mk5 cortina cosworth
just though i would share my cortina build i have been doin it since swptember time when i got it but braking my wrist did slow things lol! The car is mk5 gl done 48k from new with plenty of history too back it up. I had it painted by a good friend of mine an it was finished in frozen white which i think is much fresher an brighter then diamond white.The engine i have came from another mate (cossiedrift) out of a saff he broke the engine is freshly built with all new pistons etc so be nice an strong i hope. all comments welcomed good an bad i do as much of the work myself all fabrication an welding.
TT T38 Power
Is that a standard cossie Rad you have fitted ?
Hope this helps.
Steve
Liking this a lot.
Should be fun
Should be fun
It was running a 2.3 axle with a Capri LSD but with the 3.44 ratio. Never suffered too bad from tramp but it had solid void bushes and every bush i could replace was. You could get all the bushes springs etc from Rallye Design. Also they did a 280mm vented disc kit for the M16 caliper. I had discs on the rear as well.
Hope this helps.
Steve
Hope this helps.
Steve
TT T38 Power
Only asked about the Rad as i had a cosworth one cut down to fit, but it looks like you have made the chassies wider so you could fit a standard size cossie Rad.
What are you doing fuel tank wise ?
Steve
Live long and prosper!!
More undates please
I done the same chassis mods to my mk3 but limited room dont allow for a 500 type cooler unless the front end appearance changes alot
Keep it up there are a few of us who could make your conversion easier due to doing it beforeAny questions either Steve or myself can help ya
Paul
Paul
TT T38 Power
More undates please
Paul
Paul
I would of had it but no place to store it
Steve
JK12
33
26-04-2021 12:09 PM
