Mk6 JWRC fiesta cosworth
Old 14-04-2010, 09:30 PM
  #521
M K
M K's Avatar
Small written update to bore you with lol,
spoke to andrew and not much done lately as he is waiting for some more bits to be machined by kenny at omnitool, not sure what tho,
ordered my hydraulic handbrake and also a pair of fia approved towing eyes so Andrew can weld them into place so they stick out nicely somewhere suitable from the front and rear bumpers, so those parts along with the tilton bias valve were posted off to him today as they were the last things he needed from me before he finishes everything off,
not sure when the next update from Andrew will be coming so keep ya eyes peeled
Old 14-04-2010, 10:35 PM
  #522
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
I wonder if theres much weight capable of being lost by cutting out your original floors between sill and tunnel and replacing with thin alloy/composite?? with all the cross bracing there cant be much structural need for the floors?
I wonder how much weight has been saved of the front end through space framing?? Ive always wondered if you do it purely for weight reasons if the cost is worth the saving?? (obviously its done for more than just weight in your case!).
Old 15-04-2010, 04:26 AM
  #523
M K
M K's Avatar
I would not bother cutting the floor sections out now, but I'm interested to see the weight too, all the cage and front end etc is T45 so it's as light as it can be,
I will ask Andrew if he can throw it on the scales when it's done and the doors and boot are back on and his dummy engine is still in it
Old 15-04-2010, 11:19 AM
  #524
Psycho Warren
Carbon Crazy
that wont mean anything unless you can find out the weight of a standard shell. I guess youve got a standard car weight to compare it to when complete!
Im thinking of partially space framing the front of the puma but not as far as you, id leave the chassis legs intact and replace the inner/outer wing pressings and associated metal with tubing. Same with front cross member.
Old 15-04-2010, 05:42 PM
  #525
M K
M K's Avatar
it will mean something as it will give me a clue to the likely final weight of the car, as being 4x4 i was told to expect it to be heavy around 1200kg - 1300kg, but id like to be under 1200kg if poss,
Old 15-04-2010, 05:46 PM
  #526
M K
M K's Avatar
Andrew - judging by this pic of the flange and bearing adapter fitted i assume i will have to use a custom one off mount for whatever caliper i use on the rear as it seems to sit quite far away from the hub? i haven't seen a fully built up grp a unit to compare tho?
Old 15-04-2010, 08:38 PM
  #527
Psycho Warren
Carbon Crazy
I dont know how much a mk6 fez normally weighs but my puma weighs 1256kg will a full tank and fully trimmed interior (incl sound deadening etc) with nothing cut off shell.
Old 16-04-2010, 06:20 AM
  #528
M K
M K's Avatar
Normal mk6 fiesta weighs between 1096kg and 1178kg,
I've saved alot of weight but added a lot of cage and heavy 4x4 transmission so it will be interesting to see
Old 16-04-2010, 10:04 AM
  #529
c20tbo
c20tbo's Avatar
Hopefully mine is next for a rear end setup at AG, just waiting for Andrew to get back to me to see when he can take it. Got to admire his skills and work!
Old 16-04-2010, 12:04 PM
  #530
fezzajsy
fezzajsy's Avatar
looking good
Old 17-04-2010, 11:28 PM
  #531
erjones
erjones's Avatar
Looking good mate, you hoping to get it to Ford Fair?
Old 19-04-2010, 05:52 AM
  #532
M K
M K's Avatar
The AG team certainly have the skills no doubt about that,
as for ford fair i wish it would but there's too much to buy and not enough funds at the mo but hopefully next year for sure,
hopefully have some updates from Andrew this week if the bits he was waiting for from kenny are done etc
Old 20-04-2010, 10:35 PM
  #533
erjones
erjones's Avatar
Nice one, look forward to seeing it
Old 26-04-2010, 05:13 PM
  #534
andrewg
andrewg's Avatar
Old 26-04-2010, 05:27 PM
  #535
COCHYN
COCHYN's Avatar
Insane!
Old 26-04-2010, 05:30 PM
  #536
erjones
erjones's Avatar
wow love the work!! think if i ever need work done to future cars i will make the long trip north to get it done there, top work
Old 26-04-2010, 05:49 PM
  #537
fezzajsy
fezzajsy's Avatar
looking good
Old 26-04-2010, 06:14 PM
  #538
graham c
graham c's Avatar
mint
Old 26-04-2010, 07:28 PM
  #539
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
looking good mark ,
question , will the hand brake be a " fly off type" or will it still pass a mot >
with a bit of luck ill be going to collect my mock up cradel wed
keep up the good work fella
Old 26-04-2010, 07:31 PM
  #540
J1mbo
B1mbo
J1mbo's Avatar
beef, i think that the handbrake is both
there is a thing that goes over the top with teeth in and it locks the handbrake on as well as being fly off
cracking work andrew as usual
Old 26-04-2010, 07:43 PM
  #541
M K
M K's Avatar
looks fooking awesome.....thanks for the update Andrew
think you will still be on track to have the all the main parts finished this week if kenny gets the parts your waiting for machined up etc? then i think that will only leave the fuel system to discuss,
Beefy - the handbrake is lockable but no hydraulic handbrake will pass MOT as you have to have a cable item incase the hydraulic system loses pressure/fluid and fails so i will need a cable spot caliper and back up for mot times,
i cant wait to get this home and do some work myself as i feel a bit left out
Once again big thanks to Andrew and Scott for an absolutely amazing job with this build and kenny for his machining skills
Old 26-04-2010, 07:50 PM
  #542
carlo
carlo's Avatar
OOHH getting there now mate
Old 26-04-2010, 08:11 PM
  #543
scarnny
scarnny's Avatar
looks very nice mate. what sort of power are you going to have and what engine? 4x4 or 2wd?
cant wait to see this thing done.
Old 26-04-2010, 08:39 PM
  #544
dingla rs
dingla rs's Avatar
this thing is mental almost as good andys focus ,great work as always andy an team
id hate to no how much this thing costing
Old 26-04-2010, 09:36 PM
  #545
Fantastic progress
Old 27-04-2010, 08:24 AM
  #546
andy escos
andy escos's Avatar
looking real good mark not long now until you get it back ,then you can put your mark on it .
Old 27-04-2010, 09:33 AM
  #547
andrewg
andrewg's Avatar
lightweight way of attaching croch belt (-eye bolt and - clip) also less of a sharp edge for the belt
Old 27-04-2010, 09:57 AM
  #548
M K
M K's Avatar
Didn't even cross my mind to do it like that mate,
good thinking
Old 27-04-2010, 10:53 AM
  #549
K33VRN
Captain Cock Blocker
K33VRN's Avatar
some awesome work mate!!!!
Old 28-04-2010, 07:02 AM
  #550
M K
M K's Avatar
the engine will be a field Motorsport built yb running between 450 and 500bhp with similar torque if possible, and as the pics show it's running 4wd
this is like a smaller version of Andrews focus but will not have such exotic transmission unfortunately, as for cost Andrew has done me a good price
Originally Posted by Twins
Fantastic progress
even better if you and stu get involved with it once it's back,
I have a proper roll over jig to use now too so should make underside prep easier than laying on my back lol
no I can't see it being long now as the AG team are making serious
progress lately but there's a few extra's to be discussed still,
but as il be skint when I get it back things will slow down but there is still alot I can be doing that doesn't cost the earth and I'm just looking forward to being able to work on it myself
none of it's down to me yet mate it's all Andrew and Scott
Also although 99.9% of the fab work is complete I have bought myself a sealey 160 supermig as I'm going to teach myself how to weld
first on the list to do when the cars back is weld up some custom bars/braces to fit the shell to the rollover jig my mate dave is lending me so I'm looking forward to that,
will grab a pic of all my new welding gear tonight and post it up
And with any luck there will be more updates from Andrew at the end of the week so keep your eyes peeled
Old 28-04-2010, 07:43 AM
  #551
erjones
erjones's Avatar
Some nice work
Yeah MIG welding is alright, im not amazing at it but can get along ok lol trying to master TIG at work at the moment lol
Old 29-04-2010, 12:04 PM
  #552
Spammage
Spammage's Avatar
Holy shit this thing is awesome coming along well now whens the projected finish date got a deadline???
Old 29-04-2010, 05:54 PM
  #553
M K
M K's Avatar
Originally Posted by erjones
Some nice work
maybe i will try TIG at a later date but mig is most comon and prob more usefull in the long run to me,
There is no project finish date mate as such but middle or late next year would be nice, maybe ford fair
Old 29-04-2010, 07:36 PM
  #554
BlairM
BlairM's Avatar
Coming along nicely, like the crotch belt set up thats the same way I did my ST.
Old 29-04-2010, 07:53 PM
  #555
focus 4x4
focus 4x4's Avatar
WOW thats nearly as good as my car .................lol
Old 30-04-2010, 04:14 AM
  #556
M K
M K's Avatar
I asked Andrew to weld in another eye bolt fixing plate for the crotch belt as wrapping it around the seat bar didn't even enter my head
luckily He knows what he doing or I'd be adding weight I don't even need,
cheers mate,
your focus 4x4 is awesome
Old 03-05-2010, 02:26 PM
  #557
xr_craig
xr_craig's Avatar
Nice project mate, just had a read through. The standard of work looks fantastic and very well thought out
Old 03-05-2010, 03:49 PM
  #558
M K
M K's Avatar
cheers mate,
i definitely had a good think before starting this project about what i wanted and exactly how i wanted it and anything i was unsure of or was not such a good idea after all Andrew put me straight about it and advised whats best etc
great guys at AG motorsport
Old 09-05-2010, 03:32 PM
  #559
M K
M K's Avatar
small update,
nothing to really show as yet so just fill you in on whats been happening,
the last major part of the build as far as Andrews work is concerned is the front suspension/tca/comp strut set up,
Before the car was started i spoke to Andrew and told him that on the front end i want it fully in situ adjustable, on the tca, comp strut and steering rack rod ends but i definitely did not want to use the off the shelf compbrake tca's and comp struts as in my opinion and seeing the failures others have had just "pushing" there cars about that there items are just not strong enough for an out and out track/race car.
Unfortunately i dont have the money spare to go for a proper wrc/grp a front set up so have to stick with the standard hubs. Andrew tried to use a proper grp a tca and adapt the pin to suit the standard hub but after messing around he just wasn't happy with the angle so that idea was scrapped, he is currently having some more bits machined up to make his own bits up from scratch i think so im sure he will post up some pics when this has been done, as im eager to see it myself and this means the car is very close to being ready to collect
Only other thing that's been sorted is a roll over jig from a friend Dave so that when the shell is back i can make up some suitable brackets with the new welder and get the car in the air ready for the prep and paint process of the inside outside and underneath and engine bay,
The cylinder head is not yet ready from tommy as he has been manic busy and is also waiting on the cams to be made up as they are not an off the shelf item so no idea how long that will be but pics when its done of course
last thing is the little ebay bargain i got of a set of brand new ARP rod bolts for £34 another little part of the future engine build,
An update from Andrew soon with any luck so watch this space..........
Old 15-05-2010, 10:29 AM
  #560
c20tbo
c20tbo's Avatar
Mark,
Was up at AG yesterday as my 106 has been delivered, had a nosey around the fiesta! very very nice your deffo going to be over the moon with it, even better in the flesh matey.
You dont fancy selling me one ov them hubs do you? i need another 2!
Quick Reply: Mk6 JWRC fiesta cosworth
