BIG TURBO'd focus 'RS' is now back home!! :D
Finally finished after 3 years!! with a big thanks to garry plant from GR Performance in rotherham!
GR performance custom Petrol tank in boot
Battery in boot
2x bosch 044 fuel pumps
1x 4.0 jag fuel pump used as lift pump
1.5litre swirl pot
Blitz intercooler
Mocal oil cooler and turbo aftercooler
Gr performance inlet manifold
12mm bosch ISCV (for anti-lag)
GR performance "full race" exhsaust manifold
Gt35/40r turbo
Tial 44mm external wastegate
Blitz boost controler
Gr performance twin side exit exhaust system
Cgi closed deck block
Shot peened crank
I beam rods
Cp racing pistons
Custom spec head
Custom spec cams
Custom boost pipes
Stack dash with custom Carbon surround
Knock link pro
inovite wide band
Dta S60 engine managment "with 2 switchable maps"
Gr performance wiring loom
Fuel lab fuel pressure regulator
Siemens 83lb injectors will get replaced with injector dynamics 1200cc ones after its run-in
nortech oil return
group A air filter
fog lights removed
HID headlight conversion
pollybushed all round
std shocks with H&R springs
graphite wheels
removed front crash bar
front splitter
oil cooler bypass water pipe
underdrive belt kit
modified alternator (digital regulator changed for analog reg)
removed A/C and used smaller drive belt
GR performance heat shield (front pannel)
75deg thermostat
inline water temp sensor for stack dash
inline turbo oil feed filter
avon ZZ3 tyres
mods still to do.....
activate antilag on map 2
9" wide wheels (when i find some i like)
KA sport rear stub axle spacers
front and rear strut braces to fabricate
dog engagment box from quaiffe
vids
http://www.youtube.com/watch?v=Ebu8FnToaNg
http://www.youtube.com/watch?v=twATlDXhDKc
http://www.youtube.com/watch?v=Axlft9TGzeY
Battery in boot
1.5litre swirl pot
Blitz intercooler
Gt35/40r turbo
Shot peened crank
I beam rods
Cp racing pistons
Custom spec head
Custom spec cams
Custom boost pipes
Knock link pro
inovite wide band
nortech oil return
group A air filter
fog lights removed
graphite wheels
front splitter
underdrive belt kit
75deg thermostat
avon ZZ3 tyres
vids
power we will just have to wait and see what it makes..
i will be runing 2 bar boost on 2nd map,
so that spec... with a GT35 ramming 2 bar boost in,
could be anywhere between 500-600
its getting mapped this week, and then a final live map on the road with me driving to make sure it drives nice,
i ran it in other week and it was as happy been sat in traffic as it was when it was std so this made me happy as i have been worrying all along if it would be a pig to drive in traffic
Thats the nuts. Pretty much what I'm doing to mine (and then some). Will have to pop up and have a look. Any pics of fuel set up?
Looks really nice that does i bet it go's some to.
Im not sure mate but the fuel pressure reg looks the same as one my mate had on his cosworth and when we took it to msd for a live map they said that the fuel pressue didn't rise when the car came on boost causing it to run dangerously lean. Just thought id let you know so you can check it so you dont melt your engine.
Cheers Bram
Cheers Bram
cheers
me too mate, i cant wait
i'm after some 9j comps th's when funds allow lol
thanks
thanks
I ant got more pic of the build mate as i use to have them all on facebook and i got banned of facebook so cant access them
It is an animal!
3rd-4th-5th are all over before you realise whats happening!
It is an animal!
main caps are the ones that were supplied with the CGI block
and std oil pump, i'm not revving it past 7500 so no need for a billet one
Stock mains by the sound of it then and the oil pumps don't break just because they go over 7,500rpm Have you kept the stock FRS crank damper? What flywheel? (sorry if all this has already been mentioned). It looks like it's making good power anyway
Main caps will be stock... For the cgi block
No damper,
Std flywheel skimmed off 3mm
All balanced
