ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
#1521
#1522
that version that Andy has is the sierra one, the later escort one was built using a carbon cover type, I can still get the escort ones (the cover bit) but the sierra ones, well, there wasnt that many to begin with, and there are many variations of the design that differant builders did to suit the application, so there may be others but when they turn up who knows !
#1523
correct ian i did
i thaught it might of been for that reason about fumes & fire ,i got it because it looks neater than the standard motor.
i got mine off muddysport on ebay
thanks dan glad you like.
i didnt know that,thanks markk, a carbon one would look nice
its only a modified standard item, the centre is wrapped in aluminium and riveted on and sealed, and the air intakes are plates with tubes so you can vent the intakes up to the scuttle panel trim.
it was for a crap rule from the MSA about the heater being able to draw in fumes and fire if the engine bay caught fire - didnt matter that the reast of the box was plastic and would melt anyway !
#1527
this has the two, and its purely for the set up, you need to keeo the steering arm angle close to the tca angle, and when you change the cars geo from gravel to tar the tca angle can change dramatically, there was at some point gravel and tar xmembers !
#1530
hi graham not touched it for nearly two weeks cant be bothered lately not touched the arches since i got them in primer ,although there is loads to do i can not do much until the cage is in, them i can see about getting the interior & engine bay in primer then i can get the underneath stone guarded primed then top coat the engine bay & underneath, then its buy new pedal box & mount to roll cage make new steering column which is mounted off cage also.
just remembered i also got to buy & weld in some chassis mounted engine mounts before paint .then i got to get some dimensions of the box section so i can make my own group a style x member to take the tca,s & steering rack .
#1534
Well yes, but I can hardly talk really, got a load to do to get it done for the summer and here I am telling other people to get on with their's Is there anything you can trim off the build list Andy? This is some thing I have been thinking over, for example using the existing x-member and doing the new one next winter? Get the body and all that done then sort out the upgrades kinda thing.
I was thinking this too.
#1535
http://www.rallydesign.co.uk/images/PEDALB.jpg
#1537
no dave far from it
1.make & fit roll cage
2.make brackets & fit new pedal box
3.make new steering column
4.weld in new chassis mounted engine mounts
5.weld in front tow eyes
6.weld in new panel with flared holes in interior
7.fabricate & weld in raised gear lever section
8.seal underside ,engine bay &interior
9.prime & top coat underside engine bay &boot area in venetian red
10.paint interior in a metallic grey base coat & lacquer
11.fit engine & box
12. make new gear box x member
13.make new twin side exit exhaust
14.fit front & rear suspension
15.fit front & rear brakes & plum in
16.modify old engine x member to fit
17.make new dash from scratch
18.make new centre console
19.get dash & console powder coated
20.fit interior
21. sort out worms nest called wiring
22.make new rear diffuser with number plate lighting housing & powder coat
23.paint outer part of shell
24.finish off front wings
25.make mould for front wings
26.make mould for rear wings
27.make new front spoiler
28.make mould for new front spoiler
29.make new carbon fibre rear wings
30.make new carbon fibre front wings
31.make new carbon fibre front spoiler
32.make new running boards
33.paint new body kit
34.plum in new fuel system
35.get all geometry set up & corner weighted
36.fit doors ,boot,bonnet
37.fit all glass
38.get m.o.t.
39.sleep for a week
40. i must of missed some thing but thats most of it .
41.not much then dave
42. ill get there in the end.
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
#1538
no dave far from it
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
i only do short lists for short period
this is scary
#1540
once i get my arse in gear it should not take me that long to do all the shell work & get it in paint & rolling .
true it do look a bit daunting but i done most of the hard work i think .
#1541
no dave far from it
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
#1542
no dave far from it
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
So, have you finished the roll cage yet?
#1549
no dave far from it
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
11.fit engine & box
20.fit interior
37.fit all glass
38.get m.o.t.
39.sleep for a week
Hang in there mate, take your time , and you'll be happy in the end
Joel
#1551
Been a while since i looked in on this...
Like that you at least mentioned me when stealing idea's mate Lol
I was on the norwegian forum and i saw this thread http://www.fordclubnorway.no/forum/t...racing-forder/ it reminded me of your car so had to come take a look and see where you was at with it.
#1552
#1553
i finally got around to do a bit on the car i got richies hole flares so i could finish the last few plates up inside the roof area at the rear got it all welded in & some primer on
i will put pics up later.
#1554
Yea really like it, you have put some serious work in
I go on a few sites from different countries and all different marques dude, get different idea's and see what styles people are into etc.
#1555
I went to a Hostoric Touring Car day at Ruapuna in Christchurch a couple of weeks ago and there was a genuine Zakspeed there. Never had my caemra though.
Here is is:
http://www.flickr.com/photos/warwick...7625271247270/
And in 2009:
Here is is:
And in 2009:
#1557
Here is is:
Here is is:
#1560
here is the pics of last nights efforts
i need to clean the welds up later.
here is what i done tonight
i finally got around to flaring my holes
