S1 resto, Winter Engine Rebuild/New Wheels
#683
It Wasnt Me!
Yes and no
I've decided to put the fiesta turbo engine in, standard rad and cooler or maybe a front mount like airtec..for the moment, on a T3 and piper cam. Reason being, I want the car out for summer and if I stick the ZVH in i'd need a whole load of stuff to get it to work proper and ive just not got the time atm to get it done for the summer!
So, since last update ive got the engine out my fiesta, painted the block, put on a helix padle clutch and new relase bearing, sourced a T3, fitted a piper cam, put my B&M shifter together and re-done my front brake lines in braided hose, sure ive done more but cant think?
couple of pics of the lines, and the engine, need to get some bits shot blasted, pick up my T3 and get my alternator reconned before I put the engine in, not long to go.
then Rab the arsehole he is , is going to help me fit the standard Ofab loom (extend it into the inside of the car somewhere)
this is only temporary tho until next winter when hopefully i'll fit the ZVH after ive bought everything to go in with it!
still need to do the rear brake lines..
need to get my finger the fook out, engine flung in, bodykit on and brake lines done DO IT DO IT DOOO ITTTTT
#685
Redumbdancy
The plans sound good Davy, will be good to see it running no matter what engine is in it.
Rab - I text you about heading along to see it recently, did you get it?
#686
Fucking superstar........
No mate, I haven't. But then phone has been acting up as daughter keeps eating it. On my 3rd phone since I got home last month
I've moved recently too, which was the wifes idea......... I'm in Dunoon now. Joy.
#688
OMG i think i just died THERES AN UPDATE
fiesta turbo eh!? sounds alright for the summer, at least you should be able to get it done well...if you can be arsed that is!!
#689
It Wasnt Me!
I like to take my time as you can see!
I've been hmm'ing and err'ing over what to do but now ive decided I can crack on with it......sure ive said that before
#696
It Wasnt Me!
Chop, Believe me If I could put the ZVH in I would, but unfortunately ive not got another Ł1500 lying about to finnish it at this moment in time... I also cant weld and due to some 'unforseen' circumstances I cant get the help I need to fabricate things. Its not what I want, but unless I want to look at the car over the summer doing nothing then ive no choice....I'm also getting pissed off with the thing so the sooner I make it a working car again the better, once its on the road it can get made to look pretty!
Trust me, its not what I want, but its what needs to happen for the 'moment' the ZVH is still sitting there, it's not going anywhere, im just spreading the cost over a longer period and getting use of the car while im doing so.
anyhoo,
engines in along with rad and cooler...some eagle eyed amongst you may notice it's sitting at an angle...that's because I didnt have the correct top engine mount but a new one is on its way hopefully from ford so i'll put that on tommorow!
Yes it looks shit, engine still needs 'dressed' but I was tripping over it, and now its in I can get on with making it run and address any cosmetics at a later date!
#702
Redumbdancy
Davie - the Golf's grand still, but some old geezer dinged it slightly at work on Saturday, so im looking to get the ding pulled in it (bit of a nightmare )
Rab - gutted for you, the place in Bishopton was really nice too. When are you about until going away again?
#703
It Wasnt Me!
It Wasnt Me!
I dunno mate. Whenever I'm allowed out.
#709
Redumbdancy
#710
It Wasnt Me!
Got the correct engine mount, so engine is now straight...
Bolted a standard turbo on
bought a brand new alternator
painted alternator bracket and heat shield
painted starter, it was newish just dirty
fitted fuel filler pipe
fitted B&M shifter
put some corrigated plastic tubing over the wiring in the inner wing to protect it
need to order turbo oil feed pipe, samco or roose black hoses, Rab needs to get his arse to Glasgow and wire it up for me also
Shamone!
fitted B&M shifter
Shamone!
#711
i still cant believe how clean everything looks!! done a proper good job on it mate...still are you SURE your feeling alright!?
p.s you need to edit your post...its PINK samco's remeber!?
#712
It Wasnt Me!
Fankooo Hev, still more cleaning to do...then going to drive around a big muddy field to break it in (jokes)
Pink samco's, NOOOT ON YOUR NELLY !!!!
#714
I told you Davie, when I'm allowed out I'll come and wire it up for you. Get than manifold off and get Ł5 worth of VHT matt black paint on it! Letting the side down
#719
It Wasnt Me!
Another small update..
Painted manifold and turbo ex housing with VHT plastikot black paint (will it stay on? )
put the turbo back on..
put alternator bracket, adjuster, heat shield and alternator on, put starter on and fitted the speedo cable.
also polybushes the rear trailing arms and painted them black, just need to polybush one rear arm and paint them both black and maybe get the rear springs powder coated,
Got some new bosch ignition leeds too!
some pictchooors...
Just going to order some crackle black for the rocker cover, inlet manifold and few other bits and pieces!
some pictchooors...
