big powered cosworth YB,
who has what BHP and what spec?
sorry if its a repost but intresting to see who is running high BHP and torque and what set up they use and how it performs?
engine, box, diffs etc?
TT T38 Power
Mine is
Light head porting, AB07 inlet cam, standard exhaust cam, Turbo Technics T38 Turbo, small turbo escort cosworth inlet manifold + throttle body, 7.8.1 comp, 2wd exhaust manifold, Spec-R bar and plate intercooler, 83lb injectors, L8 ECU and live mapped by Turbosystems.
The car is also fitted with 330mm front brakes, 300mm rear brakes, rebuilt T5 gearbox, Alcon 6 paddle clutch, Gripper Diff, Koni's all round, polybushed etc
Steve
Steve
Happily retired
Mine is 2150cc :
Spec-R Intercooler : M.A.Development Breather System : 3.5" Stainless Exhaust
Water Injection : Primary Design manifold : Oil-Cooler : Pace Dry Sump system
Nitrous
Highpower 200bhp Direct-port system : Nitrogen 'push' system : Powermax controller
Transmission
Tremec TKO 600 : PRO 5.0 Quick Shift : Hydraulic triple plate clutch
You ask how it performs - goes well
Engine Specification
2150cc 16V : Nikasil linered block : 8.5 : 1 CP pistons : Arrow con-rods : Arrow crank
Double length head studs:Baffled sump :custom Head gasket :High pressure oil pump
Gas flowed and ported head : M.A.Development custom cams : RS500 Throttle body
Automotive fuel pump : 15v accuvolt : Tial External wastegate : GTX4202 Turbo2150cc 16V : Nikasil linered block : 8.5 : 1 CP pistons : Arrow con-rods : Arrow crank
Nitrous
Transmission
Differential
Jaguar 10.5" Power Loc Diff : 3.54 cwp
Brakes/Wheels
330mm discs/6pot calipers - Front : 300mm discs /4x4 calipers - Rear : Up-rated Pads
17" Speedline Corse fitted 205/40/17 Toyo 888 - Front
18" Speedline Corse fitted 235/40/18 Toyo 888 - Rear
Suspension
Leda/BAD modified height/rate adjustable coilovers - Front/Rear : Zoo Motorsport rear beam kit
Connector Rails : Custom prop-shaft : Custom drive-Shafts : Anti-dip springs on rearJaguar 10.5" Power Loc Diff : 3.54 cwp
Brakes/Wheels
Suspension
Mine is 2150cc :
Nitrous
Transmission
Nitrous
Transmission
Differential
Brakes/Wheels
Suspension
Brakes/Wheels
Suspension
First time i've seen a break down on your Spec Rodders, very nice indeed bud..
It works pretty well too...
Happily retired
This was on a GT42 so we have more Power at the topend now on the GTX4202, we guess at 860 ish but its enough anyway.
The GTX42 on the car a tight fit
Jesus christ Rod! What that without the gas? I'm guessing yes.
you may want to machine the block for long studs
standard comp
worked head if funds allow
Siemens 83's injectors
standard bottom end but machine the pistons for valve pockets
change the inlet cam for a bd14
decent inlet, you might get away with a 4x4 with spacer, if not hart or similar
choice of turbos IMO, t38, or gt3071, or whatever your tuner decides is best.
TT T38 Power
standard block
standard comp
standard comp
Steve
Not an AB07 Steve?
Happily retired
Yes !!
The gas potential is 200 jets 'pushed' with Nitrogen, the experts tell me at 2.9bar thats around 300bhp. We cant risk all of that but engine with ignition taken out & a tad less boost with 100 jets should see around 920bhp its what we will risk down Brunters. Its either 215mph or a big bang .
Yes !!
Awsome! Your car is insane!
I have just built the following for my MKII Escort..........I'm after 350 what do you think ?
RS500 Block - 6 x Long Studs
RS500 Standard Head
Cams - BD14 Inlet & Standard Ex
55lb Seimens (only running x4)
Arrows Crank & H-Section Rods
Cosworth Pistons 8:1 Comp (Valve Cuts)
T34 63
ProAlloy Intercooler
Am I on the right track..........and what degrees do you time your cams ?
Inlet 114 & Ex 110 ?
Many thanks
RS500 Standard Head
T34 63
Many thanks
RS500 Standard Head
T34 63
Many thanks
RS500 Standard Head
T34 63
Many thanks
Martin
Thanks Martin............yes, Engine already built and ready to be dropped in - just waiting to buy a new 6 paddle AP Clutch. So everything mentioned is already a goer !!!
I have tried to over engineer everything to gain some reliability.........as I also plan to do some Track Days etc.
The idea behind the Internals was just in case I decided to chase some bigger power in the future.
So, 350 looks realistic so far ?
Think the only thing that would hold back that spec is the T34 .... But sure if you get it mapped and dont mind running a good amount of boost it will run 400+bhp as had 412bhp from one but was built as a round town toy
What sort of P.S.I. do I need to run............????
That's one part I'm unsure about - any advise would be great.
Guessing I need to run the thing in first - do you do this on a lower boost and then increase once this process is complete ????
