my frst engine problem
Old Sep 17, 2009 | 08:22 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
Lightbulb my frst engine problem
<a href="http://s560.photobucket.com/albums/s...paintcozzy.jpg" target="_blank"><img src="http://i560.photobucket.com/albums/s...paintcozzy.jpg" border="0" alt="bens signature"></a>
escort mk5 xr3i it was now escort mk5 efi rs turbo with t3 and ofac loom&ecu&map/sensor strait throuh exhaust , xr3i gearbox
problem is the car runs on idle and slow throttle as i hit the throttle fast even at a distance of 2mm ish it cuts all engine power as soon as you lift of the throttle all revs are as usal
ive checked and fitted new well all the sensors,coil,fuel rail loom,two types of loom and ecu ofac and ofab with matching map/sensors...
none of this has solved the problem any more ideas guys n girls
Old Sep 17, 2009 | 09:30 PM
gup's Avatar
gup
what are the spark plugs gapped too and what plugs are you running fella
Old Sep 17, 2009 | 09:33 PM
benjaminsarmy
there motorcraft and gapped to 1.65
Old Sep 17, 2009 | 09:40 PM
benjaminsarmy
embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i560.photobucket.com/player.s...nscarprobs.flv">
Old Sep 17, 2009 | 09:41 PM
babscossie's Avatar
babscossie
1.65 what??? mm???
Old Sep 17, 2009 | 09:42 PM
gup's Avatar
gup
theirs your prob then fella
gap them to 1.0mm i think thats what they recommend
but on my mates highj boost one we gapped them to .8 as it kept on blowing the spark out
Old Sep 17, 2009 | 09:43 PM
benjaminsarmy
a piece of paper was in the plug box that i bought sayng regaped to 1.65 but this issue still acurd before these plugs were fitted http://s560.photobucket.com/albums/s...nscarprobs.flv
Old Sep 17, 2009 | 09:44 PM
benjaminsarmy
do you know jano
Old Sep 17, 2009 | 09:46 PM
babscossie's Avatar
babscossie
does it totally cut out when you come on boost?
Old Sep 17, 2009 | 09:47 PM
gup's Avatar
gup
yes fella why
Old Sep 17, 2009 | 09:49 PM
gup's Avatar
gup
try the gap setting i said fella and see if it helps also try and knock the boost down to about 2/3 psi as you may be hitting the boost cut
Old Sep 17, 2009 | 09:53 PM
benjaminsarmy
Lightbulb
yer totally but when i let off it gains its revs ive tryed everything here is a vid of today (the problem)http://s560.photobucket.com/albums/s...nscarprobs.flv
Old Sep 17, 2009 | 10:06 PM
benjaminsarmy
how do i turn down the boost is it at the actuater
Old Sep 17, 2009 | 10:07 PM
benjaminsarmy
Originally Posted by gup
yes fella why
can u ask him i have h<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i560.photobucket.com/player.s...carprobs.flv">erd hes good at this stuff
Old Sep 17, 2009 | 10:13 PM
gup's Avatar
gup
i havent got his number on me at the min fella
but his website is www.oddkiddcreations.co.uk i think
yes you turn the boost down by making the rod bigger
its a shame im busy at the min i would of tried to pop over have a look for ya
try the gap settings fella then c how it is
did all the management come of a running car
Old Sep 17, 2009 | 10:17 PM
benjaminsarmy
yer me mate clarkie he sold it to me with loom ecu and map sensoer and the rest of the bits on the plate like edis and co etc i see it runnig before hand
,, if you get chance please come and check for me and ill regap them tomo out come the fella gauges lol
Old Sep 17, 2009 | 10:18 PM
XRT_si's Avatar
XRT_si
Strange one mate, as I say mine done similar when it was on the OFAC loom and OFAB ECU but you tried that?
Agree with above, if your about tomorrow morning I can turn the boost down for you if it will make a difference if that doesnt work I agree, take it to Jano.
Old Sep 17, 2009 | 10:19 PM
enzo_dj's Avatar
enzo_dj
that could be the problem bro as when the boost kicks in its not ignighting the fuel air mixture dus making it cut out
Old Sep 17, 2009 | 10:21 PM
benjaminsarmy
si can you come check if not to much bother bro
Old Sep 17, 2009 | 10:37 PM
fiend's Avatar
fiend
Is it chipped?
Old Sep 17, 2009 | 10:41 PM
benjaminsarmy
na not chiped blue injectors
i think bog standerd a
Old Sep 17, 2009 | 11:00 PM
fiend's Avatar
fiend
Checked for any airleaks or any hoses collapsing?
Maybe not enough fuel pressure?
Old Sep 17, 2009 | 11:11 PM
benjaminsarmy
collapsing pipes is that when they draw in all skinny
ive not seen any syptoms just like its a power cut or sim ?!?
Old Sep 17, 2009 | 11:22 PM
XRT_si's Avatar
XRT_si
I am going away at the weekend but free EARLY morning? What time you about?
Old Sep 17, 2009 | 11:23 PM
benjaminsarmy
when ever
Old Sep 18, 2009 | 07:48 AM
mk3 track car's Avatar
mk3 track car
may sound like a stupid question but that happened to me on a conversion i did, have u tried swapping ur fuel pump over, could be a fuel starvation problem
steve
Old Sep 18, 2009 | 10:52 PM
benjaminsarmy
right i tryed them magnicore leads and still no joy what else can it be
and where is the fuel pump located on a mk5 escort xr3i
Old Sep 18, 2009 | 11:42 PM
benjaminsarmy
any more help pf guys
Old Sep 19, 2009 | 08:36 AM
mk3 track car
the fuel pum is on the top of the tank, shame ur so far away or i would come and have a look for ya
Old Sep 19, 2009 | 11:59 PM
benjaminsarmy
thanks mate do i have to drop the tank i lookd under my rear seat and it looks tight mate
Old Sep 20, 2009 | 07:46 AM
mk3 track car
unfortunataly yeh u will have to drop the tank only 4 bolts but its a fuckin ball ache haha or u could do what i did and make an acsess hole under ur seat like i did for easy acsess in future
steve
Old Sep 20, 2009 | 10:25 PM
benjaminsarmy
steve
oh rite do you hwve a pic of it other wise im sure to balls it up
Old Sep 22, 2009 | 03:01 PM
one_nineRS's Avatar
one_nineRS
Take your car over to Grove garage, Hornchurch, they are not too far away from your location, and they would diagnose and fix your issue in minutes, may save you alot of hassle in the long run..Ahmed Bayjoo and the boys know their stuff..
Old Sep 24, 2009 | 11:36 AM
monkeyboi's Avatar
monkeyboi
yo your bringing it passion ford tonight at enfield ?
Old Sep 24, 2009 | 12:54 PM
benjaminsarmy
yer mate that is what happens
Old Sep 24, 2009 | 12:56 PM
benjaminsarmy
its been to janos oddkidcreations but still has this fault gona go back when i get a new co sensor
Old Sep 24, 2009 | 12:58 PM
benjaminsarmy
Thumbs up
hi mate yr me and a few pals hopfully gona go tonihgt if you want to meet with us and go together more than welcome ring me on 07984497630
Old Sep 24, 2009 | 01:21 PM
monkeyboi's Avatar
monkeyboi
ill be over there so ill see ya there. aint clarke got a co sensor ?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
bigryrs
Fiesta RS1800/RS Turbo
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
