Advice needed? 202 block rebuild
Hi i am rebuilding my 2wd saph 202 block engine after spinning a shell. I am stuck on what pistons to use? The engine was running grey injectors t34 turbo ruffly 350bhp and im not sure what compression my old pistons where. How do you work it out? I also want to change the oil pump for a high pressure one, wheres the best place to get one? Where would you recomend me to take it to get it set up and maped when runing and run in?
Any help would be great!!!
big_Rad
15-09-2017 09:36 AM
Zoggon
10-08-2015 10:39 AM
Jack and the Beanstalk
09-08-2015 07:03 PM
