morning folks got a spec-r 4 pipe breather & catch tank to go on my 3dr,was wondering at what position do i get the return fitted/welded on the sump & where should get one from?
you should weld the return pipe on side of sump below oil level so there is no pressure from crank case ,best place to get dash fitting is think automotive .
hope this helps
