miller3's attempt at a resto::: (Going to Auto Dynamix for a full Chassis loom))
#1060
Thanks Marc, I wish i could afford/justify spending the cash you have on your fez but this thing would never get built lol
I like these tca's better than the compbrake ones when run with comprestion struts as i have never liked the way the load is on the head of the bolt.
#1061
They look great Doug. Are they to replace standards or did you have a set of adjustables if you've got a set adjustables for sale let me know.
cheers,
Phil
cheers,
Phil
#1063
Just read from start to finish & all I've got to say is wow, you car really is beautiful, even after all the trouble you've had.
Top work from everyone involved.
CheeRS
Tom
CheeRS
Tom
#1064
Wow thanks for that Tom, its taken alot of time, hartake, and money to get it to what it is but i dont think the car would have all the nice bits if it went any other way. Were starting to get the longer days/evenings back now so hopefully il get some motorvation back to get it all built back up and on the road at long long last... It may not have all the big expencive grp a type parts on it like other projects but maybe i can add to what i have over time
Thanks for taking the time to read mate :-D
#1077
Hears the spec sheet
ACEWELL ACE-7659 Digital Dashboard FEATURES: Simultaneously displays tachometer, speedometer, fuel gauge and bar-graph temperature meter, gear indicator, 4x4 symbol as well as one other digital readout. The extra sensor input can be used to add a sender to show oil temperature if required. Backlight can be switched with sidelights as per IVA requirements Warning lamps meet requirements of IVA test Bar-graph tachometer can be set to show 0-10,000 or 0-20,000 RPM Compatible with both car and motorcycle engined vehicles Speed input can connect to included magnet/reed switch sensor or optional cable drive adaptor or directly to many speed sensors fitted to automotive gearboxes Gear indicator calculates gear by comparing speed and RPM on manual gearbox cars, so no additional sensors are required 100% water resistant so can be fitted in beach buggies without worrying about rain damage Includes RPM sensing wire, speed sensor, temperature sensor, and generic wiring harness E-Marked for road vehicle use within Europe 170mm x 100.5mm x 30mm Each kit Includes: 1 x Computer 1 x ACE-G Speed sensor and magnet 1 x ACE-PT1/8 Temperature sensor 1/8 NPT which can be used for water or oil temp. 2 x Temperature sensor inputs which can measure water or oil temperature, but please note that only one sender is supplied. Programmable Fuel Gauge which can be set for 10-990 ohms resistance for both full and empty so that it can connect to almost any sender. Voltage warning lamp can be configured for the voltages to come on and off to suit any vehicle 1 x Set of cables & fitting instructions.
