xr3i cab HELP
Old Mar 27, 2008 | 11:28 PM
jimboss's Avatar
jimboss
Default xr3i cab HELP
I have just bought a '90 xr3i Cab and on the way home it cut out as if there was no fuel. I have been told it is probably the fuel pump relay but I cant find it. Does anybody know where it is located?
Old Mar 29, 2008 | 07:30 PM
angliafrans's Avatar
angliafrans
it is the purple relay fitted behind the plastic panel on the drivers side footwell (outside)
Old Mar 29, 2008 | 10:12 PM
cos400's Avatar
cos400
is it efi ??
Old Mar 29, 2008 | 10:25 PM
cos400's Avatar
cos400
efi dont not have a fuel pump relay if that helps
there have a ecu
Old Mar 30, 2008 | 11:38 AM
xrmalin's Avatar
xrmalin
easyest way to find it if its mfi is to take the vent out next to the steering wheel shine a torch down the hole and you'll see a row of relays,reach up behind the dash and pull the purple one out.
Old Mar 31, 2008 | 10:34 AM
jimboss's Avatar
jimboss
yeah its efi. Checked both the yellow relays and they both work. think the problem may be a bit deeper.
I was told if I took the back seats out I could get to the fuel pump via the inspection panel but this doesnt seem to be the case.
How do I get to the fuel pump so I can test it with a multimeter
Old Apr 1, 2008 | 06:15 PM
xrmalin's Avatar
xrmalin
if its efi it will be inside the tank.
Old Apr 4, 2008 | 12:22 PM
jimboss's Avatar
jimboss
any idea where I will get a pump from. am banging my head off walls no one seems to stock tehm any more
Old Apr 4, 2008 | 03:34 PM
ALL4SHOW's Avatar
ALL4SHOW
before you try swapping over relays & stuff have you checked thet the fuel cut off switch hasnt popped out ? i had an efi xr3i do it when i hit a large pot hole !!!! just push it to reset it (its in the boot if you dont already know )
Old Apr 4, 2008 | 11:17 PM
jimboss's Avatar
jimboss
cheers all for show. I have checked it and it is in. I have checked all relays and they all work. it is defo the pump (i think)
Old Apr 25, 2008 | 11:27 AM
jimboss's Avatar
jimboss
I have rpelaced the fuel pump, checked all the relays, bypassed the cutoff switch and still no power to the pump. Wha else could it be. any ideas much appreciated. I have owned it a month now and have only driven it once ing thing!!!!!
Old Apr 25, 2008 | 12:18 PM
ALL4SHOW's Avatar
ALL4SHOW
does the car turn over & just wont fire up ? if it does have you cleaned the fly wheel sensor ?
Old Apr 26, 2008 | 03:54 PM
jimboss's Avatar
jimboss
all 4 show. i havent tried that. surely it cant be something so simple??? where is it locarted? keep the suggestions coming please
Old Apr 27, 2008 | 11:21 AM
Macca RST's Avatar
Macca RST
Could the fuel filter be blocked? Its on the wing in the enginebay I think.
Old Apr 27, 2008 | 03:33 PM
jimboss's Avatar
jimboss
no i have checked the fuel filter thats not blocked
Old Apr 27, 2008 | 09:18 PM
jimboss's Avatar
jimboss
can anybody help please? All4show thinks it may be the flywheel sensor but i aint got a clue where it is and how to clean it.
If that doesnt work can I take a feed straight from the battery, put switch on the dash and power the pump that way or does it have to go through the relay?
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
