The Nisfo Primera Cosworth Build thread
#41
The more turbos,more fun!
Goyt Road i found it, then the day after i saw you giving it some shit up the street threw marple into high lane, i was in my works van so couldnt even give you a run for your money
#50
Got car back today from a full service all sensors changed and new mad leads, and thought I would put some new silicon hoses on and new air filter,
Looks well
Looks well
#54
T34.63 at the moment matey but it's boosting on its limit at over 2 bar, hence I need a bigger turbo to handle the 83lbs injectors
#59
Thanks guys tbh I've only seen very few saphs at the most in the Stockport area, couple of white, one grey, one moonstone and one magenta.
And I always see them going the opposite way and not in my car
Would be nice to see other performance fords to have a nosy at
#62
just thought i'd update the thread with the recent drama
had the engine quit on me recently and pulled it apart to find this.
Hole in the valve, hole in no2 the piston, and started to melt no 3 piston plus it had a chip missing off the crown,
Inlet gasket looks was the cause, it had split :-( and fired out the side.
luckily the rest was checked and not scored the bores, crank was ok and everything else was fine.
#63
sent the engine off to be rebuilt by none other than the wizard dave pritchard on here.
all new bits put in and ready to go back in
bottom pulley was cracked so need to source another one, if anyone can help me out on that, that would be superb
the car looking sorry for itself ready to be risen from the ashes
also the car is getting converted to RWD as the 4x4 transmission is on borrowed time.
so looking forward to that.
#67
when i last rebuilt it i used genuine gaskets, so never going down that route again, all cosmetic now so should be ok.
was thinking of turning up to pod in a full burker when its done
JoeyBoyden
04-01-2024 02:36 PM
09-10-2015 07:38 PM
