Escort Cosworth M3NTE TINY update page 13 Nov 15th 2007
#86
Small update for you....
Bought some bits to run a direct 12V supply to fuel pump, to get rid of the old loom running under the car, now the original pump feed fires up a new relay, running my new cabling, The earth for the pump goes direct back to the battery only thing I gotta do to sort it is source a new plug for the top of the tank (as per pics)
Oh and just a little note also, I have dropped all my old engine bits to Harvey Gibbs @ SCS I just KNEW I was gonna end up going silly
basic spec....
big wing baffled sump
std crank
std rods
lowered comp pistons with valve cutouts
BRAND spanking new block, which will be Longstudded
GENUINE WRC headgasket
Head, slight work around valve seat area, other than that std, obviously new guides lifters etc
Light Blue injectors
T34
FULL Dyno map by Harvey Gibbs and Ahmed Bayjoo
Other stuff I gotta sort,
New bosch 023 fuel pump
Alcon 6 Paddle clutch
Custom genuine PECTEL Engine loom
dizzyless ignition (coil pack)
that little lot will come in at a shade over 6k ... I KNEW IT I bloody knew I would go overboard
basic spec....
std crank
std rods
T34
#90
No point going greys, AFAIK Power is limited by my turbo and head/cams Benn. Well I just go on the advise of my engine builder lol.
Dave it is, well yours, Harvey's and Ahmeds
#91
ahhhh so not going full monty like Dave then lol.
Go on might aswell
Gonna have to get mine on the road soon lol, looks like i will have some decent competition
Go on might aswell
#96
All I wanted was a SAFE STRONG reliable STG III, hence the WRC gasket and long studs, aswell as new block and injectors, the rest is just incidental so more power too will defo soften the blow
#101
www.ctuceilings.co.uk
There isn't alot I can say on here that I haven't said to you on the phone on Saturday lol
#103
Originally Posted by BillyCabrio
Now i see the reason for the reminder
Damo, take what i said with a fist full of salt.
#107
AndyRST,
With that spec will it be marginal on the Diff's and the box holding out ?
_________________
_________________
Tony Turbo,
BillyCabrio,
*Anna*,
Still don't mean that you have the money and need reminding every post does it!!!!!
Anna, If you wish to have a public discussion regarding the rights, wrongs and social etiquette with regards to paying friends / associates who do a job for you without prior agreement regarding longterm payment options we can do, otherwise please dont fire off at me.... When I am not the one in the wrong..... Paul knows he owes me money as do I obviously, Paul knows I am not hassling him big style for the money, though obviously NOW I do need it ASAP.... simple... Contrary to popular opinion I am not a rich man
DAve when you taking your tank up?
#108
Quote:
BillyCabrio,
You mustve edited it before I got a chance to read it ...
BillyCabrio,
Dont worry he didnt say anything too out of order Just having a bad hair day
Im gonna get my old box rebuilt aswell, proberbly get Bernie to do it.
#109
oooh dear
Originally Posted by Benn 304R
Quote:
BillyCabrio,
BillyCabrio,
#110
Tony Turbo,
Until your bank writes to you at least
#112
you soon forget about the big bill you paid out......
#113
damo, i want to go up soon-ish.....
fancy another trip up there????
we 'could' take the bitches, then take them out afterwards for a dring / meal etc..... ??
soften the blow/drive
#114
Done it
Old pins and loom removed from plug
Old wire and new stuff
All soldered to the pins and slotted back in.. I had to open up the plastic a little to take the larger cable but its pukka!! (Took long enough though )
#116
Little update for ya
Bundle of bits from Ford, this little lot was 200 quid
All sorts including fuel filter, engine mounts, fuel tanks seal ring, bits and pieces for the steering column, anti-freeze couple of driveshaft seals etc..
New clutch... (Ł100) Proper AP/Borg&Beck item I'll be using the cover and bearing, and getting an Alcon plate from Mike
Got my powdercoating back now too.. Another 100 quid
Subframe
ARB, brackets and end plates
Power steering/alternator bracket
Bits n pieces
My new 023 fuel pump, courtesy of Phil (IMA) .. cheers mate
Thought I would make a start on stripping the original engine wiring loom out too,
Its out
Subframe
Bits n pieces
Its out
#118
Bloody hell, spaghetti nightmare! Don't you just love trying to work with those multiplugs (like your fuel pump connector)? Facking nightmare!! Good to see you're taking so much care
