zvh problems
Old Oct 6, 2011 | 05:13 PM
HirenRS's Avatar
HirenRS
turbovh
Default zvh problems
just built a 1.8 zvh finished it all up wnet to start and it wont go, i brlive its a timing problem, i have tried to line it up using the woodruff key on the crank pulley to the middle notch that it casted into oil pump as this is the only mark i can see :\ ...... i have tried turning and it turns without knocking i havenot bent any valves as a compression test confirmed this, it was a 1.6 rs turbo and i bolted a ready converted running zvh bottonm end on with the correct tensioner etc etc....
any how....
when i turn the key there is spark and fuel i hear a few pops and bangs out of the exhaust sounds like it wants to go just will not catch,
i replaced the wire plug connector to the cps could i have put the wires on the wrong way that could e causing this?
anyone timed a 1.8 zvh and how did you do it? i am using the arrow on the cam and lining it to the hole on the head where all valves are shut, i am using a cvh crank pulley aswell and do not have a zetec pulley or cover to try and find marks from
Old Oct 6, 2011 | 05:47 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
This is in the wrong section m8 better off putting it in the escort rs turbo section not the resto section!!!
Old Oct 6, 2011 | 06:40 PM
luke19790_3's Avatar
luke19790_3
did you mark the true tdc when you built the engine? but it should run even if its close
Old Oct 7, 2011 | 11:18 AM
HirenRS's Avatar
HirenRS
turbovh
did not mark tdc but thought i could use the woodruff key as a guide....the car pops and bangs like it wants to go sounds like a few of the cylinders fire up evry now and then even tried tow strating it but no luck
Old Oct 7, 2011 | 11:45 AM
1223456's Avatar
1223456
double check firing order just in case,
get a screwdriver down the plug hole to confirm tdc
give sitech a ring
Old Oct 7, 2011 | 08:27 PM
frsjon's Avatar
frsjon
the wires the wrong way round on the cps wont make it work at all so if your getting fuel and a spark its not that. does sound like a timing issue or firing order wrong,did the head come apart at all? cam change? was the car sat along time during the conversion? as it old petrol? we had probs caused buy petrol after sitting for about 4 months..
Old Oct 7, 2011 | 08:52 PM
HirenRS's Avatar
HirenRS
turbovh
i though so the wires had been put on the wrong way initially but had no spark so i switched them back over and it sparked up nicely, the firing order is most definately correct its a efi and is numbered on the coil pack, the flywheel was also fitted correctly as it only goes on one way, i used a frst flywheel with a zetec cps and holder becuase the cvh one goes to far in and catches flywheel, the head came off and wasnt touched not taken apart anyway only exhasut ports cleaned for carbon using a wirewool, the ilet manifold and throttle remained as they were the turbo is spinning fine the car was only sitting for about 3 weeks since the rs turbo cvh went knocky and was removed and it had fresh petrol poured into it as it was low.....i have done several compression tests and all read 8.6bar which is a bit higher than i was expecting howeevr i did this for sake of checking valves were not bent..
Old Oct 9, 2011 | 03:54 PM
HirenRS's Avatar
HirenRS
turbovh
Default starting it up
still trying to figure this one out getting on my nerves i tried adjusting the timing again went a bit forward a bit backward to see if it made any difference turned by hand every time to make sure it never seized up, still wont start pops and bangs every now and then jus wont run i beginning to think it might be other thing now, the car was parked for 3 weeks and was running before stripping the cvh engine out then bought a built zvh bottom end running and put my head on using a copper blanking plate and a head gasket, there is spark and fuel and as i said it pops like its going to start every now and then....anyone got a ofab ecu i could plug into it round the herts area?
Old Oct 9, 2011 | 05:54 PM
HirenRS's Avatar
HirenRS
turbovh
Any suggestions this is doing my nut in
Old Oct 9, 2011 | 06:16 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
if the leads are correct and sparking they must be good
if it coughts are tries then maybe its just working the cold start therefore try starting with the flap do
its it efi?
i know you say cps but i dunno what you may have done/made
Old Oct 9, 2011 | 11:42 PM
HirenRS's Avatar
HirenRS
turbovh
its it efi?
it does coughs when i turn it over once evry now and then it is efi using rs turbo flywheel and a converted zvh bottom end which came out of a running motor, the cps connector plug got smashed so it was simply cut and replaced for the same connector plug of a mondeo same pin...dunno wat it could be mayb ecu now im convinced the edis works as i got spark fuel etc
Old Oct 9, 2011 | 11:44 PM
HirenRS's Avatar
HirenRS
turbovh
p.s the leads are definately on the right way, efi the coilpack is numbered and ive gone of that so cant be wrong made sure a bilion times!!
Old Oct 10, 2011 | 11:06 AM
HirenRS's Avatar
HirenRS
turbovh
could my flywheel be 180 degrees out ? im pretty sure the rs turbo flywheel efi only fits on one way on the zetec crank? if im a 180 degrees out and try leads 1and 4 were 2 and 3 are meant to be?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
davidfordrs
Sep 21, 2015 04:23 AM
