Saff underside restore
Old Jan 15, 2005 | 04:39 PM
  #41
leesrs240's Avatar
leesrs240
No worries john you know where i am
Old Jan 15, 2005 | 04:42 PM
  #42
lamb chops's Avatar
lamb chops
Cheers Lee, top man
Old Jan 15, 2005 | 08:34 PM
  #43
M K's Avatar
M K
nice work fella
Old Jan 15, 2005 | 10:22 PM
  #44
cossiemen's Avatar
cossiemen
Whassup
hmm, those pics remembers me @ something i've seen before somewhere
nice mate, very nice, keep up the good work
Old Jan 20, 2005 | 07:30 PM
  #45
lamb chops's Avatar
lamb chops
Well ive just finished the diff, I was going to replace all the drive shaft washers but a full set is Ł45 and im not that sad... yet
Once pay day comes around again things are going to move faster as the underside is getting welded and painted this month as I want the dam thing ready for the spring!! I also have new calipers and disks on the way so should look the bollox
Old Jan 21, 2005 | 07:07 AM
  #46
thats going to look wicked when all back in
Old Jan 28, 2005 | 11:05 PM
  #47
lamb chops's Avatar
lamb chops
I have had a result and have found a good donor car for the rails, its a 91 2000e which were quite rare so im told but im no expert..
I have also striped out the head lining from this and loads of screws and fixings. The rear underside is mint!! I only wish i had found this before as i would have taken all the rear beam and arms too
When the guys ready to take it down the scrapy im going to follow with a great big petrol cutter and get the rails before the cars gone for good.
Old Jan 28, 2005 | 11:28 PM
  #48
Ryan's Avatar
Ryan
Chops any parts i can nab for my 3dr off the donar?
Looks like it has ABS?
Quite badly need a few bits
Old Jan 29, 2005 | 10:30 AM
  #49
lamb chops's Avatar
lamb chops
Yep it sure does Ryan. Let me know what you want
Old Jan 29, 2005 | 11:31 AM
  #50
Old Jan 30, 2005 | 04:31 PM
  #51
BlackSaff's Avatar
BlackSaff
Looking good chops, i've given up on the scrap yard owner cutting my sections out so i'm doing it myself this week with a petrol cutter! I'll get some pics up in mine when i've cut them out!
Old Jan 30, 2005 | 09:24 PM
  #52
lamb chops's Avatar
lamb chops
That would be great if you could Nosrst, how are you planning to cut and weld in to the car? Cut through the car shell or go in at 90 degrees across the box section near where it joins the car?
Old Jan 30, 2005 | 09:37 PM
  #53
BlackSaff's Avatar
BlackSaff
Unpick the original welds mate, do that with both the old and the new.
To get the new section out of the donor i'll just cut at it from back to where it starts before rear footwell, then unpick the welds on the chassis rails afterwards. Removing the original Cossie ones will take slightly more time as it needs to be a bit neater.
Old Jan 30, 2005 | 09:55 PM
  #54
lamb chops's Avatar
lamb chops
OK Nosrst let me know how you get on. cheers
Old Feb 14, 2005 | 11:59 AM
  #55
lamb chops's Avatar
lamb chops
I have some more parts building up now, I also have a chappy in the garage at the moment welding away wont be long now..
Old Feb 14, 2005 | 01:46 PM
  #56
Piccys we want piccys
Old Feb 14, 2005 | 04:34 PM
  #57
CosKev3's Avatar
CosKev3
Going to look spot on
Will be doing mine next winter
Old Feb 14, 2005 | 04:40 PM
  #58
Ryan's Avatar
Ryan
chops whos doing the welding?
looking good mate
Old Feb 17, 2005 | 08:22 AM
  #59
lamb chops's Avatar
lamb chops
Piccys on the way Twins!! Ryan, It was a local chap that was recomended called Mobile Weld. Did a good job and was quite cheap to boot.
CosKev its well worth doing, im just affriad i will end up driving it even less this year as i wont want to get it dirty
Old Feb 17, 2005 | 06:07 PM
  #60
leesrs240's Avatar
leesrs240
You big bufty john..
Old Feb 26, 2005 | 02:39 PM
  #61
lamb chops's Avatar
lamb chops
Well Im getting there finally!! the underside is welded, rust treated, seamsealed and now stone chiped!! paint tomorrow
Old Feb 26, 2005 | 03:00 PM
  #62
leesrs240's Avatar
leesrs240
Get some pics on john
Old Mar 2, 2005 | 04:35 PM
  #63
lamb chops's Avatar
lamb chops
Well paint is on!!
its moonstone but a tad darker than my car but is fine for the underside.
Just need to start putten it back togther now wheres all my bolts and screws..
Old Mar 2, 2005 | 05:09 PM
  #64
leesrs240's Avatar
leesrs240
Well smart m8 bet your glad that part of it is all finished
Old Mar 2, 2005 | 05:38 PM
  #65
lamb chops's Avatar
lamb chops
Yes sure am Lee, dont know where to start putting it back together.. Im going to try and get some new rear brake pipes first, did you replace yours?
I need to spend a fortune at my local ford dealer now on bolts, screws, clips etc
Old Mar 2, 2005 | 06:06 PM
  #66
Old Mar 2, 2005 | 06:24 PM
  #67
leesrs240's Avatar
leesrs240
Just got mine chromed as the were in good condition before..
Old Mar 2, 2005 | 07:10 PM
  #68
lamb chops's Avatar
lamb chops
Not those ones Lee, the ones from the ABS valve block right to the rear, including the T-piece. mine are all nasty.
Old Mar 2, 2005 | 07:11 PM
  #69
lamb chops's Avatar
lamb chops
Here is my parts needed list ... and growing
Parts needed
Brake presure control valve.
Rear brake pipes including T-piece.
Metal fuel pipes from fuel rail to plastic pipes at rear.
Handbrake cable.
2 rear brake splash plates.
2 rear wheel bearings.
Fuel tank plastic clips for breather pipe.
Fuel tank metal mounting clips and bolts.
Brake pipe P-clips.
2 rear koni shocks.
Fuel pump.
Speedo gear.
Pasenger rear abs sensor.
8 wheel hub bolts.
2 axle nuts and washers.
4 Guide plate to floor bolts.
2 guide plate insulator bolts
2 stabiliser bar to crossmember bolts
2 stabiliser brakets
2 shock lower mounting bolts.
4 brake caliper to wheel hub bolts.
2 Abs sensor bolts.
2 left hand exhaust brakets bolts.
4 rear axle mounting insulator to floor assembly bolts
2 stabiliser bar wishbone brakets with rubber gromets.
The Ford dealers going to love me when i come in..
Old Mar 2, 2005 | 07:14 PM
  #70
leesrs240's Avatar
leesrs240
The full lenght flow and return i got painted sorry m8 misunderstud..
Old Mar 2, 2005 | 07:18 PM
  #71
lamb chops's Avatar
lamb chops
ok matey no worries, i think mine is past the painting stage.. going to have to try my luck at the dealer.
Old Mar 2, 2005 | 08:25 PM
  #72
cossiemen's Avatar
cossiemen
Whassup
Old Mar 2, 2005 | 11:26 PM
  #73
Adz 131's Avatar
Adz 131
Looking good mate
Old Mar 2, 2005 | 11:36 PM
  #74
Ryan's Avatar
Ryan
chops if you need any of those bolts i probably got spares, not new, but if you cant get them at fords.
If not i can get old bolts acid dipped and zinc plated.
Well i can get anything done actually.
If you want your lines done let me know, if there not too far done, getting mine done, i polished my last ones, last about 3 weeks before they werent corroded wont be doing that again
Brakes lines im getting re-done green.
Old Mar 3, 2005 | 09:01 AM
  #75
N1C4T3N's Avatar
N1C4T3N
looks gr8 m8t
Old Mar 3, 2005 | 03:49 PM
  #76
Filthy Rich's Avatar
Filthy Rich
Looking well John
I love shopping lists but it'll be well worth it mate
Old Mar 3, 2005 | 04:17 PM
  #77
BlackSaff's Avatar
BlackSaff
Chops have you got any pics of the where the rear beam bolts up and the repairs that have been done? Looking good
Old Mar 3, 2005 | 06:44 PM
  #78
lamb chops's Avatar
lamb chops
Thanks for the coments guys
Ryan I may take you up on your offer.. I will try the ford dealer first and see what they can do, if they cant help expect a PM shortly
NOSRSt I will take a few shots tomorrow for you, how are you getting on?
Old Mar 3, 2005 | 08:32 PM
  #79
phil robson's Avatar
phil robson
looking great chops
wot paint have you used,2 pack, celly?
gonna be doin mine soon,just not to sure about wot paint to use
Old Mar 3, 2005 | 09:06 PM
  #80
BlackSaff's Avatar
BlackSaff
Steady, havn't really done too much just of late. Been Refurbing the fuel pump cradle and thats about it. I need to find out what progress has been made on the body as i havn't seen or spoke to them for over 2 weeks.
