My 4x4 re-shell
Hi all
Today me and a few mate started to re-shell my 4x4 and to be fair we did break the back of the strip down
I only picked the shell up on Thursday
Today we striped the rear rand and all the insid the car
I'm hoping to have the engine ang gearbox out on Wednesday but that is all if the misses lets me get away with it
Got your work cut out there mate!? At least now it's getting warmer, with longer days, working outside won't be so bad... What's up with the old shell? Rust?
Good luck with it!
Good luck with it!
The old shell is fine It need the underside cleaned and painted and a little cleane up hear and there but it's not to bad.
It's a cat d tho so as I was planning on striping and doing all the work thought it would be easier to just swap it to a clean shell.
A little update
So yesterday was an exspenceive day out too this lot to be powdercoated
And I payed for the all the wheel bearings and break pipes as well as new oil and filter and hydroulic cluch master cylinder. Was a bit of whack but it's all stuff that needs replacing or doing befor I can start to rebuild.
And today I got the rest of the loom disconnect and pulled up to the fuse box
And the air con box out.
The gear box was removed and cleaned up
The engine is ready to lift out and need to get the loom out and re covered before I can star putting stuff back together
I kneed to source a New fuel tank, heater fans, and ideally I would like to change the glass as my shell has all its original glass and when (if) it is sold on id like to sell it with all its glass
No the box is not too bad a skyline one is a lot heavier
I thought the powder coating was a reasonable price I had a lot done. Pluss that was for blasting , undercoating , and 2 layers of paint
I did say I'll pay cash tho lol
Thanks for the kind words
I am hoping to have it taxed and on the road by the end of next month
But the way it drained my bank this month I think that my be s push
But it's by tomorrow the engine should be out or at leas ready to lift. And the shell will be ready to start going back together
I kneed an engine crane tho
As for the driveway build Its a luxury copied to my last one
We reshelled my rs turbo I not a bonus shell outside my mothers house
It was emotional
So had lots done over the past week but it's all silly stuff so dose no look like much
Iv polly usage all the front tca fitted the car loom abs loom. The engine loom is next. Iv sound proofed the front of the car minus the bulk head. Built the beam up. All the wheel bearings are fitted I just need to colect then from my brother
The bonnet lock is fitted I'm waiting on new loom clips as getting the old ones out is a fucking nightmare
Iv checked the hole car loom and I remove all 3 of the old alarms.
I'm now going back together so after all the little jobs it should start looking better
Since my last post a few bits have been completed
All the looms are now refitted and ran almost in place
All the glass and rubbers are fitted now looks like a car
The rear beam is now back together
The rear diff is compleat just waiting for oil
It's have all new break pipes front to rear. And on the beams
It have new bolts in ever component it's had new wheel bearing on all for corners
The shock and spring were looking a little shabby but worked prefectly so I cleaned them up
The dash is ready to be refitted this week. The engine is out of the old she'll so it can now be cleaned up
And the old shel is ready to go
Shell came up at the right time. The silver one needed some bits doing as Well as you know. To be fair I'm glad I did iv sorted lots of little niggles out that I would never have found otherwise. I don't know what I'll do with my self after she is done I'll have to spend time with the kids I guess
Please please please remove the rear trailing arm bushes and use the GGR ones.
Poly bushes are a massive downgrade over the factory spherical joint bushes. I can promise you 100% your car will handle shit, wander and clunk because of them.
You'll end up hating the car. I have replaced all mine with the GGR bush and they're just far superior. I assure you what I am telling you is the best and only way to do it. There's plenty on here that'll agree.
Just don't want you to build the car to then not like it due to that reason. Whilst stuff is easy to remove I'd seriously suggest doing it and changing them.
