3dr engine loom
hi there, have just started rebuilding a 3dr rally car. i am starting from scratch. i was given some looms with the car. the engine loom i was given seems to fit just fine apart from one plug! i noticed that the abs loom has a connector plug the same which goes onto the 'brake pipe block' not sure what to call it. will not be fitting this as it is not required on a rally car. i think the plug has 6 pins from memory maybe 7, if anyone can help me it would be great, cheers il get some pics tomorrow
you need to put a photo up mate of wot you need help with and all so this post is in the rong place put it in ( Ford Sierra / Sapphire / RS500 Cosworth ) and you will get the anser you need there mate
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
