hooorrrayyyyy i got an internet connection again
steering colum looks sound m8 every one ive seen look's different.
youn could 'nt give me the measurements for the cossie brake servo could you my car was built with the focus servo in mind to use but ive tried to mock it up and it hits the down pipe
just need the measurements from the chassis up to centre of hole and from the flitch to the centre of the hole please Andy
will try get some for you tomro mate when im back in garage ,
that mean you'l have put the servo mount in as well the hole for
column go throw ?
soon as i get this back of spit primerd up an tidy garage dave ,as it is in the way were it is really, feel guilty as the bloke had to put one his cars in damp garage coz off it ,but got no funds to do anything on it tho still it be nice to have it home tho just to look at lol
Is all the fab work done on your shell?
What are your plans with the car? colour ? wheels ? power?
there build thread on here mate
its painted blue all fab work done by ag motorsport ,as for power it will
run what ever the car/engine comes with i buy then over time it will
get uprated ,not sure on wheels yet
from the looks of things, you'll soon have another one getting the treatment so if you don't sell the jig i'll be waiting for a beam
might have to come a tad bit further than coventry to get it though
the jig going no were mate its tookd away in a safe place
also a normal focus back beam is same as a focus rs one bar the brakes
just the front that different so iv been told buy the bufftys on rsoc site
This is awesome mate, have i read this right then... this shell is going to be forsale when complete as a rolling shell? rough figure of a price?
it will have the main fabwork done the convertion (little bits like fuse box brakets an that will be up to buyer) it will be in primer with all
panels bar spolier an grille around (4grand ,not desided yet) tho wount be rolling just on
trolley unless i get more for it
That's the "roughly" part Mines pretty much quite simple, a stock Focus column with the shaft modified e.g cut and Saph one welded on.
it will be same as it copyed from my other shell,the part i ment was past bulkhead the coupling from triagle bit to steering rack just i have
shorten mine for it to fit ,?not the column the coupling
im trying to cut the top out of the cossie pedal box , weld a plate on the front (to add strength) the make up some kind of braket with a roller to carry the steering colum down till it changes to the triangle needed for the cossie steering rack.
every one ive looked at is different so i thought id keep it as high up as i could as im a lanky 6'3" sod
What you think?
Once you fit the "special" bearing it'll work perfect.
could you not simply have cut that pedal section out of a seirra and then welded it in where you felt most comfortable?
the hole for the bearing wold have then linged up with everythign else?
