ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
#1646
You mean this wenny?
http://www.frost.co.uk/item_Detail.a...oductName=Hole Flare (1in.)&catID=&frostCat=&frostSubCat=&subCatID=
think ill have to buy one of them
#1650
now thats really pissed me off now
i got my 909 flanges on wednesday but i am still waiting on my stub shafts i ordered mine before you .[/QUOTE]
my wife has got onto tnt & atmsport & it turns out that they sent my stubs to some one else (I WONDER WHO IAN) but they are sending another set out tomorrow
#1651
my wife has got onto tnt & atmsport & it turns out that they sent my stubs to some one else (I WONDER WHO IAN) but they are sending another set out tomorrow [/quote]
I though you would have made some pegs up to do this, as they are only std items with the three driveshaft bolts changed for pegs.
#1652
i know that would be a simple fix but the main reason i got new flanges & stubs was the last time i tarted it all up i got the front & rear stubs & flanges zinc plated & they are tight as fook to the point i totally mullered the threads trying to strip them apart
#1653
#1657
How different it tig welding compared to mig Andy? I'm pretty good at mig and i always wanted to give tig a go
Ps looking good mate
#1658
im waiting on the rest of the tube coming before we break up for christmas so i can get the rest of the cage done over the hols
thanks mate im glad you like it your car is awsome
#1660
to be honest doug i get one of the lads from work to do my tig welding as mine is not that good, if you can gas weld then you should be able to tig its all down to practice which is some thing i never get time to do .
#1666
#1669
cheers mate
thanks doug its not as if i need encouraging to get the grinder out is it
the rest of my tube should be here this week so i should get the rest of the cage fabbed up over xmas
#1673
small update
finally got my new tilton pedal box
done a bit more work on the cage got it back up onto the base box,s & mocked up where to put some more tubes.
also got 12mtrs of 40mm x 2mm wall cds tubing .
#1674
the down side of fitting the cage is because im a lanky twat & i raised the floor pan to fit twin side exit exhaust i now have to cut out the o/s rear floor & drop it down 4 "s so i can get my big head in with out hitting the cage ..
at least i can use my grinder again to do some cutting.
