Escort MK6 Van, Zetec turbo on MS..
Old 16-10-2010 | 02:24 PM
  #41
COCHYN's Avatar
COCHYN
Looks great, needs finishing off and tidying up though. What power is it running do you think?
Old 16-10-2010 | 02:33 PM
  #42
xtrmjks's Avatar
xtrmjks
Originally Posted by bassboy
Hi mate excellent project u have there! Quick question. is that an OBX exhaust manifold? Where did you get it from?
It is OBX. Got it from America, £160, I think..
It's not "show van", it's due a tidy up, agreed! I use for work everyday.
power wise have no idea, had it on rollers while back, didn't get any real figures, due to wheelspin..I will take it on rollers again in near future..
It's running 21psi..
Old 16-10-2010 | 02:39 PM
  #43
G801WAC's Avatar
G801WAC
Doing It Better
hi yeah that is true its a good ecu very easy to understand ,i did have my escort rst running for two weeks on it at low boost using original distributor it ran quite good it was when i wanted to run it on more boost think i must have had an ignition fault in a way should have perceived with it instead tried to run it on trigger wheel and coil pack for wasted spark well done for sticking with it ,will be interesting too see what it runs bhp and toque
Old 16-10-2010 | 06:16 PM
  #44
bassboy's Avatar
bassboy
Nice one mate...any links etc of where you got it from?
Old 16-10-2010 | 06:43 PM
  #45
xrmalin's Avatar
xrmalin
Cheers pal the question is though if i hadnt of said on the other thread what engine was in it would you of known ? as i was going for the stealthy approach lol
Old 17-10-2010 | 08:45 AM
  #46
xtrmjks's Avatar
xtrmjks
I searched for "focus turbo manifold" on American e-bay...
Old 19-10-2010 | 12:08 AM
  #47
G801WAC's Avatar
G801WAC
Doing It Better
hi plenty of torque then lol sounds good too me ,can't wait to get mine mapped
Old 21-10-2010 | 04:40 PM
  #48
xtrmjks's Avatar
xtrmjks
rear discs fitted,
Thought i try and make van run cooler..and found this out!
-Rover 200 1.8D (Q&H number:QTH328) thermostat (78c) straight fit, to std zetec 88c
-Sierra mk2 2.3D (intermotor number:50012) Fan switch (86-77c), to std zetec 95-105c
..should do the job!
Fitted new thermostat and fan switch..stationary, in traffic, water temp is 20c cooler!!
even when driven hard it's 15c cooler!
there's also slight drop on oil temp!
can't beleive i didn't work this out earlier!!
Old 21-10-2010 | 11:55 PM
  #49
adie_mwell's Avatar
adie_mwell
love this van mate am gawny build another van wen i finish my current rebuild and go 4x4 zetec turbo whats involved in the rear disk conversion ? cant wait to see it painted defo worthy of a feature get me your rims sent up ill pimp them up haha
Old 22-10-2010 | 12:21 AM
  #50
phil_rs's Avatar
phil_rs
yam yammer
Leave it as is I reckon, love a tatty van that goes like stink!!
Old 22-10-2010 | 12:31 AM
  #51
COLEYST200's Avatar
COLEYST200
my hat is off to you mate
Old 23-10-2010 | 08:43 PM
  #52
xtrmjks's Avatar
xtrmjks
Thanks,guys!!
Been busy with Cad sus.prog designing tubular, rosejointed lower arms..getting there!
Old 07-11-2010 | 09:54 PM
  #53
escortmk5's Avatar
escortmk5
hi,every one.nice moded van.I have a problem I would be very happy if someone would like to help me.I am building a zetec turbo engine and bought supertech valves from the US.the lenght of the valves are the same but the ony difference is that the european valve version has 3 grooves(cotter) and the US version has 1 groove.I bought 1 groove cotters and valves springs+retainers from ford racing US.when the head was fit with the new parts there was a loss in fitted leght of 4mm.it seems that the only way out is to find offset valve spring reatiners which I cant find.can someone help me please.
Old 07-11-2010 | 10:07 PM
  #54
MrCapriScort's Avatar
MrCapriScort
Old Fords Never Die
Mad project, proper sleeper
Old 14-11-2010 | 03:48 PM
  #55
EscoVan's Avatar
EscoVan
Awesome van mate what would you say the total figure for the engine is? and Whats the rear disc set up off? Thanks
Billy_RS
15
05-09-2015 01:04 PM
Chopshop85
17-08-2015 07:38 PM
druidgetafix
15-08-2015 11:22 AM
turbobill
09-08-2015 06:21 PM
turbobill
01-08-2015 09:55 PM
