Is it possible?
Old Sep 17, 2008 | 06:17 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Default Is it possible?
I have an original escort rs turbo s2. Its on a d plate and was owned from new by my nan(!). So just 1 previous owner. It has done 130k and to be honest the outside looks good. Only a few scuffs and small dents on the doors. However underneath is rotten. Its had loads of welding- pretty ugly welding too (nearly on every mot). As far as i can see, its got hole in inner wing passenger side (can see from inside wheel arch and engine bay near suspension turrent). Small hole in boot. Both rear inner arches have gone (big gap in btwn outer arch and inner). Its had welding to floor pans,boot,sills,front cross member,battery tray and just about everythere else b4 on the previous mots.
The engine runs (needs setting up as been sat for 2 years) and ive been driving it but needs clutch, gear linkage (real loose)and poss rebuild to get it back to new. Its not noisy and doesnt overheat.
As i said No rust on outside including outer wheel arches,sunroof.
Is there any point in restoring (im not that mechanically minded tho i know a few people that could help with normal things but welding,spraying and engine rebuilding will prob need to go to garage) or would it be better to reshell? Prob is then it wont be a proper rs would it?
I was thinking of getting the welding done that it needs, then strip the interior and giving the under side and inside a good clean then smooth hammerite it white (its in diamond white)inside and out (and under bodykit where you cant see it as well as under bumpers and places where you cant see the finish)where ever I can.Then possible top end rebuild including new cambelt and head gasket.
Then prob just tune it so its making a reasonable amount (180bhp? sensible). Is this a good idea? Ive got a limited budget of about £150 a month and mot and tax due next mth.
Im not looking for a concours car by any means but id like a car thats not gonna rot more and just end up as brown cornflakes in a few years. I aim to keep the car but also get weekend use out of it and enjoy owning a classic that i can use when i want!
Old Sep 17, 2008 | 06:21 PM
I would say repair it as its a one owner car
Old Sep 17, 2008 | 06:24 PM
notroubleclubber
but with the amount of welding thats been done already and what it needs, is it viable that once i rust proof it i shouldnt have no more probs?
Old Sep 17, 2008 | 06:26 PM
All depends on how well its done ,if you cut out the rust properly and repair and rust cure then you should be ok
Old Sep 17, 2008 | 08:10 PM
matts1's Avatar
matts1
Hate to say it, but sounds like it will cost you an arm and a leg mate.
If you had the ability to do all the work yourself then maybe, but your going to run into a good sum of cash to put this right.
Re-shelling, well you would need an S2 shell with history and log book, but then it will become the donner shell car, yours will be scrapped, so no longer a one owner car.
Don't want to put you off, but there is a lot of work ahead of you, think carefully before you dump a lot of cash into a car that wont bring the returns.
The other option is sell it and buy one in better condition, after all, it may be a one owner car but that don't mean much unless it is a prestine show car and even then don't make loads of difference.
Get some pictures up mate.
Matt
Old Sep 17, 2008 | 08:14 PM
Lee Reynolds's Avatar
Lee Reynolds
Rust will always come back. Even cutting out still leaves behind problems. If it is done well, it will last a long time. Escorts from the ford factory could be rotten and fail an MOT after 3 or 4 years and some be even scrap worthy after 5 or 6, so after a full restoration if you get more than 5 without having to do ANY work then youve done a decent job
Old Sep 17, 2008 | 09:21 PM
notroubleclubber
The other idea i had was if i had to reshell the car then I wanted to do a xr2 turbo conversion. I used to have an xr2 years ago and always wanted to turbo one. So if i was gonna lose the 1 owner id i might as well do that. prob is, getting a mk2 xr2 shell!!!!
