mk4 escos 4x4 pic update 1st/9/07
Old 23-01-2005, 08:24 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
Default mk4 escos 4x4 pic update 1st/9/07
Old 23-01-2005, 08:35 PM
Lloyd
Lloyd's Avatar
Old 23-01-2005, 08:39 PM
Lloyd
Lloyd's Avatar
Old 23-01-2005, 08:44 PM
Dean Saff
Dean Saff's Avatar
Good work so far..
But how do you get in and out of that garage door...
Old 23-01-2005, 08:50 PM
david
david's Avatar
Looks excellent lloyd, will be a weapon once its done
Old 23-01-2005, 08:52 PM
Lloyd
Lloyd's Avatar
the chap i got it from told me it was a mega bling sunroof i was going to fit it next week
Old 23-01-2005, 09:07 PM
dave cos4x4
dave cos4x4's Avatar
how long lloyd till its done.
Dave.
Old 23-01-2005, 09:13 PM
Lloyd
Lloyd's Avatar
it depends on how much time i can get off work to finish it 4 to 6 weeks at the most
Old 23-01-2005, 09:17 PM
dave cos4x4
not long then.
whats its first outing.
Dave.
Old 23-01-2005, 09:23 PM
Lloyd
Lloyd's Avatar
pts at luton with the central group in march,then central day at the pod on the strip am,and on the stand pm
Old 23-01-2005, 09:24 PM
SPADGE
SPADGE's Avatar
Lloyd what are you going to do about a petrol tank?
Old 23-01-2005, 09:28 PM
Rs Gus
impreza wrx sti version 8
Rs Gus's Avatar
looks mean as get some underbonnet piccys up
Ginge !
just finding my feet
Ginge !'s Avatar
on a serious note theres gonna be a few cossie mk4 escorts about soon
good luck with it mate and keep up posted
Old 23-01-2005, 09:33 PM
Lloyd
Lloyd's Avatar
spadge,when i measure the space left ,where the spare wheel well was,iam gonna get pro alloy to make me one
Old 23-01-2005, 09:34 PM
SPADGE
SPADGE's Avatar
See the thread i just started ref my tank mate! It is only 5 gallons as that is all that will fit!
Old 23-01-2005, 09:51 PM
Lloyd
Lloyd's Avatar
ive been trying to find a pic of the space for a fuel tank,i cant but its loads bigger than a standard cossy tank
Old 27-01-2005, 11:39 AM
adamS2RST
adamS2RST's Avatar
Top work.
Old 27-01-2005, 01:11 PM
Sticky.
Sticky.'s Avatar
Old 28-01-2005, 09:20 AM
Filthy Rich
Filthy Rich's Avatar
Old 28-01-2005, 09:30 AM
Old 28-01-2005, 10:21 AM
Damo V
Damo V's Avatar
How are you fitting up the rear end? cossie setup or axle?
Old 29-01-2005, 06:26 AM
Lloyd
Lloyd's Avatar
cossy rear beam is in and fitted
Old 30-01-2005, 09:44 AM
Damo V
Damo V's Avatar
nice, wouldnt mind seeing how you done it mate...
Im sure i remember seeing pics of this conversion on here or the rsbb years ago didnt I?? the barn type workshop looks familier??
Old 30-01-2005, 09:14 PM
Lloyd
Lloyd's Avatar
yes your right,it has taken nearly 3 years now .good news is i now have the r33 skyline box
Old 05-02-2005, 12:36 AM
mk1 dan
mk1 dan's Avatar
that will be a tool when are u puting more pics up keep looking at this space top job
Old 05-02-2005, 06:50 AM
Lloyd
Lloyd's Avatar
Old 05-02-2005, 06:56 AM
Lloyd
Lloyd's Avatar
Old 05-02-2005, 07:29 AM
Lovin that
Old 05-02-2005, 08:47 AM
Blakey
Blakey's Avatar
Did you build yours in a similar way to how i did mine? (see link.) How are you getting on and are you happy with the work so far, will be starting back on mine in the summer.
https://passionford.com/forum/viewto...er=asc&start=0
Old 06-02-2005, 09:45 PM
Lloyd
Lloyd's Avatar
yes thats how mine was done. and that was the easy bit the rear end is the hard part. brom at zoo makes some nice cos adjustable rear suspension.with a few plates welded in it should be easy to fit a cos rear suspension
Old 07-02-2005, 03:35 PM
Blakey
Blakey's Avatar
how did you do the rear if you dont mind me asking, i was hoping that was going to be easier than the front. have you got anymore pics?
Old 07-02-2005, 07:49 PM
Lloyd
Lloyd's Avatar
if you put the cos rear beam under your escort, you will find that none of the mounting points are near the chassis,i cut out the sierra rear chassis and overlayed it onto the escort,then plated all the gaps.i used 2mm steel plate at the cosworth mounting points.i have some pics but they are too blurred to post.
Old 07-02-2005, 10:08 PM
mk1 dan
mk1 dan's Avatar
very nice just blewn my escort up put a hole in number 1 piston shit happens
Old 09-02-2005, 07:47 PM
Blakey
Blakey's Avatar
lloyd, thats what i had intended to do, i still have the rear mounts for the rear beam from the sierra. thanks for the help mate.
Old 09-02-2005, 08:51 PM
luke89
Team HOTHOT!
luke89's Avatar
looks good so far mate how much left to do ?
Old 10-02-2005, 05:50 AM
Lloyd
Lloyd's Avatar
what shocks are you fitting? coilovers or springs?when are you going to fit the rear chassis? as there are loads of problems.i can save you lots of work my car will be at central day at the pod in april,i can then explain what you will need to do
Old 10-02-2005, 05:52 AM
Lloyd
Lloyd's Avatar
luke,the engine and skyline box are being fitted next monday
Old 10-02-2005, 05:56 AM
Lloyd
Lloyd's Avatar
oh nearly forgot,you will also have to alter the rear inner sill to get clerance for the rear beam
Old 10-02-2005, 11:28 AM
Sticky.
Sticky.'s Avatar
Looking good mate
Old 13-02-2005, 08:35 PM
Lloyd
Lloyd's Avatar
now have a quaif front diff
Quick Reply: mk4 escos 4x4 pic update 1st/9/07
