sierra wiring crimps in fuse and relay box
hi guys
i wonder if you could help me with a ford sierra wiring problem i have.
i am restoring a january 1984 2 door sierra 1600 automatic, according to DVLC there are only 12 left , so its worth me trying to make a good job of it.
i need to change some of the fusebox and relay parts, namely the female crimps the fuses push into and the female parts the relays push into because they are corroded.
haa anybody any idea where i could buy some ??? or what they are called or even what they look like, i dont want to pull them out and break them, just in case i really cant find any replacements.
any help would be really appreciated
You should be able to get them from a company called polevolt
They should be in the un insulated section
you can remove them from the fuse box with a small flat blade screwdriver
Sierrasideways
15
31-08-2015 10:10 AM
kosienutter
31
22-08-2015 09:55 AM
