ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
Old 16-09-2012 | 08:57 PM
  #3481
turnover's Avatar
turnover
you should deffo make it Cf show next year then lol,coming along nice Andy well done
Old 17-09-2012 | 07:43 PM
  #3482
Deltaone's Avatar
Deltaone
Default xx
Nice work, as always!
Old 18-09-2012 | 08:28 AM
  #3483
XRT_si's Avatar
XRT_si
Originally Posted by andy escos
Thanks Jonny
Simon done a real good write up & Michael took some great pics too.
Cheers Andy!
I think it came out really well too. Can't wait to see it finished!
Old 18-09-2012 | 06:36 PM
  #3484
andy escos's Avatar
andy escos
Thats the plan but we shall see .
Thanks mate
Originally Posted by XRT_si
Cheers Andy!
was a good write up & as soon as its up & running i willl be getting in contact with you
Old 18-09-2012 | 06:58 PM
  #3485
andy escos's Avatar
andy escos
i been busy down the garage today stripped the old rear callipers down
before
after all ready to go for plating
rear drive shafts painted in 2k
modified throttle pedal
rear hubs all stripped etch primed & painted in 2k
front shafts
Old 19-09-2012 | 05:54 PM
  #3486
Paul Cos's Avatar
Paul Cos
Looking good Andy
Old 20-09-2012 | 04:22 PM
  #3487
andy escos's Avatar
andy escos
Originally Posted by Paul Cos
Looking good Andy
thanks Paul how was your holiday?
Old 20-09-2012 | 05:24 PM
  #3488
whizzisat114's Avatar
whizzisat114
coming on Andy
nice to see your plugging away at it
Old 20-09-2012 | 09:43 PM
  #3489
Paul Cos's Avatar
Paul Cos
Holiday was good mate thanks
Just need to finish the Escos now
Old 20-09-2012 | 09:52 PM
  #3490
COLEYST200's Avatar
COLEYST200
your doing a very nice job of all the stuff andy
Old 21-09-2012 | 05:28 PM
  #3491
andy escos's Avatar
andy escos
Originally Posted by whizzisat114
coming on Andy
bit by bit im getting there Dave
chop chop Paul
Thanks Ian it should last well as well as its all 2k paint
Old 23-09-2012 | 04:12 PM
  #3492
andy escos's Avatar
andy escos
i won a billet power steering pulley of ebay for Ł20 it will be re anodized black
i also painted my rear link arms off the wrc style cradle
wrc bladed roll bar & gear box x member
and the rear uj covers for the gaitors
Old 23-09-2012 | 04:26 PM
  #3493
Minirotty's Avatar
Minirotty
Lucifer II - 666
Old 23-09-2012 | 04:34 PM
  #3494
v6gerry's Avatar
v6gerry
looking good andy going to be a amazzzzzzzzzing escort any time set for getting it finished
Old 23-09-2012 | 06:25 PM
  #3495
andy escos's Avatar
andy escos
Originally Posted by Minirotty
Thanks Kev
Thanks Gerry
im hoping for central day next year .
Old 23-09-2012 | 08:08 PM
  #3496
Paul Cos's Avatar
Paul Cos
Nice one Andy.
Looks like you have been doing the same as me today. Painting bits.
Old 23-09-2012 | 08:16 PM
  #3497
andy escos's Avatar
andy escos
Nice one Andy.
Yes Paul i have nearly painted every thing that needs to be painted in black then i got to get some titanium to do the rear cradle & hubs just for a bit of contrast .
Old 23-09-2012 | 08:50 PM
  #3498
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
looking awesome mate!! If you need any more bits copying into carbon then let me know!
Old 23-09-2012 | 08:53 PM
  #3499
andy escos's Avatar
andy escos
Thanks Warren
how about a full group 5 body kit lol
in all honesty a roof for mine would be cool but i got to get this kit out the way first
Old 24-09-2012 | 08:42 PM
  #3500
Psycho Warren
Carbon Crazy
big panels can be done but as ive got no space up here im a bit limited to doing it in the lounge Anything that can fit on the kitchen table is fair game though.
You could mould off your roof on the car easy enough. Mould making isnt very technical if you can play with gel coats and fibreglass.
its just the resin infusion that needs a vac pump and vac bagging consumables.
I could come down if you want to help show you how it works but its nothing beyond your skills.
Old 25-09-2012 | 06:49 AM
  #3501
graham c's Avatar
graham c
Looks like you need a holiday in Devon warren , few weeks should do you fine and while your down their you can help andy ha ha
Old 25-09-2012 | 08:12 AM
  #3502
Sticky.'s Avatar
Sticky.
Slowly coming together Andy.
Old 25-09-2012 | 06:41 PM
  #3503
andy escos's Avatar
andy escos
as & when im in a position to take a mould off the roof i might take you up on that offer
that would be great if i could afford it lol
Thanks Paul
what would you say if i asked for a full mampe zakspeed sticker set for my car
Old 25-09-2012 | 06:47 PM
  #3504
andy escos's Avatar
andy escos
i stripped the front end down to refurbish it all & finally got every nut bolt washer off the car for zinc plating along with the rear calipers front diff support brackets power steering pipes front strut bodies blades for wrc roll bar compression strut adjusters ,adjustable tca adjusters & loads of other bits i can not remember but its about 20kg,s in weight
BUCKET OF BITS FOR PLATING
Old 25-09-2012 | 06:54 PM
  #3505
Good luck putting them all back from where they came from.
Old 25-09-2012 | 07:00 PM
  #3506
andy escos's Avatar
andy escos
Thanks Glenn i think i need it there got to be getting on for 200 bolts ,nuts washers ,but a fair few will be spares the critical ones are easy to work out ,the fun bit is putting the rear calipers back together .
Old 25-09-2012 | 07:02 PM
  #3507
I bet the calipers will be fun to rebuild.I take it you will be fitting new seals.
Old 25-09-2012 | 07:32 PM
  #3508
andy escos's Avatar
andy escos
yes i got a complete set of seals & the bellows for the sliders off ebay ,the fun bit is there is a bloody great spring in the bottom which is part of the adjuster mechanism & its held in with a circlip .
Old 25-09-2012 | 07:40 PM
  #3509
Sounds like fun.Good luck lol.
Old 25-09-2012 | 07:55 PM
  #3510
Moonstone Mart's Avatar
Moonstone Mart
I did this with my rear calipers - rebuilding I used the hydraulic press at work to hold the spring/washer down in place and then refitted the circlip with a pair of modified (longer pins) circlips pliers.
Worked out pretty easy that way.
Mart.
Old 25-09-2012 | 08:30 PM
  #3511
andy escos's Avatar
andy escos
Mart.
Thanks that sounds an easier way from when i done it last but im afraid my boss threw the old hydraulic press out as it looked tatty
Old 25-09-2012 | 08:41 PM
  #3512
whizzisat114
Could you use a g clamp with a big thick washer welded to the end Andy?
Old 25-09-2012 | 09:24 PM
  #3513
andy escos's Avatar
andy escos
i will have a look when i get them back from the platers .
Old 25-09-2012 | 09:45 PM
  #3514
JonnyBravo's Avatar
JonnyBravo
Car is looking good.
Don't forget to get the blades de embrittled if your getting them plated
Old 25-09-2012 | 09:50 PM
  #3515
whizzisat114
Never heard of that before
what's involved in that process?
Old 25-09-2012 | 09:56 PM
  #3516
JonnyBravo's Avatar
JonnyBravo
Here is a link with a brief explanation
http://www.bobsplating.co.uk/page7a.html
Old 25-09-2012 | 09:59 PM
  #3517
andy escos's Avatar
andy escos
To bloody right i am after my compression strut accident
(WHICH WAS NOT MY FAULT)
during the process of zinc plating microscopic bubbles of hydrogen get trapped in the metal & it causes them to snap .the process to solve this problem is bake them in a oven for 24 hours @ 200degree,s centigrade in a special industrial oven .
i will dig the pics out of what happened to my comp struts.
Old 25-09-2012 | 10:03 PM
  #3518
JonnyBravo's Avatar
JonnyBravo
Where were your comp struts from ?
I sadly have a set of blades which weren't done, although I should say I can't be sure if they were done or not but have been advised not to use them incase.
Old 25-09-2012 | 10:04 PM
  #3519
andy escos's Avatar
andy escos
HERE IS A LINK EXPLAINING IT dAVE
http://metallurgyfordummies.com/hydrogen-embrittlement/
HERE IS THE CURE
http://www.vacaero.com/Vacuum-Heat-T...ittlement.html
Old 25-09-2012 | 10:13 PM
  #3520
JonnyBravo's Avatar
JonnyBravo
Good link Andy
Quick Reply: ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
