my evo 5 rebuild, cossie on hold :(
#202
i used zero gauge cable for the battery location
but yes the earths just bolt to the chassis of the car and your new earth will go chassis to battery in boot
you could get a junction box and have your erths go to that that thn one large cable to chasis
will update the thread with some pics over weekend
#203
pic update
e 6 dash bar back in
fuel tank sender seals and nuts
aeromotive stealth 340 fuel pump
new fuel pipes
fitted
i also moved the breather on the tank so this will run up to the filler neck now
i cut a section out for the fuel pump cover to get to the pipes and modded the cover as well, no pic though but will get one later on
bought a new screen wash bottle and pipes and this is all fitted, also got a perm marker and marked the lettering on it
front diff stripped and painted, just waiting on uprated lsd bolts before it goes back together
gearbox stripped cleaned painted and rebuilt
i cant believe how heavy these are and even worse as you can see when i lifted it up i forgot to drain the oil so i got covered in the stuff and my garage still stinks now lol
and ive stripped the engine down and i was glad i did as ive found the pistons rubbing against the bores and bearings just starting to go, so engine will be forged now
ive done some wiring tidying again in the bay just need to get starter and alt cables to make my loom up then thats all done, steering coloum is back in as well, next is to get a full bush kit and and new bolts and start getting the car rolling
new fuel pipes
fitted
#205
tbh the gearbox oil in it smelt very sweet, not like any other gearbox oil ive ever smelt so i could live with it lol
and yes glad i done the engine, has done 80k or 124000km ish, but i did have it on its limit lol
#207
update
first is replace the front lsd with 12.9 bolts
then diff is built up
got a complete set of bushes
now for the rear diff to be installed
wing powdercoated and new bolts from dealer
bushes pressed in
new bolts for rear set up
front bar fitted with new bushes
and all fitted, what a job on your own and on your back lol
going to take out the last bushes today of my lower arms then send my amrs in for powdercoating then these can be fitted
bushes pressed in
Indyrs
04-12-2022 01:39 PM
Russ Payne
25-09-2015 09:29 PM
