engine conversion
Old Jul 14, 2010 | 04:37 PM
lee*viper's Avatar
lee*viper
Default engine conversion
hi folks just wondererd if anyone can help me i want to convert my rs turbo s1 from mfi to efi please could you tell me what is involved or email me and is it worth while as i escort p reg 1600 zetec car complete and would gearbox fit straight on to the cvh engine and drive shafts along with the clutch thanks everyone
Old Jul 14, 2010 | 06:30 PM
escort1989uk's Avatar
escort1989uk
It's up to you!!
List of parts!
Ofab ecu
Ofab loom
Air charge sensor
coolant sensor
fuel pressure regulator
fuel rail
plastic fuel feed line that screws into fuel rail! ( a must to avoid the bodge jubilee clipped fuel lines!! )
efi throttle body
efi throttle sensor
coil pack
coil pack mount
distributor blank for the head
fuel potentiometer
efi amal valve
1800 sierra crank sensor, bracket, alternator pulley, alternator bracket, and crank pulley!
Someone to fit it all!!
there you go that s one way to do it been done many times so lots of info on here you will need a few relays to
Old Jul 14, 2010 | 06:31 PM
escort1989uk
and you have to have the sierra bit machined down
Old Jul 14, 2010 | 06:42 PM
lee*viper's Avatar
lee*viper
many thanks for the info on conversion but it may be out of my league is there any way wou could simplefy it in laymen terms
Old Jul 14, 2010 | 06:46 PM
escort1989uk
its easy really you need all the parts froma the fiesta turbo then you use the sierra 1.8 cvh 1800 sierra crank sensor, bracket, alternator pulley, alternator bracket, and crank pulley! you the ofab llom and wire it into the fuse box wiv a few relays job done if your not that machnical somone one here may help you fit it all with a little beer money
Old Jul 14, 2010 | 07:08 PM
lee*viper's Avatar
lee*viper
would buy anyone a good drink if anyone could give me a step by step account on what to do you make it sound easy any help would be a god send
Old Jul 15, 2010 | 06:17 PM
luke89's Avatar
luke89
Team HOTHOT!
just to add to escort1989uk u will need an efi inlet or have ur mfi one modded to take injecters, ur also need an adapter plate ( mfi head dosnt have injecter cut outs )
do a search on here there are loads of escorts been changed to efi with full write up and picks
Old Jul 15, 2010 | 06:47 PM
conor.rst's Avatar
conor.rst
Depends what your budget is ? you could always have somone els fit it.
Old Jul 15, 2010 | 09:14 PM
escort1989uk
think jano still sell the efi inlet to mfi conversion plates needed
Kyle Langford
27
Aug 5, 2019 07:54 PM
mint_s2
Sep 2, 2015 08:58 AM
