mini rs cosworth
Old 21-06-2016, 05:32 AM
  #841
COLEYST200
COLEYST200's Avatar
It's looking very nice as all ways mate
scarnny (21-06-2016)
Old 21-06-2016, 05:42 AM
  #842
Moderator
STeve's Avatar
Originally Posted by scarnny
I've had the car off the road for a while to sort out a few bit and pieces, got a new bonnet with some focus rs style vents and some added bling on the underside to help with cooling...[
should be at ford fair this year if anyone wants to come and have a chat..
dont forget to get booked up before july 1st andy,
Old 21-06-2016, 11:45 AM
  #843
scarnny
scarnny's Avatar
cheers mate, gonna do it Friday, ( pay day ) yippee...
STeve (21-06-2016)
Old 23-06-2016, 08:30 PM
  #844
scarnny
scarnny's Avatar
anyone going to the retro show...
http://www.retroshow.co.uk/index.html
Old 23-06-2016, 08:57 PM
  #845
Caddyshack
Caddyshack's Avatar
I think I am, I will say hello if I make it
Old 10-09-2016, 09:28 AM
  #846
scarnny
scarnny's Avatar
finally got the mini out on track at Snetterton, I was very pleased how it performed on the day, apart from some rubbing on the passenger side tyre it was faultless all day..
Old 09-06-2017, 06:33 PM
  #847
scarnny
scarnny's Avatar
mindlessly tyre shredding....lol...
Old 09-06-2017, 06:36 PM
  #848
Caddyshack
Caddyshack's Avatar
Cool vid, most Cossies produce that much smoke just from the exhaust.
Old 09-06-2017, 06:39 PM
  #849
scarnny
scarnny's Avatar
ha yeah, it does smoke a bit but it's normally black smoke....
  #850
Caddyshack
Caddyshack's Avatar
Mine too
Old 09-06-2017, 07:02 PM
  #851
scarnny
scarnny's Avatar
who up for this next week
www.retroshow.co.uk/index.php
Old 09-06-2017, 10:18 PM
  #852
COLEYST200
COLEYST200's Avatar
That looks such a good show I might pop along to this one
Old 23-01-2018, 04:41 PM
  #853
scarnny
scarnny's Avatar
Default Group a coil
I'm thinking of replacing my standard coil with a group a one , is it worth doing? and how much hassle is it?
thanks Andy..
Old 23-01-2018, 04:42 PM
  #854
Caddyshack
Caddyshack's Avatar
Go coil on plug if you can.
Old 23-01-2018, 04:51 PM
  #855
scarnny
scarnny's Avatar
I'm a bit limited for space , how much extra room will it take up?
Old 23-01-2018, 04:55 PM
  #856
stevieturbo
C**t
stevieturbo's Avatar
What ecu you have can determine coil options.
COP will add a little height on the valve cover area...ie where the coils sit on top of the plugs. But it looks like you've a strut brace up there, so presumably a load of room ?
Or a 4 tower type coil pack....wont add any height as you'd still be using HT leads same as you probably have now.
Obviously your ecu would need to be able to accommodate either of these instead of the dizzy
Old 23-01-2018, 05:08 PM
  #857
Caddyshack
Caddyshack's Avatar
To add to stevie turbo...I have Yaris coils so you mill off about 10mm from the turrets on the cam cover so you save some height and lose the leads off the dizzy, ideally delete the dizzy and go cam trigger 9as long as ecu allows)
Old 23-01-2018, 05:42 PM
  #858
scarnny
scarnny's Avatar
thanks for the input guys I will look into it, I'm not sure my ecu is compatible for that option,,,,
Old 08-11-2020, 11:02 AM
  #859
scarnny
scarnny's Avatar
Default turbo oil leak??
hi guys, I've got a t34 turbo which hasn't done a lot of miles and I thinks it's started leaking oil from somewhere , I thought it was coming from the oil return pipe as it runs down the outside of the pipe but I've replaced the gasget and it's still leaking, could it be a seal in the turbo??? any advice would be welcome please, as the next plan is to take it off and strip it down...
thank Andy...
Old 08-11-2020, 11:07 AM
  #860
stevieturbo
C**t
Give it a good clean to see exactly where it is leaking from. If it's external....it can't really be a faulty turbo unless the casting is cracked, which is extremely unlikely.
Find what height the leak starts from, and then you'll get a better idea.
Old 08-11-2020, 02:37 PM
  #861
scarnny
scarnny's Avatar
thanks for the reply, that's very interesting, I'll check my breather system as it seems to leak on boost not at idle which would point to that problem...
Old 28-04-2022, 08:55 AM
  #862
scarnny
scarnny's Avatar
Default New clutch
hi guys, I'm after a new clutch for the car , ive had an AP organic one in it since I built the car and it's done really well but this year it's started slipping on high boost , I'd like to get another AP one but they don't make them anymore so I was just seeking some advice as to what one to go for, the he helix one is an option but a lot more expensive than the AP one , any advice please would be welcomed
thanks andy
Old 28-04-2022, 06:54 PM
  #863
stevieturbo
C**t
TTV ? Helix ?
BIG.DAMO.H
1185
15-02-2019 06:11 PM
MT-Motorsport
16
13-04-2014 09:33 AM
turbodod
42
20-11-2011 11:05 AM
malcs-escort-cos
12
22-02-2009 09:38 AM
Kverna
66
01-11-2008 11:42 PM
Quick Reply: mini rs cosworth
