Mk6 JWRC fiesta cosworth
#203
We'll see how wenny's old front diff copes in my 106, 600+
What sort of deal did you get on a hart plenum if you dont mind me asking, thinking on this route as i think martin was going sweedish on my engine but after reading up on hart jobbie and results, change of plan me thinks!
#207
very nice mark and really coming along nicely. fook me its only took 2 weeks to get yours to this stage , andy and his team dont fook about do they .
cheers paul
cheers paul
#208
how much did you pay mate as im looking to use a quaife thick wall case and diff ?
What sort of deal did you get on a hart plenum if you dont mind me asking, thinking on this route as i think martin was going sweedish on my engine but after reading up on hart jobbie and results, change of plan me thinks![/quote]
the plenum with throttle bracket and linkage so cable attaches from the rear of the throttle body (standard cossie item) was Ł460 mate but then you need the part the injectors go into etc still but there only cheap,
cheers mate, just wish i had the knowledge to do all this myself like you are as i would have a bank full of cash then
thats the plan fella
well ever since i seen yours aly i knew i had to have one although its not fair that you have so many other awesome toys to chose from
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
#209
little update on a few bits i have sourced,
i have group A bilsteins for the rear on there way to Andrew on monday and the group A bilsteins to be modded for the front arrived at Andrews last week![Top](https://passionford.com/forum/images/smilies/smile011.gif)
also some time this coming week i have to go and collect my hart plenum cover and throttle linkage etc so i can get it sent up to Andrew along with the 2wd cossie zorst manifold so he knows what clearance i have around the engine as his making the front end up etc, will also be using a 44mm external wastgate welded into the 2wd trouser section of the manifold,
pics when i collect the parts and maybe some pics of the bilstein coilovers from Andrew when he gets them sorted as i havent actually seen them yet lol,
thanks marc
thanks marc
#213
Cheers Andrew, glad the shocks all turned up ok, looking good so far mate,
does the tunnel still need an added section for the transfer box and front prop?
Inlet has been made and is being collected tomorrow so be with you by Friday along with the zorst manifold so you can check clearances![Top](https://passionford.com/forum/images/smilies/smile011.gif)
what are the next stages of fab work?
Thanks marc,
ps - were you happy with the rear shocks?
Thanks marc,
#234
i had the standard suzuka's in my xr2 and they were a great seat imo so these were an obvious choice
#240
