317bhp 2wd sapphire cosworth
i bought a sapphire cosworth a little while ago
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0634.jpg)
it was tidy, stage 3 engine, stack of history, etc
but it is still a 20 year old car so improvements can be made.
so when my turbo died i saw it as time to do some work
the first thing i did was remove some of the chrome from under the bonnet as i cant be arsed to clean it![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
then i fitted new front discs
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0682.jpg)
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0683.jpg)
while i was at it i had the arch liners out to clean the inner arches
and was quite happy with how tidy it is under there
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0653.jpg)
ive replaced the chavvy alloy gear knob with a leather gti style one
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0689.jpg)
then ive started to clean and repaint the underside
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0688.jpg)
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0687.jpg)
so im now up to date,over the next few weeks im hoping to get my new turbo and finish painting the underside
cosworth gimp
so when my turbo died i saw it as time to do some work/upgrades
the first thing i did was remove most of the chrome from under the bonnet as i want to go more stealth under there
then i fitted new front while i was at it i had the arch liners out to clean the inner arches
so im now up to date,over the next few weeks im hoping to get my t34 turbo and finish painting the underside
your old disks were on the opposite sides
make sure you fit the new ones the right way round ....... ie when braking the dust is moved to the outer part of the groove when disk rotates if you get my drift..
![](https://passionford.com/forum/images/smilies/roi.gif)
forgot to update this
i bought myself a refurbed turbo and a new -31 actuator, its now back on the road after a oil and filter change
then a couple of days ago my new denso plugs arrived so i chucked them in along with my poly strut top bushes which ive had fo a while
and yesterday my new turbo damper arrived so i fitted that
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0783.jpg)
T-bolt clamps...Amazing stuff when they work.. shit when you undo them completely and try to get them back together!
Lookin well mate, Love the matt black bits, did you use VHT black at all or just matt black? painting chrome bits is a bastard as usually i find the paint to easily chip![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
What does your car run like with out the amal valve?
cheers
cheers
cheers
cheers
think the alloy was easier to keep clean
car runs fine without the amal valve
another little update
fitted a new ecu cover as some numpty had hacked the old one for a boost gauge![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0798.jpg)
managed to get hold of some new roof lining material as mine is a little saggy
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0800.jpg)
and replaced the water temp sensor in the block with a new matt lewis one
![](http://i69.photobucket.com/albums/i55/749steve/cossie/Photo0802.jpg)
i also tried fitting my new air box, but found it wont fit due to the intercooler and the turbo heatsheild
change of plan on the wheel front
after some advice from various people in the know, i decided to stick with 17s
this way i dont mess the handling up as much and i can buy tyres at reasonable money
so i bought these
![](http://i69.photobucket.com/albums/i55/749steve/cossie/BMZ87w2kKGrHgoH-EYEjlLly8EBKqWSt4UO.jpg)
revolution millenium with group a inserts and prada tyres
so i bought these
