My Project G3 RWD Escort
#45
Latest update of the engine, just need a rad, and some silicon hoses, still need a single peice propshaft, fuel lines, and the brake piping up. thats about it, cant wait till sheis on the road for sum fun.
#49
some updated photo,s for those following this project, not much to complete now, maybe youll see it in the spring, going to give the project a rest now for a while.
#51
Lucifer II - 666
Lovely car bud, defo following project and looking forward to spring updates
#57
Update the fuel pump and ancillaries are now in, 044 fuel pump genuine bosh. New aluminum battery tray, and a new battery, just installing fuel lines today, just a rad now to get running, Then onto the brake lines and prop, not far off now,
#65
NEW UPDATES AS PROMISED, NOW RUNNING, on target for summer, whats left. well! the prop is being made, ally door cards to get, manual window regulators and then THE BIG DAY FOR A RUN OUT IN HER>
#70
Just a few more pics for you all, got more if your intrested, of complete build, the spec has also changed, the engine alone now stands me at 5k, it will be worth it on my first day out in her.
#73
Love it - cracking car this - goes against the grain in a good way!
couple of small things id do if it was my car id smooth out the bottom suage line on the doors and put a slightly larger rear spoiler on it.
#75
Thats what the shell was built for, built by Denise Moody for tarmac, originally ran an EX engine, i would have had to do to many mods to the bulk head to drop a cozi in there, although that was my original idea till i seen how much more work would be involved
#76
Yea i know what you meen about the vents, will change the bonnet eventually back to the original one or a carbon one, what you think about a rear WRC boot spoiler or would that be too much
#78
Lucifer II - 666
I like the vents
#79
Had the head fully rebuilt, new guides, valves, piper double valve springs and special stem seals, mildly ported and skimmed, run it up and it seems fine at the moment but i need to take it out so i can run in properly as its had new pistons and rings need to bed everything in, but sounds awsome, will post a video on utube later thanks for the comments
