BIG TURBO'd focus 'RS' is now back home!! :D
Old 03-01-2012, 06:53 PM
  #81
robp-tt
ZETEC TURBO
robp-tt's Avatar
lookin foward to how the oil pump goes, still in two minds if i should drysump mine keep it standard
Old 03-01-2012, 07:48 PM
  #82
TommyB
Boosted 122 cu in
TommyB's Avatar
What's the reason for the turbo change?
Old 03-01-2012, 08:40 PM
  #83
Rollinz
Rollinz's Avatar
Hopeing the oil pump is a good en lol, dont want no failures,
Also looking into fabbing up a baffled sump using rubber baffles from a bmw m3'
The reason for the turbo change is when we got the gt35 to 1.7 bar we where getting valve float, so altho i am having mods to try and eliminate that iv been worrying about what if i still cant get the gt35 into its prime efficiency range, so by opting for a gtx30 the turbo has a much more efficiency range and can still produce the same power as the gt35 would have (if the engine will swallow it)
Does that make sense? Lol
I dont know if i will get any earlier spool, maybe 100-200 rpm as the gtx has a heavy billet compressor but the torque produced should be more interesting
Old 03-01-2012, 09:02 PM
  #84
nevsrevs
nevsrevs's Avatar
fingers crossed on the oil pump, its all down to luck.
Old 10-01-2012, 05:37 PM
  #85
Robs Frst
Robs Frst's Avatar
Suscribed, should go well
Will good to have a look at this one when your next have it down.
Old 12-01-2012, 08:54 PM
  #86
Rollinz
Rollinz's Avatar
Head should be back from ian howel end of next week ,
Undesided on a gtx30 now .... :/ maybe regretting sellin my gt35.... Gggrrr
Old 12-01-2012, 09:15 PM
  #87
nevsrevs
nevsrevs's Avatar
spoke to ian last night, said he was finishing your head, why the turbo?
Old 12-01-2012, 09:30 PM
  #88
Rollinz
Rollinz's Avatar
Worried about getting surge if it starts to spool too early lol,
I know the 35 wirked and worked well..... Jus need that extra .3 bar
Old 13-01-2012, 04:51 PM
  #89
nevsrevs
nevsrevs's Avatar
only 1 way to find out!
Old 14-01-2012, 10:12 AM
  #90
Rollinz
Rollinz's Avatar
Well past few days ive been in a massive dilema as to what turbo i actually buy for the focus... Well this morning ive bit the bullet and made my mind,
A billet wheel'd garret gt35..
Basically same as my old turbo but with a cnc'd billet compressor wheel... 720 horses anyone??? Lol
Also ordered a methanol tank
Should be fun,
Old 14-01-2012, 01:52 PM
  #91
jonfoc
jonfoc's Avatar
Hahahaha I knew you'd go back. Whats this about a methanol tank? Are you that worried?
Old 14-01-2012, 02:48 PM
  #92
Rollinz
Rollinz's Avatar
Just to keep detonation at bay jon, may be somthing for you to consider??
Can ramp loads of advance timing in to get turbo to spool quicker,
with a bit of meth spray to stop det occuring,
Also can spray some in when temps get high to aid cooling,
Old 14-01-2012, 03:33 PM
  #93
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
Should be fun,
so youve gone for the gtx35 then lol , i went up to see ian last night and we was talking about you having problems etc and i can only see you having valve float by not having the correct poundage springs fitted to the head , ian also stated that harvey gibbs has had trouble with the gtx range of turbos surging there tits off on cossie engines so i wish you all the best and hope everything goes ok
keep up the good work
cheers paul
Old 14-01-2012, 04:45 PM
  #94
Rollinz
Rollinz's Avatar
cheers paul
yes spoke to ian about harveys findings too...
But!! And i must say this is my own opinion non of other peoples so i hold my self responsable if it fails... Lol
With the last 35 we had no problems (only valvefloat) which i hope ians double spring will eliminate. So with going for this turbo its also got antisurge where my old one didnt... So fingers crossed it will work lol,
If not... Just going to get to what its happy at on that set up and thats it cause got twins due next month and that will be 4 sprogs lol so not going to have the money to spend on it which i do now.... Lol
Old 14-01-2012, 08:17 PM
  #95
jonfoc
jonfoc's Avatar
You sure youre going to need it pal? Has Gaz rec'd it? I was chatting to gaz about mapping the other day and he was against water inj, yeah I know its different. I'm running vvt so it may be an after thought to get a quicker spool if 1st option isn't good enough.
When you getting ya new turbo?
Old 14-01-2012, 08:42 PM
  #96
zetaboostboy522bhp
good luck mate with the turbo and i know ians head will sort the valve float issues out as i never had any issues with my head at 30 psi , hope everything goes ok with the new kids
cheers paul
Old 15-01-2012, 07:25 AM
  #97
Rollinz
Rollinz's Avatar
Gaz was talking about me running full meth!! Lol
But my car IS just a toy,
Turbo is the one off gaz's evo,
Old 15-01-2012, 07:26 AM
  #98
Rollinz
Rollinz's Avatar
cheers paul
Fingers crossed mate
And thanks :thumbsup:
Old 04-02-2012, 07:43 PM
  #99
Rollinz
Rollinz's Avatar
ok, so small update..
turbo gtx35 CHECK
injectors still need to order...
spoke to ian this week i should have the head with double spring conversion back by next week,
next big thing.... ive sold... spoiler, boot lid, front wings, and front bumper......
and ordered a 2003 WRC front bumper, front wings, and spoiler
when complete i plan on a FULL WRC printed wrap like this car.. except changing the BP sponsers to GR PERFORMACE
Old 04-02-2012, 07:55 PM
  #100
nevsrevs
nevsrevs's Avatar
bet your going to be over the moon with the head, never delt with someone in this trade as genuine as ian, cant wait for this engine to be on the dyno again,
Old 04-02-2012, 08:02 PM
  #101
Rollinz
Rollinz's Avatar
me too
cant wait for it all actually,
engine back together, and get kit fitted,
and thats this year money spending done.. going to enjoy it!
next year... tractive sequential gearbox and a rear half cage
Old 05-02-2012, 01:34 PM
  #102
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
I run a set of single valve springs at 2bar no problems :/ ive seen the same set run at 2.3 bar also
Old 05-02-2012, 01:47 PM
  #103
Rollinz
Rollinz's Avatar
On a Gt35??
Maybe down to cam choice too?
Old 05-02-2012, 05:47 PM
  #104
jonny s2
jonny s2's Avatar
cant wait to see the wrc kit, think it will look fantastic
Old 26-02-2012, 06:22 PM
  #105
Rollinz
Rollinz's Avatar
Just been and collected the kit, much better than i was expecting tbh with it been fibreglass,
Cant wait to get it all on
Spoiler
Bumper & wings
Old 26-02-2012, 09:01 PM
  #106
stevealien
stevealien's Avatar
good stuff rich,you truly are a loon lol.
what colour you gonna paint the car then??
white with all the rally graphics????
Old 26-02-2012, 09:23 PM
  #107
COLEYST200
COLEYST200's Avatar
Looking good mate have a look at my FOCOS im building iv got the same kit on it as your going to be using
Old 27-02-2012, 07:03 AM
  #108
Rollinz
Rollinz's Avatar
Got a link to the thread mate i will definatly take a look,
Steve
Its staying blue but having a complete white/green/black wrc car wrap
Old 27-02-2012, 07:04 AM
  #109
Rollinz
Rollinz's Avatar
Steve
Old 27-02-2012, 07:15 AM
  #110
Rollinz
Rollinz's Avatar
Steve
Old 27-02-2012, 08:05 AM
  #111
Minirotty
Lucifer II - 666
Minirotty's Avatar
This is Ian's FOCOS build bud, yours is looking good Rollinz!
https://passionford.com/forum/restor...fuel-tank.html
Old 27-02-2012, 03:19 PM
  #112
Rollinz
Rollinz's Avatar
The focos build looks epic
I want somthing similar to that to mount my front bumper
Old 05-03-2012, 06:14 PM
  #113
Rollinz
Rollinz's Avatar
Well today i decided to get some work done on the car,
After half an hour i ended up with this
An hour later left me with this
So all ready for tomorrow to rip it to pieces and change oil pump and then fit the head and slot it back in the car,
While its in bits i thought i would take a few pics of my inlet manifold as i know a few people were interested in it,
Bottom
Top
Tb angle
And the best pic i could get showing the cnc machined velocity stacks
Old 05-03-2012, 07:07 PM
  #114
nevsrevs
nevsrevs's Avatar
what you doing with your oil pump mate?
Old 05-03-2012, 07:20 PM
  #115
hogdog
hogdog's Avatar
I've done alot of research in building my own inlet so I know that's going to be really helping produce the numbers, a very efficient design.
Is that the ICV or a sensor?
Old 06-03-2012, 06:22 AM
  #116
Rollinz
Rollinz's Avatar
Fitting a billet steel one mate, so i can rev to 8500
Under the inlet is a double sensor , air temp and 4 bar map,
I run a remote bosch 12mm stepper motor for als/icv
Old 06-03-2012, 06:31 AM
  #117
Rsmat
300+
PassionFord Gold Member (Male)
Rsmat's Avatar
Looking good mate.
Old 06-03-2012, 04:59 PM
  #118
Rollinz
Rollinz's Avatar
Well what a cr4p day ive had,*
I was hoping to at least of had the engine back in the car tonight but everything was against me from the start,*
The day started ok,
Engine with oil pump removed
Std oil pump and billet steel oil pump
New oil pump fitted
And then things just went wrong,*
Firstly the crank seal i had was wrong, so ordered another with thanks to steveB giving me some part numbers,*
Ordered 1 from my loal motor factors for it to turn up at 3-30 and still be wrong
While i was waiting for that seal i re-fitted the sump and then went to fit the head,*
Got the head gasket out of the packet to find only 3 layers *
I needed a 4 layer headgasket (1mm) so couldnt even fit the head!!
So well pee'd off today, cant work on it now till next monday,*
Some random pics of the engine
My oil cooler/thermostat setup
And how its now stood waiting for me till monday
Old 06-03-2012, 06:33 PM
  #119
nevsrevs
nevsrevs's Avatar
gutted, is that a low pressure switch on the sandwich plate? have you got your head back yet, if yes get some pics up
Old 06-03-2012, 07:20 PM
  #120
Rollinz
Rollinz's Avatar
Yes mate got the head back, went over to ians on sunday to collect it,
Will get pics of that as i build engine up lol
The 2 sandwich plates house a 110 degree thermostat, and the sender units are oil pressure and oil temp for the stack dash,
Quick Reply: BIG TURBO'd focus 'RS' is now back home!! :D
