MK4 Escort 1.3 Popular
#121
it sounds good in that video...
also the engine bay looks mint, you're taking great care of that lil' cherry...
well done mate!
keep us posted...
well done mate!
keep us posted...
JC600 (11-09-2016)
#122
All ready for Blackpool, fuelled up, Tyre pressures checked, levels checked. Washed, polished and waxed. *
Also got a lock set, so I (my dad lol) *can re-code the ignition barrel to match the rest of the locks. *
Also gave the ST a quick clean lol
JC600 (17-09-2016)
JC600 (17-09-2016)
#133
Finally got a full set of Amber's, when I fit them I'm also going to repaint the backs of the headlights. *
Also got a brake fluid leak, around the master cylinder. Leaves a patch on top of gearbox. Main seal is dry, no fluid in the servo. Servo looks brand new inside. Think it may be the lid or reservoir seals.*
Started scraping the blistered paint off the servo.*
#134
Checked for brake fluid leaks whilst under pressure, and nothing. Checked the cap and there is fluid on the threads, so think it's weeping out the cap whilst driving.*
I've ordered a new cap and keep a eye on it, it's only a very small leak. Just annoying having to wipe the gearbox off all the time.*
Think I best give the servo a lick of paint now lol
#135
Thats the ambers in, master cylinder and servo painted. Cleaned the surface rust off the back of the headlights, treated and resprayed them. The paint reacted, so will have to do them again at some point.
Just waiting for my remote idle speed control valve and new brake reservoir cap to arrive. *
#136
Remote idle speed control valve and new brake reservoir cap have arrived. Will get them fitted one night this week.*
The holes are already in the inner wing, so that makes it easier. Hopefully my idle problems will be resolved and my brake fluid leak. **
#137
New reservoir cap fitted, and remote idle speed control valve fitted. *
Set idle speed at 850rpm, returns back 850rpm after revving the engine. No stalling when dipping the clutch and idles loads better, smoother too. So all good so far. Just need to take it for a test drive after I finish call. *
#138
each time you put your hand in it, she gets better and better...
keep it going!
well done mate!
keep it going!
well done mate!
JC600 (28-09-2016)
#140
Exhaust clip from my MK4 with 1.6efi cvh with 2" bore down pipe back stainless steel exhaust.
And the engine idling nicely after fitting the remote idle speed control valve.
#141
Took the Escort for a good 40 mile drive this morning, idle is spot on now. So can stop and drive off properly now. Seems to be a bit quicker too.
Definitely have no brake fluid leaks, but still had fluid on top of the gearbox. Looks like it was coming from the transmission to clutch housing bolt. Checked the bolts, and they didn't seem that tight. So torqued them up to the correct amount. Hopefully that's sorted it.
Some better pic's with the ambers fitted.
JC600 (02-10-2016)
#145
Looks good as Ive mentioned before. Someone was selling the small heckspoiler(think its the 1.6 sport one) on a facebook group for about Ł40. Someone was selling a full set of the XR3i side mouldings for Ł40 too! I thought of you when I saw them. Also ummmm....Flaps!?!
#147
Flaps are still in the garage, test fitted the rears and they were nearly on the floor lol. And there's a lot of speed bumps near me. I need the molded type, which I'm on the look out for.
Cheers mate, it's the small one I'm after.
#148
Sorry i dont know the name, I'm on mk3 mk4 parts wanted for sale. mk4 escort owners uk, Which one I cant remember.
Was the same as this one:
http://www.ebay.co.uk/itm/FORD-ESCOR...IAAOSw3YNXZbPr
Also NOS flaps for you.
http://www.ebay.co.uk/itm/New-Genuin...3D222279529963
#153
Yes I cant remember if they were an accessories item though. I'm certain i've seen them on Bonus models years ago.
It'll suit your car.
Heres a link to the other one I remember, it was painted too.
https://www.google.co.uk/search?q=es...FzcxtUhZIhM%3A
#154
http://m.ebay.co.uk/itm/Perfect-Fit-...22016&fdback=2
Cheers Glenn. As always.
JC600 (28-10-2016)
#156
Collected a few parts today, correct airbox for the remote idle speed control valve I fitted. Genuine Ford Indicator to replace the aftermarket one I have fitted. And a coil pack cover that mine was missing. Just need a good clean before I fit them all. *
#159
your engine bay always looks better, each time you put your hands in it .
opposite than mine, lol.
keep the updates coming mate! i love this thread...
#160
