3dr Sierra project from Greece
#43
these are my specs of my engine:
GT35 garrett ball bearing
throttle body aftermarket with F70
external turbonetics 38mm
grey injectors form the start ,later 750cc siemens
DTA P8PRO ecu with new loom
kent cam pulleys
bd16 cams
cometic gasket
ARP kit
bigger valves
ported head
double valve springs
lighter flywheel
clutch kit AP
Gr A oil pump
bosch 044
200 block
blue flame exhaust
S steel exhaust manifold
GGR breather
oil cooler
alloy water radiator - rs500 I/C
gaz coils
poluyrethane full set
BLITZ boost controller
full gauges
pistons 7.8: 1
lighter balanced crank
T5 gearbox with B&M shifter
std rear diff
std brekes at the moment
kent cam pulleys
bd16 cams
cometic gasket
ARP kit
bigger valves
ported head
lighter flywheel
clutch kit AP
Gr A oil pump
bosch 044
200 block
blue flame exhaust
GGR breather
oil cooler
gaz coils
full gauges
pistons 7.8: 1
std rear diff
#45
kent cam pulleys
bd16 cams
cometic gasket
ARP kit
bigger valves
ported head
lighter flywheel
clutch kit AP
Gr A oil pump
bosch 044
200 block
blue flame exhaust
GGR breather
oil cooler
gaz coils
full gauges
pistons 7.8: 1
std rear diff
kent cam pulleys
bd16 cams
cometic gasket
ARP kit
bigger valves
ported head
lighter flywheel
clutch kit AP
Gr A oil pump
bosch 044
200 block
blue flame exhaust
GGR breather
oil cooler
gaz coils
full gauges
pistons 7.8: 1
std rear diff
thank's a lot my friend!
RB26DETT
05-02-2022 01:54 PM
nico12
31-12-2015 04:42 PM
Adam Graham
06-09-2015 06:04 AM
