Series 1 (Booked in for the full bareshell resto beginning of August)
Old 03-06-2008, 09:55 PM
nicorsts1
nicorsts1's Avatar
Default Series 1 (Booked in for the full bareshell resto beginning of August)
Hi, this is my 1985 Series RST, i first bought this car back in 98, my second car after running a around in Nova SR.
I then sold it on in 2000 and 4 years of regret later out of the RS scene i was lucky enough to buy it back with the intension of doing a full resto.
The bodywork as i knew was'nt to bad, wax-oiled through out, but i knew one of sills had been repaired and the front panel was in a bad way under the kit. The battery tray, fusebox and roof all seemed ok too and it had full service history with folders full of reciepts so it seemed to be a fairly good base.
Well in 2006 i made a start to the long and ongoing resto
Heres some photos
Sometime back in 06, making a start -
Before
Interior Removed
Bodykit Removed 06
Engine Removed + Underneath 07
Loom Removed 07
Has it stands June 08
Old 03-06-2008, 10:27 PM
boothy
boothy's Avatar
a long way 2 go but will look good in the end
Old 04-06-2008, 01:08 PM
nicorsts1
nicorsts1's Avatar
Just been quoted around Ł2000 for the welding and paint work. Replace any damaged sills, rear panel, front panel, wings + cross member etc. Plus extra for Sandblasting the underside/ and inside floor.
The rear floor pan near the VIN stamp and seat mount has a hole, looks to close to the vin i think to repair so i might have to remove the whole panel including the VIN number. I've been told i need to trailor the shell to the nearest DVLA or send a photo of the VIN for identity proof. If the panel is fully repaced they re-stamp the chassis but i've been told they'll do it on the inner wing.
Anyone had this problem? Why cant they stamp it back in the same place?
Old 04-06-2008, 03:50 PM
RSandy
RSandy's Avatar
when i cut out my rear floorpan, i did some research into possibly adding the VIN tag again
basics were that the DVLA were happy to leave it without and just have the VIN plate on the slam panel. and the police would likely see the car as a ringer and impound it until proven otherwise if they saw a non standard VIN tag in place of the original 1
feel free to ask the questions yourself aswel. i even contacted ford but they want mega money to restamp the tag in the original location!!
Old 04-06-2008, 06:33 PM
vroomtshh
vroomtshh's Avatar
I'm not exactly sure of the legality, but we use letter stamps at work for stampng structural steel, so you could always do it yourself. Can get them off ebay for peanuts
Old 05-06-2008, 02:52 PM
nicorsts1
nicorsts1's Avatar
Cheers lads, contacted the DVLA and its a case of either photo proof from a trusted garage or trailoring away to the nearest DVLA place for conformation. Once the repairs carried out they restamp the shell, as to where abouts is upto them i think. Been told to call VOSA for more info on where abouts they stamp it.
Old 05-06-2008, 04:11 PM
COCHYN
COCHYN's Avatar
Looks like you got one hell of a hand full there mate, but a nice project
Old 06-06-2008, 12:05 PM
fraser9764
fraser9764's Avatar
looks good, what are you planning on doing with the roof?
keep up the good work
Old 06-06-2008, 12:44 PM
nicorsts1
nicorsts1's Avatar
COCHYN - thanks mate, can't wait to get stuck in.
fraser9764 - thanks pal, i'm hoping to remove the inner panel, think its only bonded on plus two spot welds. I should be able to get at the underside of the main roof panel then to fully treat it. The photos don't really do the roof panel any justice, its solid, the rust is only on the inner surface, very thin. Its caked in oil, wd40 and whatever else was sprayed down there in its life.
Just hope its fairly staright forward removing that inner panel, any info on how would be well appreciated.
Old 06-06-2008, 03:52 PM
rostill2007
rostill2007's Avatar
gotta love an s1 good luck with it
Old 12-07-2008, 12:47 PM
nicorsts1
nicorsts1's Avatar
I'm going to seperate the internal roof cassette panel and have it all treated, the outer roof panel is solid so should'nt be to bad once seperated.
Plus got the car booked in for the beginning of August to get the shell completely restored
Old 12-07-2008, 02:27 PM
fordrs2005
fordrs2005's Avatar
looks a good shell uve got there , not needing to much attention , keep the pics coming
Old 12-07-2008, 03:16 PM
fezzajsy
fezzajsy's Avatar
looking good
Old 12-07-2008, 04:25 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
good luck, looks not too bad
Old 14-07-2008, 12:25 PM
nicorsts1
nicorsts1's Avatar
Cheers lads, will get plenty of pics up through the resto.
Old 15-07-2008, 08:47 PM
reborns1
reborns1's Avatar
Looks like a nice solid base u got there mate are you gonna go concourse?
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
Bransby
11-09-2015 01:09 AM
Quick Reply: Series 1 (Booked in for the full bareshell resto beginning of August)
