Cheers pal. Once it's in my garage I'll give you a nudge and you can pop over if you fancy?
#229
Yeah sound mate
#230
A little more done today. Gravitex in the rear arches then I cleaned the main floor pan before I applied a dusting of etch primer. I’m leaving it a couple of days now to go off before I apply the epoxy mastic and start on the sills
#231
Epoxy mastic was applied today. That’s the underside pretty much done now. I doubt I’ll put a top colour on. Just a bit of seam sealing to do. Monday I’m onto the sills and front arches.
I think if I do a top coat it’ll be a similar shade of grey. It’ll certainly help to spot oil leaks.
#232
You can do mine if it comes back lol
#233
What do you mean if!!? I thought he Was on it now. Yeah no problem mate, I’m finding it quite enjoyable
#234
Lol im sure it will one day mate some good graft going in on yours how many wire brushes did you use remember doing my s2 i looked like pinhead from hellraiser when i got out from under the car
#235
Only used 3 mate plus a lot of thinner and scotch brite. it wasn’t too bad to be fair
#236
Cool my mate who did the rs face lift on the shell said the under seals like concrete on newer cars hopefully it wont be to bad but i do want to do what youve done
#237
Don’t get me wrong I don’t want to do it again anytime soon but it wasn’t that bad. I’ve got a hole in a sill that needs sorting but the rest is solid. I left all the sound proofing on as it was solid and the interior showed no signs of rot. I’ll fill all the chassis rails with acf50 or dymax sealant and keep my fingers crossed
#238
Wonder how rusty mine are now sat up thier
#239
I suppose that depends if it’s tucked away warm in a unit or it’s spent 3 years exposed to the elements
