Marks moonstone 3dr
Old Dec 8, 2014 | 11:09 PM
Markpo's Avatar
Markpo
Default Marks moonstone 3dr
Hi folks , thought I would start a build thread on here for my new cossie . Been after a 3 dr for many years. I looked for one id be happy with for about a year and explored all avenues. Price was the major factor as I didn't have a large amount of cash to just go out and buy a minter. So I searched the web for about a year every day until a car came up locally I had my eye on . Managed to strike a deal with the owner we were both happy with (from a forum member).
The sierras In need of some tlc due to being off the road dry stored for the past 7 years but it's a solid honest example .
joined two mates in a unit they rent out in Glasgow both are mechanics so its ideal having just about any tool to hand. Im hoping to learn a bit about these cars and carry out most work myself so its going to be my first big project with some help along the way . here are some pics of it in the unit.
Had a day off work so started messing about on the sierra yesterday . Brakes and suspension have seen better days so stripped them off.. Callipers will be rebuild/painted and I'll order some new bilstein shocks and springs at standard ride height .
Polybush kit ordered and subframe and all components will be going to get powder coated and generally cleaned up .. Plan for winter is get it driving properly and sort the small jobs out . Not too concerned about paint for time being.
Stripped the kit off it and luckily not a great deal of rust to tackle so far , this was a big worry before buying the car . It's had some welding in the past on the sills but to be expected so overall happy with how its looking . The car was built 3 years before I was even born so its unlike most cars i`ve previously owned and its my first ford. Only had the pleasure of driving it for a few days before it went into the garage but in that time its proved to be all I expected.
Been down the unit a few times recently for a couple hours at a time .. Subframe has been dropped and all rear suspension now off the car . Will take it over to powder tech next week when I get paid . I've started under sealing the arches and rubbed them back to near enough bare metal , fronts came out pretty well .. removed the old bushes which wasn't fun but its done now.
Gave the prop shaft a paint as it was pretty rough looking , cracked the diff open to add the new seal kit so oil looked like it's never been changed.
Removed the rest of the kit and discovered an area of rot that'll need attention .. This was a worry when buying a Cossie as so many suffer .. Luckily it'll just need a sill on the n/s and it only cost me £25 .
bits and bobs
Standard Cam belt cover and airbox . Also got a set of roose performance boost pipes as originals are gubbed . Just buying things when I can really .
Old Dec 9, 2014 | 12:22 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Good luck with it mate, I enjoyed doing mine
Steve
Old Dec 9, 2014 | 03:48 PM
Markpo's Avatar
Markpo
Steve
thanks matey appreciated . looking forward to the better weather coming in so I can actually drive it
Old Dec 9, 2014 | 04:20 PM
james kiely's Avatar
james kiely
its hard to beat a moonstone 3dr ,best of luck with the rebuild matey
Old Dec 9, 2014 | 06:43 PM
siscossie's Avatar
siscossie
3-door moonstone
Good luck fela be worth it when it's done
Old Dec 9, 2014 | 06:53 PM
Harryh24's Avatar
Harryh24
nice project! will follow!
Old Dec 9, 2014 | 07:12 PM
cameron2's Avatar
cameron2
Good luck mate. Hope that sill isn't fucked inside like mine was.
Old Dec 9, 2014 | 08:24 PM
Harryh24's Avatar
Harryh24
actually yeah that happened to me as well.
Old Dec 9, 2014 | 08:41 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Great car good luck
Old Dec 12, 2014 | 12:15 AM
Hellraiser's Avatar
Hellraiser
Not too bad then fella seein as been stood for 7 yrs :0) best colour too, I will be keeping an eye on this
Old Dec 14, 2014 | 06:33 PM
Nice to see another 3dr getting saved/looked after.
Old Dec 15, 2014 | 09:36 AM
COLEYST200's Avatar
COLEYST200
Keep at it mate and keep the updates coming
Old Dec 21, 2014 | 01:53 PM
Markpo's Avatar
Markpo
Bought some bits, dropped the fuel tank and decided just to get a fresh one ordered . Also bought some new suspension. Decided to try out avo shocks and springs. Started rebuilding the driveshafts, got them broken down and cleaner all components in petrol. Gave the shafts a sand then painted matt black . New boots and greased them up. Waiting on new set of bolts to come but they're looking fresh.
Parts off to get powder coated .
Cleaning up the diff now as it's got 30 years worth of grime .. Needs minimal welding and should be ready to under seal start building up suspension , brakes lines by mid jan ..
Old Dec 21, 2014 | 02:01 PM
ajamesc's Avatar
ajamesc
If that new fuel tank dose not have the proper plastic surge tank inside it I'd be very careful. I fitted an after market one in mine with a metal surge tank in side and it surged it's nuts off!
Old Dec 21, 2014 | 02:15 PM
Markpo's Avatar
Markpo
Thanks for the heads up mate , still got the original so if it's bad I'll need to clean that one up .
Old Dec 21, 2014 | 03:14 PM
ajamesc's Avatar
ajamesc
May just have been the make I used for the fact it couldn't supply fuel fast enough as I was running 500bhp. But it was modded to aero quip fitting so couldn't change it back. I had to fit a second fuel pump and a surge tank in the boot to make it work in the end
Old Dec 21, 2014 | 04:17 PM
Ive just fitted a tank with the metal surge tank in it. I put 16 quids worth of petrol in it and kicked its head in and it was ok. That was on the way to the petrol tank to put anotjer 30 quid in.
Old Dec 21, 2014 | 04:19 PM
ajamesc's Avatar
ajamesc
There be a few different makes knocking about no doubt. The one I have is rubbish. But then the guy I got it off said it came off a 330bhp saff
Old Dec 21, 2014 | 04:26 PM
Escos Jam's Avatar
Escos Jam
Excellent project mate. Doing an awesome job so far. I'm only along the road in Falkirk if you're needing another pair of hands
Old Dec 22, 2014 | 10:07 AM
Markpo's Avatar
Markpo
Much appreciated matey I'll keep that in mind thanks a lot .
Old Dec 25, 2014 | 03:47 PM
tjRS500's Avatar
tjRS500
Looking good... Where did u get the stuff to overhaul the rear driveshafts? Boots clips etc?
Old Dec 26, 2014 | 09:28 PM
costina's Avatar
costina
Live long and prosper!!
Glenn, your lucky then mate as James said there are some shit tanks about be careful it could cost you a engine
And yes I have seen these tanks and looked inside they are not great.
Paul
Old Dec 26, 2014 | 10:50 PM
jc2000e's Avatar
jc2000e
great project! love it.
Old Dec 27, 2014 | 05:55 AM
AJC's Avatar
AJC
Just bare in mind you don't want to fit poly bushes to the rear trailing arms. Any poly bush in there is a serious downgrade in bush
Old Jan 5, 2015 | 05:44 PM
Markpo's Avatar
Markpo
I was lucky enough to have some areas of welding sorted out over the weekend by a pal who works in a fabrication shop, he's done a cracking job sorting out the rotten arch and a couple other small areas .
While he was cutting and welding I set about cleaning up the diff and diving it a lock of fresh paint . About 30 years of grime clinging to it ..
Wee keyring I got for Christmas
Old Jan 5, 2015 | 07:36 PM
Escos Jam's Avatar
Escos Jam
Looking good mate!!
Mark RS
Mar 5, 2021 06:08 PM
martynhomer01
Oct 1, 2015 12:05 AM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
