24v BOA or 24v BOB?????
which is the real deal, the BOA from the granada or BOB 24v'r from the ugly wide mouth frog thing scorpio. ???? also whats the difference, can you straight swap the BOB 24v into a granada that had the BOA???
of the two the boa is the easier one to deal with , the bob has the pats system which can be bypassed ( just not by me.. ) the bob can replace a boa by using the boa loom, again i've no idea on what you need to do but i know of a couple of cars doing this.........
i prefer the BOA's look smarter also....The bottom end on BOA's are supposed to be bulletproof and can withstand 400bhp+ on standard internals ive been told...altho i would put BOB cams into the BOA...dont know why but i know everyone does it
thats how it was explained to me, i didn't have a flat spot as such , but have you noticed the sudden oomph as the secondary opens and you get more power??? it sort of smooths it out abit, me i prefer the oomph bit myself and when the engine goes back in i won't bother with the cams just the vaux injectors..
Yea...i heard Vectra injectors work well...can you enlighting me on this please?
I dont really notice the "oomph" tbh as most of the time the engine is peaking over 3.5k most of the time sideways....will have a listen for it when im next out on track tho
someone else said to me about vectra injectors. there supposed to be better
The bumph on 24v BOA vrs BOB
BOA
Easier fitted.loom is simpler,upgrades are install a set of bob cam and a set of vauxhall injectors,i think the boa is a nicer plant slight down side to boa is that there is less meat on the block around the cranks and therefore the bob block is stronger.
BOB
The wiring loom is more difficult to install as it has a pat system,to me not as nice a unit,althought it already has bob cams and a stronger bottom end
some pic of my boa unit
link to restoration
https://passionford.com/forum/genera...rd-sierra.html
BOA
BOB
link to restoration
BOA
BOB
link to restoration
BOA
BOB
link to restoration
