Opel Manta 400 Cosworth
#43
Nice project and great work
Always loved the Manta coupe shape, remember seeing Jimmy McRae in the red Ac Delco Manta 400 a couple of times, great car.
I used to run an Ascona Berlina SR which was like a 4 door manta, they were nicely specced cars back in the day.
#44
"SNIFF MY DIFF"
Excellent combination mate, I had a cavalier coupe with a pinto fitted and a manta
with a 400 kit and a pinto fitted about 20 years ago, my mate and his dad had 2
manta i240's, my mates 1 was seriously quick and featured in a mag back then, 1 of my other mates had a i200 with the rothmans colours.
#46
Not a lot done on the car due to work but the good thing about being busy at work means you can spend more on the manta :-0
Some new parts arrived into the garage this week.
Still waiting for the Swedish inlet from G19engineering.
Should be here next week.
Always wanted one of these for the pit. Probably only use it one or two times but should be invaluable when needed
![Name: 7A251202-7530-4919-B41E-A52E580FCBC9-4165-000004AC8B217965_zps5bf421a3.jpg
Size: 92.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78185d1501476758-opel-manta-400-cosworth-7a251202-7530-4919-b41e-a52e580fcbc9-4165-000004ac8b217965_zps5bf421a3.jpg)
Group A coil from Matt Lewis Motorsport
![Name: 6FC27B1A-A405-41B7-9782-6DE757BDC5AB-4165-000004ACAECF1F72_zps43d0b2b2.jpg
Size: 81.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78187d1501476758-opel-manta-400-cosworth-6fc27b1a-a405-41b7-9782-6de757bdc5ab-4165-000004acaecf1f72_zps43d0b2b2.jpg)
8mm plug leads and dizzy cap
![Name: 386593CA-5818-4865-AC12-EC5286C1C2E4-4165-000004ACCEF4F1D3_zps484b1183.jpg
Size: 97.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78188d1501476758-opel-manta-400-cosworth-386593ca-5818-4865-ac12-ec5286c1c2e4-4165-000004accef4f1d3_zps484b1183.jpg)
BMW loom tape for the engine loom
![Name: C45BE3D4-CAFB-4A21-A9F6-89BB442C7E9D-4165-000004ACC797F05C_zps8a92b03c.jpg
Size: 100.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78189d1501476758-opel-manta-400-cosworth-c45be3d4-cafb-4a21-a9f6-89bb442c7e9d-4165-000004acc797f05c_zps8a92b03c.jpg)
My new welder deserved a new mate so a speedglass one to suit![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
![Name: 07E907F7-97D3-41C5-A253-ADFD36DE2E6D-4165-000004ACB80C58B3_zps6348df6e.jpg
Size: 86.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78190d1501476758-opel-manta-400-cosworth-07e907f7-97d3-41c5-a253-adfd36de2e6d-4165-000004acb80c58b3_zps6348df6e.jpg)
Piper cams cambelt arrived and the aluminium bar for the concentric release bearing
![Name: 237841A3-DEFD-4B32-AEED-30CE288B15EC-4165-000004ACC0698119_zpsaebff7bd.jpg
Size: 101.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78191d1501476758-opel-manta-400-cosworth-237841a3-defd-4b32-aeed-30ce288b15ec-4165-000004acc0698119_zpsaebff7bd.jpg)
Arrrgggghhhhh my expensive dewalt grinder armature died so I'm fed up of buying angle grinders
![Name: D0DCA865-9875-4E33-BFF1-3AF2E95CDD40-4165-000004ACD74C3107_zps13612deb.jpg
Size: 91.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78192d1501476758-opel-manta-400-cosworth-d0dca865-9875-4e33-bff1-3af2e95cdd40-4165-000004acd74c3107_zps13612deb.jpg)
So it's back to screwfix cheap ones.
Ł25 for 1000w.
![Name: D268489A-A41F-4080-963A-DBC16EFEFD8B-4165-000004ACDE5957B4_zpscd796326.jpg
Size: 92.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/78193d1501476758-opel-manta-400-cosworth-d268489a-a41f-4080-963a-dbc16efefd8b-4165-000004acde5957b4_zpscd796326.jpg)
Bought 2 and one was faulty straight out of the box. I must be lucky!
Ł25 for 1000w.
#51
Ben
How did I miss this?! Awesome!
Bosch are the only grinders to use, all ours at work are and the only problems we get are when people drop steel on the fookin cable! Or the brushes wear down.
#53
Ben
Our drills are Makita, they don't go wrong either.
#54
Did a bit of work to the intercooler holes in the front end.
Decided to cut the entire panel out ( yep I'm doing the job twice, again!)
![Name: 0F949FEF-62CE-4DFD-851A-F1456E6FC9EF-2660-000003197938BB62_zpsbd37f4aa.jpg
Size: 84.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76048d1501469882-opel-manta-400-cosworth-0f949fef-62ce-4dfd-851a-f1456e6fc9ef-2660-000003197938bb62_zpsbd37f4aa.jpg)
Then made a new panel out of zintec and did a nice hole with a cover
![Name: AEA25B29-3299-4841-AA4A-E5C30B9A3074-2660-0000031969E953F0_zps6dd6d03b.jpg
Size: 73.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76049d1501469882-opel-manta-400-cosworth-aea25b29-3299-4841-aa4a-e5c30b9a3074-2660-0000031969e953f0_zps6dd6d03b.jpg)
![Name: 303D737B-D4B6-44EE-8F40-9ED516814CE3-2660-000003198657AAA8_zps4948844c.jpg
Size: 78.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76050d1501469882-opel-manta-400-cosworth-303d737b-d4b6-44ee-8f40-9ed516814ce3-2660-000003198657aaa8_zps4948844c.jpg)
It's here!!!!!!
Swedish inlet manifold made by Doug at G19 Engineering.
![Name: 89CA64D4-E9AA-4121-8163-4949150588EF-2660-00000318F203C9FE_zps458dd892.jpg
Size: 113.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76051d1501469882-opel-manta-400-cosworth-89ca64d4-e9aa-4121-8163-4949150588ef-2660-00000318f203c9fe_zps458dd892.jpg)
Topped off by a quick release vac line kit from Eneboengineering
![Name: FB82A425-5F9C-4A48-931F-DE4CDAC8677C-2660-0000031917C5F5D7_zps9820d76f.jpg
Size: 66.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76052d1501469882-opel-manta-400-cosworth-fb82a425-5f9c-4a48-931f-de4cdac8677c-2660-0000031917c5f5d7_zps9820d76f.jpg)
Complete with a one piece throttle cable mount
![Name: 174CFE6B-B1CD-493C-8BDA-B7FAF2AD4799-2660-00000318E1EBE861_zps44c24507.jpg
Size: 126.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76053d1501469882-opel-manta-400-cosworth-174cfe6b-b1cd-493c-8bda-b7faf2ad4799-2660-00000318e1ebe861_zps44c24507.jpg)
The manifold is fantastic, great fabrication. Made from 10mm plate ends and what feels like a 5mm+ case.
Check out the welds
![Name: EB450716-5728-4A1A-9E86-36257BBAEAFA-2660-00000318F83FAA2A_zps1fc35d26.jpg
Size: 90.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76054d1501469882-opel-manta-400-cosworth-eb450716-5728-4a1a-9e86-36257bbaeafa-2660-00000318f83faa2a_zps1fc35d26.jpg)
![Name: CC01B88D-9BD3-4239-8877-F477F7687719-2660-00000318D9291FE5_zpsccd7e565.jpg
Size: 106.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76055d1501469882-opel-manta-400-cosworth-cc01b88d-9bd3-4239-8877-f477f7687719-2660-00000318d9291fe5_zpsccd7e565.jpg)
It should go well once fitted with the fuel rail and this new pressure reg
![Name: CF31547B-C776-474B-A2EF-1267206AC2DC-2660-0000031938085A7F_zps4b92b1fc.jpg
Size: 71.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76056d1501469882-opel-manta-400-cosworth-cf31547b-c776-474b-a2ef-1267206ac2dc-2660-0000031938085a7f_zps4b92b1fc.jpg)
![Name: 07E188CD-57CC-45CC-A822-F404438EECD9-2660-00000318D2A4796D_zps0d9e32ac.jpg
Size: 48.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76057d1501469882-opel-manta-400-cosworth-07e188cd-57cc-45cc-a822-f404438eecd9-2660-00000318d2a4796d_zps0d9e32ac.jpg)
Bailey breather to go onto the engine too
![Name: 1A546316-0DB0-4236-8823-2D345D9C8B63-2660-000003192F032DB5_zpsf5bc3099.jpg
Size: 63.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76058d1501469882-opel-manta-400-cosworth-1a546316-0db0-4236-8823-2d345d9c8b63-2660-000003192f032db5_zpsf5bc3099.jpg)
I bought another engine loom, need to check it and wrap it. Getting a good Cossie loom has been difficult. I now have 3.
![Name: 030A0635-A7A8-478D-8AFF-C9DBDF218F87-6094-000006AA2D8B062C_zps43e6bcc8.jpg
Size: 113.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76059d1501469882-opel-manta-400-cosworth-030a0635-a7a8-478d-8aff-c9dbdf218f87-6094-000006aa2d8b062c_zps43e6bcc8.jpg)
This latest one cost 100 quid and still needed a slight rewire due to added wires and alarm shit
![Name: 9ED56233-498B-4DC8-8D52-FA4F723C1BF3-2660-0000031940987068_zps653d5630.jpg
Size: 88.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/76060d1501469882-opel-manta-400-cosworth-9ed56233-498b-4dc8-8d52-fa4f723c1bf3-2660-0000031940987068_zps653d5630.jpg)
Warming the manta gte loom to refit for dry build of engine
![](http://img.photobucket.com/albums/v646/callybreaker/19B0FD29-113D-4294-AAD8-F240E7279E8D-2660-000003194A9B8A7E_zpse56e30f8.jpg)
I want to get 400 bhp out of the engine, can anyone point me towards what I need to do
( for 400, greys,tp09, L8, 3bar, t38, bd10 bd14, breather, ?) but what actuator? Do I need to go wasted spark? what psi do I need to run? Should I strip and inspect the engine? It came out of a low mileage car but as we know it might of been ragged for those miles!
It's here!!!!!!
Check out the welds
#57
Tried the new manifold on, fits great. Thank's to Doug at G19 Engineering
![Name: 185D1A6C-BACB-4EDA-B1DF-D4E4D8C410CD-8917-0000094FF12498B0_zps88ffe1d9.jpg
Size: 84.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70751d1501454839-opel-manta-400-cosworth-185d1a6c-bacb-4eda-b1df-d4e4d8c410cd-8917-0000094ff12498b0_zps88ffe1d9.jpg)
![Name: 40CD83D2-55F0-4384-BB55-49145A48F939-8917-0000094FFA960A0F_zps2c175f89.jpg
Size: 95.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70752d1501454839-opel-manta-400-cosworth-40cd83d2-55f0-4384-bb55-49145a48f939-8917-0000094ffa960a0f_zps2c175f89.jpg)
I have 3 cosworth looms now as you won't believe how hard it is to get a good one.
![Name: DF951DA6-1FD4-4FB2-AB83-AB4868644427_zpsvuqy6tqr.jpg
Size: 167.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70753d1501454839-opel-manta-400-cosworth-df951da6-1fd4-4fb2-ab83-ab4868644427_zpsvuqy6tqr.jpg)
Breather, the high power cossies have to breathe from both sides of the block and not from the cover ( but you all know that
Ł300 later at torques I might have the parts
![Name: E3ACFEEC-5117-4361-B18D-52289FBB8805_zps3zx11rcv.jpg
Size: 139.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70754d1501454839-opel-manta-400-cosworth-e3acfeec-5117-4361-b18d-52289fbb8805_zps3zx11rcv.jpg)
Another Ł100 on teflon braided lines and torques fittings for the fuel rail
Cut the end off the rail
![Name: C4CB83CF-0BD4-4469-AA95-40EAD19A0569_zpstuabok3q.jpg
Size: 94.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70755d1501454839-opel-manta-400-cosworth-c4cb83cf-0bd4-4469-aa95-40ead19a0569_zpstuabok3q.jpg)
![Name: 3AF69A78-0599-4475-849F-3DCABE44F4A3_zpsykgwwgbs.jpg
Size: 90.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70756d1501454839-opel-manta-400-cosworth-3af69a78-0599-4475-849f-3dcabe44f4a3_zpsykgwwgbs.jpg)
Add -AN6 fitting
![Name: 46609F2A-7D84-4414-8FCB-51BCC53663AA_zpsmwow8hta.jpg
Size: 80.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70757d1501454839-opel-manta-400-cosworth-46609f2a-7d84-4414-8fcb-51bcc53663aa_zpsmwow8hta.jpg)
Then return fitting and teflon lined braided nylon pipe
![](http://img.photobucket.com/albums/v646/callybreaker/B5EC1BD9-5530-4CE9-802F-24947DC8C81F_zps0he02ud8.jpg)
Kidney box deleted and a fitting inserted
![Name: 0E5CF3F0-0BFB-4459-BEB7-1B2AE304E2CA_zpsyhpydkux.jpg
Size: 134.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70758d1501454839-opel-manta-400-cosworth-0e5cf3f0-0bfb-4459-beb7-1b2ae304e2ca_zpsyhpydkux.jpg)
Then a AN10 fitting added
![Name: D4326767-9F3B-47AE-AEEA-CE872DF38F20_zpsvodhduo8.jpg
Size: 119.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70759d1501454839-opel-manta-400-cosworth-d4326767-9f3b-47ae-aeea-ce872df38f20_zpsvodhduo8.jpg)
On the other side the fitting looks wrong. I bought AN-10 to 1/2 NPT. It's 3/8 NPT to AN-10 I need so another one ordered this week.
![Name: 7F097B26-D6B6-4EA6-A486-4DC0FCFE4C6A_zpsp87lg1gc.jpg
Size: 134.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70760d1501454839-opel-manta-400-cosworth-7f097b26-d6b6-4ea6-a486-4dc0fcfe4c6a_zpsp87lg1gc.jpg)
It all leads up to the bailey breather. I need a fitting welding into the sump for the oil return
![](http://img.photobucket.com/albums/v646/callybreaker/1A546316-0DB0-4236-8823-2D345D9C8B63-2660-000003192F032DB5_zpsf5bc3099.jpg)
I'm using stainless braided pipe covered in a nylon braid for all the pipes
![Name: 9A4743B0-CA0A-4A68-A864-562775EC3193_zpsqr3ot5r6.jpg
Size: 105.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70761d1501454839-opel-manta-400-cosworth-9a4743b0-ca0a-4a68-a864-562775ec3193_zpsqr3ot5r6.jpg)
Inlet needed a special tool to be made to release the fitting
I will have to have a AN-6 fitting tigged into here onto the inlet
![Name: 61F5ADE6-84F6-443F-ABAB-341F37509BA2_zps7ocz43s6.jpg
Size: 115.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70762d1501454839-opel-manta-400-cosworth-61f5ade6-84f6-443f-abab-341f37509ba2_zps7ocz43s6.jpg)
Header tank bought and polished
![Name: 914D246C-B3E5-42AF-9846-A87D36957A65_zpshn0ifw59.jpg
Size: 134.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70763d1501454839-opel-manta-400-cosworth-914d246c-b3e5-42af-9846-a87d36957a65_zpshn0ifw59.jpg)
Swirl pot needs some work
![Name: 867AC524-73F1-4CD0-A806-849F534F270F_zpsn2duglqv.jpg
Size: 97.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70764d1501454839-opel-manta-400-cosworth-867ac524-73f1-4cd0-a806-849f534f270f_zpsn2duglqv.jpg)
FPR polished but I may put the anodised one on
![Name: 533907EF-9835-44FA-A039-B78EEAD7C976_zpsvpak9ftq.jpg
Size: 125.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70765d1501454839-opel-manta-400-cosworth-533907ef-9835-44fa-a039-b78eead7c976_zpsvpak9ftq.jpg)
PF09 bought, I know need a L8 ECU
Hartge wheels anyone?
![Name: B3AFAE76-A373-42C3-AFE9-CC6FCE1BE84C_zpser5sclld.png
Size: 449.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70766d1501454839-opel-manta-400-cosworth-b3afae76-a373-42c3-afe9-cc6fce1be84c_zpser5sclld.png)
Mine need some love to look like the above
![Name: 30AFFDC2-1CDE-4B1E-A198-C094C252DA9B_zpsiffc9t7z.jpg
Size: 119.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70767d1501454839-opel-manta-400-cosworth-30affdc2-1cde-4b1e-a198-c094c252da9b_zpsiffc9t7z.jpg)
Big decision to be made........................................
I think I'm going to leave it narrow bodied!
Add -AN6 fitting
#58
Ahhhhhhhh, to have a clean pit, all the s##t ends up in their
![Name: 100_2409.jpg
Size: 39.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70745d1501454791-opel-manta-400-cosworth-100_2409.jpg)
![Name: 100_2413.jpg
Size: 37.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70746d1501454791-opel-manta-400-cosworth-100_2413.jpg)
![Name: 100_2415.jpg
Size: 35.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70747d1501454791-opel-manta-400-cosworth-100_2415.jpg)
![Name: 100_2417.jpg
Size: 38.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70748d1501454791-opel-manta-400-cosworth-100_2417.jpg)
Last nights work in the garage. Henry the hoover who lives in the pit decided he didn't want to play anymore so he has stripped and rebuilt, now he can clean the pit again.
The computer screens, one got an upgrade and one a downgrade, the 42" plasma was swopped out for a 37" LCD and the 17" LCD swapped out for a 27" LCD. With the dual screen graphics card on pan it gives an effective ( if not slightly ineffective due to resolutions) 64" display and no Image retention worries as the plasma has gone![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
![Name: 10C74274-AE63-4804-A71E-7ED02E30F4CD_zpsoxn3rl2h.jpg
Size: 102.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/70749d1501454791-opel-manta-400-cosworth-10c74274-ae63-4804-a71e-7ed02e30f4cd_zpsoxn3rl2h.jpg)
#61
if you dont have any luck with the engine loom contact these guys, they are currently making mine, they are very polite and helpfull
http://www.grovegarage.com/?page=services
#62
Live long and prosper!!
www.bigturbo.co.uk
And repair what you got
#63
Little update
Temp boss and ford sender now welded into radiator
![Name: EFC6752A-0B46-4AEC-851A-36B36755CCD3_zpshmrg8hc9.jpg
Size: 124.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/68825d1501448807-opel-manta-400-cosworth-efc6752a-0b46-4aec-851a-36b36755ccd3_zpshmrg8hc9.jpg)
Fuel rail inlet modified with a AN-6 male to male turned down and tigged into it to allow a proper AN -6 connector
![Name: DBDC7064-D9AE-4AA9-8A2A-97D2522DD57F_zpssfqsm8yw.jpg
Size: 239.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/68826d1501448807-opel-manta-400-cosworth-dbdc7064-d9ae-4aa9-8a2a-97d2522dd57f_zpssfqsm8yw.jpg)
Intercooler may be getting a drain put into the bottom.
Reference pic left to right.... Calibra turbo.. 2WD cossie.... Frontera TD... RS500 cossie
![Name: intercoolers002.jpg
Size: 91.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/68827d1501448807-opel-manta-400-cosworth-intercoolers002.jpg)
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
