ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
#3762
as for the roll bar time will tell but it is heavy wall tube
I painted it kawasaki green to go with the zakspeed theme it used to be yellow .
its been a long time coming i had to do it one day lol .
#3763
i missed these
Thanks Gary it means a lot mate
Thanks James
Thanks Ben the inner joints are only temporarily held on, i have to fit a spacer inbetween diff & bearing to wide track it, i just need to know how much plunge i need at ride height ?.
Hi Andy,
I know what you mean about the cars looking Awesome. Just the best looking Escort ever.
I will keep you posted on the trip to Europe, we are hoping to be able to run at Spa, Nurburgring and Silverstone or Brands. Could even get it to one of the big Ford shows??
I am watering the money tree every day!!!
Keep up the good work, the latest photo are looking good.
Cheers,
Gary
Cheers,
Gary
Thanks James
#3778
update time again the coil pack & ignition amp brackets are fitted
air injector bracket spacers made
i had to strip the turbo & move the hanger bracket around as it was in the wrong place as the turbo is in a new orientation now ,so i need to make a new turn buckle with new rose joints as the old one is to short .
stainless reducing misalignment spacers all fitted
started plumbing up the tilton pedal box
also plumbing the rear end up
also had to cut the actuator bracket in half turn it upside down & inside out so it lined up correctly ,i just need to get it welded now
more updates to follow tonite .
#3784
thanks for the kind words folks
update time again i trial fitted my new oil filler its not like any other have seen my cam cover filler has been welded up .just to confuse people lol.
sump fitting its a -16 so its quiet big .
wastegate actuator all welded up just need it zinc plated .
i have also fitted my wrc drop links on the rear .
#3789
#3794
This is a very spectacular project!
I've just noticed this on ebay:
http://www.ebay.co.uk/itm/zakspeed-m...m#ht_77wt_1401
Any use to you?
Any use to you?
#3796
Thanks Ron
its surprising how much weight & you can save & it puts a bit of detail into some thing that is usually over looked .
Thanks Dave
I do work on it now & again lol .
Thanks Richie
erm no not quiet .
Thanks Ian
Thanks Dave
Thanks Richie
erm no not quiet .
Thanks Ian
#3797
Thanks mate .
Im not a bufty honest guv
Thanks Glenn
plumbing for all the brakes is done & the new 328mm rear discs are off being machined so i can put some alloy bells on .
Thanks Mark
i will be getting a wrc style breather at some point in the future
Thanks mate im glad you like it
that kit is for a mk1 i got a mk2 .
Thanks Warren
i will go & weigh it next time im in the garage .
Thanks Glenn
