ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
#3322
Seeing Builds like yours makes me kick my self for selling my mk2 escort Thunder Saloon Xpack
It went to a guy in the IOW i think it was he had it collected and i just had to do my best wrapping the pannels :0
He was going to email me photos of his build sadly never got any
Look faward to seeing more updates to your build
#3324
Thanks mate when's your mk3 back on track ?
#3325
Hi Andy,
I really do find some random stuff when im browsing round the net lol
Some more stuff you may not of seen before
Link to page: http://www.cg-cars.com/showthread.ph...-MKII-RS/page3
Cheers James
Cheers James
#3329
some Grp.5 Escort pictures & info
Hello
I am not sure if you have seen some of these links images & info...
but here it is:
http://www.turbosport.co.uk/showthre...2-Escort-pics-!
http://www.ten-tenths.com/forum/show...108803&page=21
& if you have time for Facebook:
http://www.facebook.com/pages/Zakspe...41120859276168
keep the good work up
Christian
but here it is:
Christian
#3330
Hi Andy,
Cheers James
Cheers James
Hello
but here it is:
Christian
but here it is:
Christian
#3332
Yes Kev there is a small update
stripped all the rear end out to get powder coated & also got together every thing i needed zinc plating which should be going off this week hopefully .
some of the bits for powder coating
prepped the gear box & got some etch primer on
also prepped the front diff
i also bought another tubular exhaust manifold which is miles better than the other one i bought .
#3336
https://maps.google.co.uk/maps?q=Bod...d+Kingdom&z=20
#3339
it was at the cornwall RS show down at Bodmin town football club
#3340
for now its all standard escort cosworth running gear ,but next year i should be going all skyline on the box & front & rear diffs
Thanks Ben
#3343
[/quote]
I've just found this forum & build. I got a photo of this at the R.S show at Bodmin a while ago. It's probably to late now (but i don't want to go to the end of the build) but how about going green and yellow in the same style as above. This will then keep your signiture paint going? Just a thought.
#3345
Thanks Paul im getting there slowly
I've just found this forum & build. I got a photo of this at the R.S show at Bodmin a while ago. It's probably to late now (but i don't want to go to the end of the build) but how about going green and yellow in the same style as above. This will then keep your signiture paint going? Just a thought.[/QUOTE]
thats a good idea but i got my heart set on the full on mampe colour scheme
Ha ha i bet that took a while to read ,thanks for the encouragement & kind words
#3346
time for an update
The rear aerofoil was very rough so i gave it a quick bit of filler to smooth it off
the horses heads of the spoiler was in a poor condition ,it was held together with expandafoam news paper & filler
so i dug out the foam & put a load of filler in to give me a good base to get the true shape of the top of the 1/4 panel
then i covered the 1/4 panel with cling film
put a huge dollop of filler on the end of the spoiler & held it in place until the filler was hard
sanded back the filler and voila fits like a glove
unfortunately this spoiler will only ever be used for the moulds as there is no strength going through it ,but the new spoilers will have a full laser cut back bone & base with cnc,d mounting points so the spoiler is adjustable .
#3348
Great work on the spoiler Andy i was thinking before the end of your post How the hell is he gonna mount it .lol
I should of known better that it was going to be some king of exotic material made from a mould
You going to any show's this year? ford fair? piss up again?
#3350
cheers mate.
Thanks Dave i will be getting one of my boss,s designers to do all the cad drawings for the profiles & cnc,d bits .
i should be able to go to ford fair ,im not doing many shows this year as the moulds are costing me a fortune
thanks
thanks
#3351
another update
i bought some Eibach helper springs off ebay ,but i cocked up & bought 2.5"springs instead of 2.1/4 " so i bought some nylon 66 off ebay which is a good machining grade with good sliding properties & got a friend to machine me up a set of adaptors for the adjusting platform to take the larger spring & a set of adaptors to go from 2.5 " spring on bottom to 2.1/4 " main spring on top .
i also got him to make me eight m10 miss alignment washers in alloy
i am also upgrading the m12x1.25mm rose joints on my rear link arms to m14x2mm rose joints so i also got my mate to machine up some reducing miss alignment washers to go from m14 down to m12 .
#3354
xx
another update
#3355
No i have not got any thing on the car yet but i have bare metalled the engine to paint in its new colour which will be kawasaki green ,which is in keeping with the zakspeed escorts
and i have 1 litre left over from the rear end of my old colour scheme
i did get a good result a couple of weeks ago i managed to get hold of a 45 gallon drum of resin FREE which should of cost Ł600 & two 25kg drums of blue gel coat FREE but i have had to buy all the matt so far
so all in all im very happy im also got an independent fibre glasser to do the prep work on the new kit & i have just talked him into doing moulds for part of the kit if not all of the kit at a good price so it will be right first time as i can not afford to cock this kit up .
#3356
the grinder in the back ground was just to cut the rear horses heads down the middle as they were to wide for the 1/4 panels so not to bad (no cutting of the shell ) YET .
#3359
Thanks Frayz im getting there.
#3360
done a bit more on the engine i have finished stripping the block back to bare metal ready for painting in its new colour & i have also drilled & tapped the engine mounts out to take m10 instead of m8 which is what they done on the group a rally cars .
i need to get some etch primer so i can start to paint the block .
