My rotten s2..... Finished (ish) :D
Old 11-02-2009, 10:43 PM
  #41
Chopshop85
Chopshop85's Avatar
Default rotten s2 update (26.3.09)
Cheers for the feedback guys!
I didnt want to go silly with the restoration as its my everyday car. but while certain things are out of the way I may as well do a bit of tidying!
Got my amber indicators back in today as I have gone off of the clears!
Just want to get some money together after this rebuild and get the bodywork sorted, few little dents and bits of bubbles starting to come through in usual places! (as my mates always say, looks good from a far, but far from good....getting tired of hearing that tbh lol)
Gonna be a while tho as this engine rebuild has stung my student wallet a fair bit!
Old 14-02-2009, 04:32 PM
  #42
Chopshop85
Chopshop85's Avatar
Finally got the engine back in. Had a few issues with the mounts being cross threaded so the whole process of dropping the block back in took longer than expected! Just need to get the metering unit back in and all the pipes, hoses and wire connected then it should be ready to fire up!!
Finally wiggled it in with all the mainfolds on! Couldnt be bothered to bolt them up afterwards!
Rocker cover on and all finished for the day!
Old 14-02-2009, 04:40 PM
  #43
Great progress there
Old 14-02-2009, 04:49 PM
  #44
Chopshop85
Chopshop85's Avatar
Thanks man, would have liked to get it done and fired up today, But must have spent 3 hours messing about with the engine mounts!
Old 14-02-2009, 04:56 PM
  #45
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Great work, you've done a good job! fingers crossed for the fire up!
Old 14-02-2009, 05:12 PM
  #46
Chopshop85
Chopshop85's Avatar
Ive just realised I might not be able to fire it up as I have broken the coolant temp sensor! ( yellow one underneath the inlet manifold )
does anyone know whether the car will tick over without one?
and where I can find a new one ?
Old 17-02-2009, 06:48 PM
  #47
Chopshop85
Chopshop85's Avatar
Managed to get everything sorted and the engine fired up tonight!
Went smoothly, apart from a dodgy starter connection, 2 water pipes leaking and a fuel line not being tight enough!!!
However, with those niggles dealt with it started and ticked over surprisingly well!
bleed the brakes 2moro then should be ready for a test drive!
Old 17-02-2009, 07:03 PM
  #48
vroooom ptssssh
It Wasnt Me!
nice one good work
Old 17-02-2009, 07:06 PM
  #49
rs_traynor
stage4 2wd cosworth
rs_traynor's Avatar
nice mate.wheels suit it
Old 17-02-2009, 08:16 PM
  #50
Matt carter
Matt carter's Avatar
Whats the engine spec? Standared or have we got some more oooomph?
Old 17-02-2009, 10:14 PM
  #51
Chopshop85
Chopshop85's Avatar
Nothing special. just the basics.
Air Filter
Exhaust
-31 actuator
Front mount
Chipped ECU
hoping for around 170-180bhp. Gonna take it to northampton motorsport once ive done my 1000 mile run in and see what they can do!
Old 17-02-2009, 10:16 PM
  #52
brett_
brett_'s Avatar
least you got it in mate, jst got your runnin in stage now haha
mite pop over 2moro mate
Old 17-02-2009, 10:30 PM
  #53
Chopshop85
Chopshop85's Avatar
yeah man do it, you can help me bleed the brakes
Old 17-02-2009, 10:38 PM
  #54
boothy
boothy's Avatar
good work mate.....
Old 18-02-2009, 01:33 PM
  #55
Chopshop85
Chopshop85's Avatar
Got the brake bled today and went for a little spin with 2 major issues!
the car is pulling hard to the right under acceleration, then when i let off the throttle it snaps the steering wheel left!??!
and the temperature gauge is about 1mm under the red !!!
any ideas?
Old 18-02-2009, 02:48 PM
  #56
fezzajsy
fezzajsy's Avatar
thermostat fucked?maybe..
hope you get it sorted
Old 18-02-2009, 06:26 PM
  #57
Chopshop85
Chopshop85's Avatar
yeah i think you might be right on the thermostat as its not kicking the fans in either!
Found out what the random pulling all over the shop was. Anti roll bar was on but not tightened up properly! got that sorted as well!
Old 18-02-2009, 09:13 PM
  #58
Nice project mate keep up the good work.
Old 18-02-2009, 09:32 PM
  #59
coswurv
coswurv's Avatar
Make sure you have beld all the air out the system properly, check that all the pipes are around the same temp when the engine is up to temp including all the rad, check the heater is blowing out hot or as good as they are, if that is all ok then it must be down to the fan switch, fan or wiring, if the fan does come on in the end but wont go out you may have issues somewhere else.
Old 18-02-2009, 10:38 PM
  #60
Chopshop85
Chopshop85's Avatar
thats something else i have forgotten to do
im not doing to good at the moment lol
shall have to get that bled 2moro!
I go the fans on a switch in the car so the fans arent a problem at the moment, its just with the fans coming on under the thermo's reading makes me think theyre may be an issue.
cheer for the input tho, will try it 2moro and see how i get on!
Old 19-02-2009, 07:14 PM
  #61
malcs-escort-cos
malcs-escort-cos's Avatar
nice one mate
Old 26-03-2009, 03:02 PM
  #62
Chopshop85
Chopshop85's Avatar
Finally got the temperature problem sorted with a new rad! nice one "zvhturbo29rs" for that
temps are much lower than before, been out 3 times in it and not even had the fans kick in yet! top stuff.
and also had a bit of funny money knocking about and decided i was fed up of the car being lowered 60mm as it wasnt doing anything any favours.
ordered these on tuesday from amber performance, they said 10 days and they came lunch time today! result!
25mm springs on uprated shocks!
Old 26-03-2009, 07:21 PM
  #63
nsdrst
nsdrst's Avatar
hi mate great project was wondering what alloys u hav they look ace
Old 26-03-2009, 11:32 PM
  #64
Chopshop85
Chopshop85's Avatar
thanks man,
they are team dynamics pro race 1.2
I think they have just done a new range that have slightly flatter spokes.
Old 27-03-2009, 12:18 AM
  #65
hunterlaar
hunterlaar's Avatar
Great work mate,credit to you! really suits the alloys aswell
Old 28-03-2009, 08:29 PM
  #66
Chopshop85
Chopshop85's Avatar
Got the suspension on today, nice easy job. the ride height turnt out pretty good, im pleased with the way it looks. (pics to follow)
also the ride of the car is so much better 25mm dropped with uprated shocks. Such a nice ride now. props to spax.
Old 21-05-2009, 04:00 PM
  #67
Chopshop85
Chopshop85's Avatar
Default My rotten s2 R/R update! (21.5.09)
So finally got it down to Northampton Motorsport with a chance of it coming out set up correctly. (so many times have different engine components let me down!)
The Idle was all over the place so that required adjusting, however, with it being an RS this was no easy task, The screw had turnt into an orangey blob of metal, so that needed drilling out and a new one putting in. Wasnt to bad a job in the end and no metal filings where lost in the metering unit.
Some of the team where hard at work lol
Once all was sorted it was ready to start putting some power down. Or was the plan
Soon discovered that my rev counter is 400rpm out so out came the timing gun to stop to much limiter bouncing!
Had to remove the knock sensor as it was on the fritz and causing spikey havok on the read outs. Next was gapping the spark plugs and advancing the timing.
But alas, when it came to crunch time the good old trusty MFI metering unit was not up to the task of fueling. No matter what was tried anything after 4500rpm the dyno graph just went flat.
The final read out was 149bhp / 171FtLbs @ 13psi. Which im quite happy with as I dont want to lunch the brand new block, just gutted as i know it could make so much more.
Old 21-05-2009, 04:41 PM
  #68
gregxr3i
gregxr3i's Avatar
Nice car mate. Still good but a little work and you'll get that higher reading
Old 21-05-2009, 07:35 PM
  #69
Chopshop85
Chopshop85's Avatar
little bit more work perhaps lol, However the car fund is empty now so im gonna have to leave it as it is for a bit. plus there is some cosmetics that need tending to before anything else.
Old 21-05-2009, 08:32 PM
  #70
ram
Has a large member
ram's Avatar
looks good
at least you know your cars not gonna run lean now, got mine being set up on tuesday, im worried somethings gonna get in the way too lol
Old 21-05-2009, 10:08 PM
  #71
Chopshop85
Chopshop85's Avatar
Originally Posted by ram
looks good
Cheers man, Yeah thats what they said to me, "at least you know your engine is safe at that power"
Its peace of mind now knowing that the new engine is not running rich or the timing is out or anything like that, so it should last (touch wood) until i can get some money together for a bit more power.
Next is the bodywork tho, underneath and engine is done. Next is rust + dent removal and paint! if you look at the pics the bonnet is almost a matt finish lol
Old 22-05-2009, 06:53 AM
  #72
Zetecfiesta
Zetecfiesta's Avatar
gutted mate!
Old 09-11-2009, 03:54 PM
  #73
Chopshop85
Chopshop85's Avatar
Well, time for an update as it has been a while since Ive done anything to the car. (money)
It was dyno'd today with the fitment of a kent pulley to help with ignition issues.
The boys at northampton motorsport finally worked out why my power was running flat at 3500-4000 rpm. It was supposedly to do with the FMIC and where the actuator takes the vacuum pressure from the turbo housing. They replumbed the actuator vacuum to the cross over pipe and its holding the boost nicely now.
Made:
184.6 ftlbs & 165.0 bhp at 14psi.
well chuffed
Old 09-11-2009, 05:12 PM
  #74
Matt carter
All tip top then.
Old 10-11-2009, 10:17 AM
  #75
jay26
jay26's Avatar
this car looks the nuts mate
Old 10-11-2009, 11:54 AM
  #76
JEEMO
JEEMO's Avatar
Love it with the white wheels on it.
Old 10-11-2009, 12:12 PM
  #77
Robs Frst
Robs Frst's Avatar
Nice, like the wheels.
Old 10-11-2009, 03:16 PM
  #78
Chopshop85
Chopshop85's Avatar
Cheers for the comments guys , makes it all worth while.
After going for a little blat last night I have decided I want more lol. As is always the case. So next thing on the list is a clutch upgrade as the car did make 180bhp + 202FtLbs but obvioulsy the clutch was not up for this task at all hence the lower final output.
Gonna save a few pennies and get myself an AP 2000-35 with corresponding quadrant.
Old 10-11-2009, 03:46 PM
  #79
Zetecfiesta
glad you got more power!
Old 13-03-2010, 01:52 AM
  #80
Stow1985
Stow1985's Avatar
Done a good job there mate,
Your work is tidy and with a bit of power to boot.
Credit where credits due
Quick Reply: My rotten s2..... Finished (ish) :D
