Focus 2.0 Zetec Turbo Build
#54
sorry, what has been done to the block?
what is the size of the current block in the car and what will be happening with it when the new engine is fitted??
i may be interested in it and any spare parts that you didnt use from the 2nd engine
#55
PassionBMW.com Member
My missus stole my digi cam, so I am round ehrs now and will take some pics later today
Adam, the engine it is replacing is a 2.0 Focus motor (like for like almost), and wll quiet possibly be up for sale, I'll ask Josh, I know he has a 2.0 Mondeo engine for sale.
The block was bored to 0.5mm oversize, honed, faces machined, front breather removed and blocked, turbo oil return fitted and a breather port put in the back
#58
![](https://img.photobucket.com/albums/0703/philm/zetecs/DSCF0782.jpg)
Oil pump fitted, all bolts now torqued up on the bottom end, also rear oil seal and housing fitted
![Name: DSCF0790.jpg
Size: 41.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100468d1501884623-focus-2-0-zetec-turbo-build-dscf0790.jpg)
Steel Rods, ARP bolts, Piston Oil Spray Jets and lovely Forged Pistons
#65
![](https://img.photobucket.com/albums/0703/philm/zetecs/DSCF0794.jpg)
Lower crank case and headgasket fitted (3 layer metal)
![Name: DSCF0797.jpg
Size: 39.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100469d1501884623-focus-2-0-zetec-turbo-build-dscf0797.jpg)
Head fitted (standard ports!)
Tommorow, run to Ford to pick up a gasket they didnt put in the gasket kits, sump pan on, waterpump on, time her up and thats about job done
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#67
![Name: P1010070.jpg
Size: 57.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100470d1501884623-focus-2-0-zetec-turbo-build-p1010070.jpg)
Cams in and torqued down - note the Focus' massive external waterpump
![Name: P1010067.jpg
Size: 56.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100471d1501884623-focus-2-0-zetec-turbo-build-p1010067.jpg)
Timing belt fitted and tensioned
![Name: P1010074.jpg
Size: 60.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100472d1501884623-focus-2-0-zetec-turbo-build-p1010074.jpg)
Cam cover layed in place, it's about to go off to be powdercoated
![Name: P1010075.jpg
Size: 56.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100473d1501884623-focus-2-0-zetec-turbo-build-p1010075.jpg)
Food for thought? Perhaps a future project using a Duratec ST170 head, with it's massive valves, massive ports and VVT?
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Name: P1010076.jpg
Size: 48.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100474d1501884623-focus-2-0-zetec-turbo-build-p1010076.jpg)
#69
Not 100% sure. I should have the ECU this weekend, need to spend a few hours with wiring.
The car can be delivered any time, Its a case of, I have exams at the mo, and need my own car MOTd, so that kinda takes semi priority....we shall see, hopefully it'll be at Ford Fair though
(Not fully mapped/run in though)
#70
EXCELLENT work here phil....did you manage to do some more research regarding the st170 head and fitting? as i remember when we last spoke you were a bit unsure about the ins and outs of it...
we can chat on messenger if you like
bassboy
bassboy
#73
#75
300+bhp mate ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Tech spec's :
205 BHP + 50 BHP shot of NOS
0 - 60 in 6 seconds.
Now this focus is supercharge'd, turbo'd and nitrous'd
Turbo : Garret T3
supercharger : jackson racing charger with 16psi pully
#77
Is that Ruth's black Power Engineering Focus? Lovely car that
Excursion,
....will be looking into that more shortly I think ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Excursion,
#78
Not really too good of a engine to turbo mate, would stick with the standard 2ltr block tbh
#79
Bulletin Board User
