Looks like it may be complete soon
Old 08-06-2010 | 08:06 AM
  #201
34CHASSIS's Avatar
34CHASSIS
Originally Posted by MadRod
With the wing removed an Escort Cosworth is much the same as a Saff. Both require circa 700/720 horses to pull 200mph in the confines of Brunters with resonably correct gearing.
so my v8 twin turbo escort should do it ,do you think
Old 08-06-2010 | 08:43 AM
  #202
Chip's Avatar
Chip
*** Sierra RS Custard ***
What power is the v8 twin turbo?
Old 08-06-2010 | 09:04 AM
  #203
34CHASSIS's Avatar
34CHASSIS
1027
Old 08-06-2010 | 09:07 AM
  #204
Chip's Avatar
Chip
Originally Posted by 34CHASSIS
1027
Should be doing 200mph in less than a mile mate!
Is your intercooling up to the job though of keeping the power while under load?
We tested a monaro with similar power and it fell short, and it was due to intake temps.
Old 08-06-2010 | 09:20 AM
  #205
34CHASSIS's Avatar
34CHASSIS
has cooler slightly bigger than rs500 one for escort plus water injection ,whats the most it could lose power wise if it lost 200 still have 800 ,plus because it only runs 28 psi to get that figure would temps not be lower than say a yb running 38/40 psi to get 650
thanks
Old 08-06-2010 | 09:23 AM
  #206
Chip's Avatar
Chip
thanks
RS500 cooler works well for rod at that level, and as you correctly state there will likely be less of a drop off on yours if anything due to the lower boost.
So it certainly sounds like you will piss your way past 200mph, when are you planning on trying?
Rod will have a better idea of your realistic maximum speed than me, but its got to be in the 215 mph ballpark I would think if your aerodynamics is similar to a saph or escos.
(havent seen your car, do you have a link to some pics?)
Old 08-06-2010 | 09:35 AM
  #207
34CHASSIS's Avatar
34CHASSIS
its in for sale bit on here and in projects on here escort v8 twin turbo
thanks
Old 08-06-2010 | 10:44 AM
  #208
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Obviously it should do & sail on past 215mph, but to do that you have to get the gearing near optimum & keep the charge air down. If the charge air runs away the ECU will simply pull all the Power . Think that Monaro with over 1000bhp failed to reach 190 on its first try, although i thinks its done 198ish now still 15mph short of its potential. I wish you luck & any advise i can give i will.
Old 08-06-2010 | 10:53 AM
  #209
Chip's Avatar
Chip
https://passionford.com/forum/cars-f...v8-escort.html
cool project
Are you thinking of top speed testing it before you sell it then?
Or is this just a sneaky way to get people to view the ad?
Old 08-06-2010 | 11:09 AM
  #210
34CHASSIS's Avatar
34CHASSIS
cool project
i was just curious to ask if it would do it ,sorry rod didnt mean to mess with your thread ,nothig sneaky about what i have done ,credit to you rod for what you do ,i bet them speeds are scary ,
Old 08-06-2010 | 11:10 AM
  #211
whizzisat114's Avatar
whizzisat114
Nice car shame your selling it. bet it goes like stink and sounds lovely
Old 08-06-2010 | 11:24 AM
  #212
34CHASSIS's Avatar
34CHASSIS
hi could anyone wanting to comment on my car please do it on the forsale ad or thread please ,this is about rods car
thanks
Old 08-06-2010 | 01:04 PM
  #213
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
No problem bud .
Old 08-06-2010 | 01:26 PM
  #214
andy130's Avatar
andy130
rods a proper cosworth owner! in all the posts iv seen rod post not one of them did he say my old cossie is a shit/heart ach etc, like must cossie owners go on! i wish you best of luck rod i hope you break your record.
Old 08-06-2010 | 02:36 PM
  #215
Chip's Avatar
Chip
True, he certainly loves his car as much as anyone does!
Old 08-06-2010 | 04:01 PM
  #216
JonathanH's Avatar
JonathanH
Cracking build and nice meeting you yesterday Rod, cars really impressive ! We're back down Marks monday to finish the astra off so may see you if your around...
Old 08-06-2010 | 04:09 PM
  #217
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Sometimes i feel like throwing in the bin but im a determined little bugger & try to find answers to the problems that arise on such a build. Being older i dont need it finished yesterday, I sometimes just walk away & do something else the problems always seem easier after a break.
One such little problem was smoking when cold, we knew from Simon that these huge Turbos used a bit of oil but it did seeme excessive. I mentioned it to Mark so he investigated, during work elsewhere the oilfeed union had been removed & a nice new sparkly one fitted. However it did not include the restrictor so the Turbo was getting way to much oil, without taking it apart it could not be seen. That prob had an easy fix .
Still suffering from belt mis-alignment checks have shown that the Power steering pulley is very slightly out of line & needs to be moved forward about .8mm it makes a noise when cold, it will be sorted shortly. We have gone from RWD to Escort belts but its a strange one & should not need the pulley moving . 8.5K revs dictate its got to be spot bollix.
The Stack Tacho dont like the signal from the CDI & goes AWOL over 7k, will try a Tacho adaptor or try wirng it direct to the SM4, these are my today probs all of which will be sorted . Then i will go to high Boost but not before.
Old 09-06-2010 | 12:28 PM
  #218
gjh's Avatar
gjh
So this car is probably the quickest (top speed) 4 cylinder car in the UK? I rekon it could well be, good luck with the top speed run whenever it happens.
Old 09-06-2010 | 04:10 PM
  #219
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
No its second to Andy Forrest Subaru which has done 210.4 we have un-officially reached 210.2 so we should gain that title, with the extra Power .
Old 09-06-2010 | 05:30 PM
  #220
leecavturbo's Avatar
leecavturbo
sorry for the head in sand question not been on here lately.
good news on the car progress rod
is there a booked date for this 200+ run? or even a plan to?
Old 09-06-2010 | 07:33 PM
  #221
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Their are no plans whatsoever at this point. I want a mag feature about the car & its attention to detail not how fast it can hack down a runway at this point in time.
Old 09-06-2010 | 07:44 PM
  #222
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Back to ongoing jobs.
The new intercooler is mega & the WI has not yet turned on & it will probably not be required even on Topspeed runs a far cry from having the WI working when on the throttle for a few seconds. However the 2 new rads are proving to be just as mega & Mark wants them at 90 deg. On the motorway it can now drop as low as 60 . Mark has asked me to come up with a Diverter system controlled by the ECU to take 1 rad out of play untill its required.
Ordered a suitable 12v valve from the States which has the correct outlets so will fit it when it arrives. If that fails i remember my Dad putting a piece of cardboard in the air inlet that will work .
Old 09-06-2010 | 07:52 PM
  #223
robp-tt's Avatar
robp-tt
ZETEC TURBO
nice work rod, will be good to see it finished
Old 09-06-2010 | 10:24 PM
  #224
G801WAC's Avatar
G801WAC
Doing It Better
hi rod glad you getting car back on road be nice to see it in a mag again too good luck
Old 09-06-2010 | 10:56 PM
  #225
NEIL A's Avatar
NEIL A
Nice work Rod glad it all seems to be working well after so long off the road. There is a Porsche event being organised at Brunters soon that should see the fastest British cars running.
Old 11-06-2010 | 07:22 PM
  #226
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mark fitted the Turbo restrictor today & i have sorted my Chassis rail wiring thats been their since Noah now all looks neat & i even painted all the Blue/Red fittings black even though you cant see them, this is very Sad i realise but true Buftys do this sort of thing. Next job is the pully alignment problem probably early next week. Mark wants to revisit the crank sensor as hes getting dodgy readings. When these jobs are complete, Mark will dial in 2bar of boost which should be circa 700bhp so the fun should start.
Then 2.5bar . On pump thats 770bhp/838 on 109.
Old 11-06-2010 | 07:24 PM
  #227
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
If the ffs boys are there they hold Top 3 slots over 1.5miles (223, 222 & 222mph). I can only dream of their overall package .
Old 11-06-2010 | 10:24 PM
  #228
fezzajsy's Avatar
fezzajsy
Old 18-06-2010 | 12:56 PM
  #229
Zzz...Zzz's Avatar
Zzz...Zzz
I really like your ride, some quality engeneering shure is put into this car! *respect*
Old 23-06-2010 | 12:05 AM
  #230
macca33's Avatar
macca33
Old 23-06-2010 | 12:49 PM
  #231
SiZT's Avatar
SiZT
Andy Frost has also done 223 allegedly
Old 23-06-2010 | 01:17 PM
  #232
Top updates.How far are you off now Rod.
Old 24-06-2010 | 10:28 PM
  #233
pig's Avatar
pig
lovely car this,see it mad a few weeks ago when i picked mine up.a decent fella as well imo good to have a chat m8.cracking motor and awesome detail
Old 04-07-2010 | 07:53 AM
  #234
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Well
Took car to Combe its first RS show for 5 years, incredible interest from the punters & must admit it looks the best its ever done. The new centrepush hydraulic release bearing has transformed the way the car drives so im well happy. Will be at Modified Madness next weekend.
Done 1300 odd miles now & may well go to 2bar of boost in the next week or so & then run a few miles at that before going to 2.5bar. Have a mag feature in the next couple of weeks so lookinf forward to that.
Cheers Rod
Old 04-07-2010 | 09:47 AM
  #235
andy escos's Avatar
andy escos
it was good speaking to you yesterday rod your car looks mint & that black evo looks a serious bit of kit ,i had a chat with mark about yours & the evo i could,nt believe how much he spent on the cage & suspension
Old 04-07-2010 | 10:01 AM
  #236
the saint's Avatar
the saint
fair play rod she looked stunning yesterday mate
Old 04-07-2010 | 10:35 AM
  #237
Staffi's Avatar
Staffi
Echo the above, car looked fantastic Rod, i didn't get much of a chance to chat as i was talking Mark's head off for about 40mins..........
Edited to say,
Ade's car looks superb too..........
Old 04-07-2010 | 02:38 PM
  #238
gjh's Avatar
gjh
Well
Cheers Rod
Which mag? I will be buying it.
Old 04-07-2010 | 02:40 PM
  #239
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
nice to hear she is back and running well rod!
Old 07-07-2010 | 07:06 AM
  #240
MAD Ade's Avatar
MAD Ade
Edited to say,
Thanks Pete
Quick Reply: Looks like it may be complete soon
