2WD Saph Cossi -- Saunamökki --
#41
Excellent, great looking car
#52
Thanks for your nice comments guys!
Been a bit lazy over the winter since it turned out not only the shell on the 4th cylinder was worn, also the crank has marks. First plans were to rebuild the engine, but I managed to get hold of a nice 4WD Saph engine with a pretty nice spec from UK!
Its on the way over the channel atm, plus a lot of nice goodies from the Woodford Garage guys. So I hope to get everything bolted together withing the next 2 month.
Spec is not going to be that wild. L8, Siemens 55s, T35.63, WRC gasket and some parts to keep everything nice and reliable.
Until the parts arrive I am just trying sort out the mess in my garage.
Robbed all the bits from the old engine that I still need:
All parts I need stored:
Also cleaned the sump so I can send it to UK for big wing & baffle conversion:
Hey Stian, there's been barely any progress here as I couldnt decide what to do with it and got a bit bored. Havent been as busy as you!
I already cleaned them, which makes a big difference, but for the new engine theres some adjustable ones on the cards anyway.
Thanks! Hope to get a big 3xx with the new spec.
#57
Time for an update here:
The "new" engine is already in the car and running spot on! Hope to get on the rollers next week and see what sort of power its coming up with.
Some pics of the build and the finished item:
And heres a video of one of the first tests when running:
http://www.youtube.com/watch?v=Xdq9NkK62tk
#59
Thanks! I'm not too sure what to expect.
Engine spec:
200block
4x4 head
ARP head stud and main stud kit
WRC metal head gasket
BD14 & BD10 cams
T35.63
small turbo plenum
siemens 55s
044 pump
Hope to get close to 4xx
Some new wheels are also ordered but wont be here before mid to end of may...
Engine spec:
200block
4x4 head
BD14 & BD10 cams
T35.63
small turbo plenum
siemens 55s
044 pump
#63
Small update here with new wheels:
The car is off the road during the winter now.
Also got some new bits to play with while waiting for next season...
Rubber braided Ryan loom:
Thanks mate! That thing is top notch!
New Top mounts:
MSD rear diff mount:
New Top mounts:
#72
Make it or break it
