Ukrainian cosie
#41
now A/R.63 turbine housing instead .48, all silicon hoses, t-bolt clamps, magnecor leads, new heater tank ect
500km of slow moving passed(don't know how to say this period by english), oil changed and now running with full boost 2+ bar
but there is some problems with 5th gear of my T5 - some times it is move out to neutral.
#45
have bought some wheels. seems like cromodora. 18x8. But they has some different locking. Seems like I need to replace studs to longer one or to drill the wheel at the front to suite with std studs. Please give me advice - what to do, what is better way to install it?
#48
do not drill the wheels fit longer studs
http://www.ebay.co.uk/itm/FORD-WHEEL...#ht_1151wt_790
& if they have group a inserts in the wheels you will need these
http://www.ebay.co.uk/itm/8-X-FORD-G...e#ht_713wt_934
#49
Magnesium wheels:
89.9% Mg
9.3% Al
0.64% Zn
0.1%-0.2% Mn & Si
fitted:
215/40 front; 245/35 rear
Thanks Andy! Yes, seems like they are with gr.A inserts. I use this nuts with flat washers. Not sure is it correct:
89.9% Mg
9.3% Al
0.64% Zn
0.1%-0.2% Mn & Si
fitted:
#50
custom cosie 750Nm+ aluminium driveshaft from famous USA shop.
light, was fitted some time ago:
Fordmad!
15
27-09-2015 06:24 PM
cossie1
02-08-2004 09:50 PM
cossie1
35
28-06-2004 12:16 PM
